shawn Posted June 4, 2015 Share Posted June 4, 2015 just wondering if anyone would know off-hand what would be the gears most likely found in a truck like this one. it's a hundred dollar special but doesn't really have anything nice about it other than the interior. Link to comment Share on other sites More sharing options...
Crash Posted June 4, 2015 Share Posted June 4, 2015 I believe that there is a thread with all model year specs. But, I want to say 3.73's is what that would have. And, for 100$, you could turn profit on it easy if you don't want to keep it. Link to comment Share on other sites More sharing options...
shawn Posted June 4, 2015 Author Share Posted June 4, 2015 i'd love to find that thread. i always look for the 4 cyl xj's and mj's now for the diffs but this is the first 2.8 ive seen. woulda thought they would have given them at least 4:10s. Link to comment Share on other sites More sharing options...
Pete M Posted June 4, 2015 Share Posted June 4, 2015 being an 86, there's simply no way to know for sure. the ratios weren't really standardized until 87. plus all sorts of craziness can be swapped in over 30 years time. easiest way is to check is to jack up one tire, put the trans in neutral, and rotate the tire around twice while counting the number of times the driveshaft rotates. for example, if the driveshaft rotates around about 3 and a half times then the ratio is 3.55. If for some reason the rear diff has a posi in it, then you'd have to jack up both rear tires and rotate them around just once. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted June 4, 2015 Share Posted June 4, 2015 My 86 2.8 5 speed donor truck had 4:10's in it. Link to comment Share on other sites More sharing options...
88whitemanche Posted June 4, 2015 Share Posted June 4, 2015 This 86 had the 2.8 and had the amc 20 with 4.10s non posi.... Link to comment Share on other sites More sharing options...
Wiggilez Posted June 4, 2015 Share Posted June 4, 2015 my 2.8 4x4 with 5 speed has 3.55's Link to comment Share on other sites More sharing options...
86FUBAR Posted June 5, 2015 Share Posted June 5, 2015 Mine were 3:55 with a 5sp Link to comment Share on other sites More sharing options...
shawn Posted June 7, 2015 Author Share Posted June 7, 2015 That's about half and half reporting 4:10s. Maybe i'd better get back out there and have a second look at it. Link to comment Share on other sites More sharing options...
shelbyluvv Posted June 7, 2015 Share Posted June 7, 2015 My 86 had a 2.5 with a AX-5 with 3:07 gears. It's best you check them for yourself to be sure. Link to comment Share on other sites More sharing options...
