mattbuch96 Posted April 23, 2016 Share Posted April 23, 2016 So did you drill completely through your visor so you could run your wires under the visor? Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 24, 2016 Author Share Posted April 24, 2016 Yes. The visor itself isnt even 1/8 thick, and only fiberglass. Its very easy to drill all the way through. And those lights are considered "flush mount" so they require a 3/4" hole to be drilled and mounted into Here is the link to the lights http://www.amazon.com/Maxxima-M09300YCL-Combination-Clearance-Marker/dp/B00L5204O4 Link to comment Share on other sites More sharing options...
mattbuch96 Posted April 30, 2016 Share Posted April 30, 2016 What wire did you use to connect all the lights together? Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 30, 2016 Author Share Posted April 30, 2016 Just some regular 16ga 2wire power cord with crimp connections and heat shrink. Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 5, 2016 Author Share Posted May 5, 2016 clipped a rouge piece of rebar and blew a sidewall out,. so went out and got a fresh set of 33x10.5r15 BFG KO2s Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 5, 2016 Author Share Posted May 5, 2016 also had my leaking FSU repaired by a buddy and reinstalled it last week. finally no more constant gas smell! Link to comment Share on other sites More sharing options...
A-man930 Posted May 6, 2016 Share Posted May 6, 2016 On 5/5/2016 at 11:51 AM, mikekaz1 said: clipped a rouge piece of rebar and blew a sidewall out,. so went out and got a fresh set of 33x10.5r15 BFG KO2s I'm fixin' to get those exact tires here soon. If they're anything like the original KOs then I'll be happy Link to comment Share on other sites More sharing options...
gogmorgo Posted May 6, 2016 Share Posted May 6, 2016 Also looking at those tires, as they're pretty well the only ones I've found that say they meet my needs. But if they're anything like the original KO's, I'll be severely disappointed. Snow/ice performance is a pretty big deal for me. My MJ had the KO's on it when I bought it, and it was only a couple hours after the first snowfall that I got something better... Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 7, 2016 Author Share Posted May 7, 2016 On 5/6/2016 at 5:27 PM, gogmorgo said: Also looking at those tires, as they're pretty well the only ones I've found that say they meet my needs. But if they're anything like the original KO's, I'll be severely disappointed. Snow/ice performance is a pretty big deal for me. My MJ had the KO's on it when I bought it, and it was only a couple hours after the first snowfall that I got something better... On 5/6/2016 at 3:03 PM, A-man930 said: On 5/5/2016 at 11:51 AM, mikekaz1 said: clipped a rouge piece of rebar and blew a sidewall out,. so went out and got a fresh set of 33x10.5r15 BFG KO2s I'm fixin' to get those exact tires here soon. If they're anything like the original KOs then I'll be happy I think they look awesome. I've only put 30-40 miles on them tops. But they are noticeably better then the duratracs that were on it. I don't get nearly as much wheelspin, the duratracs loved to just spinout if I was trying to merge quick or something. And really you DIDNT like the KOs in the snow? That's one of there highest stats on tire rack. Link to comment Share on other sites More sharing options...
gogmorgo Posted May 7, 2016 Share Posted May 7, 2016 Those are the ratings for the ko2, not the original ko. Tire rack rates the ko in the 8's on snow and a 7.2 on ice. And I'm pretty sure that's generous, given it seems like half the reviews seem to mistake it with the KO2. But yeah. Even in 4x4 I was struggling to keep the truck pointed in a straight line. It's an old-fashioned durable, rock-hard tire. Not great for cold weather. Night and day difference when I switched to the Grabber at2's. Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 8, 2016 Author Share Posted May 8, 2016 On 5/7/2016 at 2:03 PM, gogmorgo said: Those are the ratings for the ko2, not the original ko. Tire rack rates the ko in the 8's on snow and a 7.2 on ice. And I'm pretty sure that's generous, given it seems like half the reviews seem to mistake it with the KO2. But yeah. Even in 4x4 I was struggling to keep the truck pointed in a straight line. It's an old-fashioned durable, rock-hard tire. Not great for cold weather. Night and day difference when I switched to the Grabber at2's. Huh. You might be the only person I ever met that didn't genuinely love the all KO1 or 2 Link to comment Share on other sites More sharing options...
gogmorgo Posted May 8, 2016 Share Posted May 8, 2016 I'll admit I don't know how old they were on the truck. Had probably 30% tread left. But the truck I was driving at work early this winter had them too, and it was the same story. Shouldn't need 4x4 just running around on packed snow. Admittedly they were a bit better than the Wrangler SRA highway no-seasons on the new truck I got in Februrary... I'm also tentative about the KO2, as we've been putting them on all the trucks at work when the factory tires go bad, and they were constantly coming back in for patches with small rocks pushed through them between the . I work for a national park and probably 75% of the miles our trucks see are on gravel, so that may just be par for the course. It may also have just been an earlier run of the KO2's, as the newer ones don't have as much trouble. But so far it's the only severe-snow rated tire I've found in a 32 or 33 x 10.5 x15. Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 8, 2016 Author Share Posted May 8, 2016 Ah. Gotcha! Well that was part of my Dilemma too. I wanted a really good snow tire also in 33x10.5. As I plow in the winter and those duracraps were gawd awful. Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 9, 2016 Author Share Posted May 9, 2016 attempted to put on my push bumper from my old bumper. Realized I REALLY didn't like how it looked with the Waggy nose. Took the rubber bumpers and fog lights off and put them on the chrome bumper. Link to comment Share on other sites More sharing options...
mikekaz1 Posted May 10, 2016 Author Share Posted May 10, 2016 also bolted up my gas tank skid finally. had to make some nut strips for the bed rail but went on smoothly. Link to comment Share on other sites More sharing options...
mikekaz1 Posted June 14, 2016 Author Share Posted June 14, 2016 Little poser shot with my chrome wagoneer badging Link to comment Share on other sites More sharing options...
Reddout Posted July 7, 2016 Share Posted July 7, 2016 On 3/10/2016 at 4:19 PM, mikekaz1 said: XJW nose wired and installed too! Love your build, man. What year Wagoneer did that grill come out of? I know you said the end result was lighting wasn't as good, but how hard was it to wire the quad lights? I really like that look Link to comment Share on other sites More sharing options...
mikekaz1 Posted July 8, 2016 Author Share Posted July 8, 2016 On 7/7/2016 at 8:20 PM, BigRedFan said: Love your build, man. What year Wagoneer did that grill come out of? I know you said the end result was lighting wasn't as good, but how hard was it to wire the quad lights? I really like that look I think this one was specifically a 87. but all 86-90wagoneer headers are the same. lighting is just as good as the single headlight, wattage is all the same, just lenses themselves are smaller. but no issue seeing at night whatsoever. wiring the quad lights just involves separating the factory 3 prong plug and wiring high beam power to one light and low beam power to the other. maybe 5 minutes of work. Link to comment Share on other sites More sharing options...
88whitemanche Posted July 8, 2016 Share Posted July 8, 2016 So your set up didn't come with the separate wiring harness? I pulled one a while ago and grabbed the complete harness with the header... Link to comment Share on other sites More sharing options...
mikekaz1 Posted July 8, 2016 Author Share Posted July 8, 2016 no I did not have the factory quad wiring. i just too that opportunity to wire a HD relay setup. if you do have the factory harness, and its intact with the plug for the drivers side harness. it should be 100% plug and play Link to comment Share on other sites More sharing options...
Reddout Posted July 8, 2016 Share Posted July 8, 2016 On 7/8/2016 at 3:59 PM, mikekaz1 said: no I did not have the factory quad wiring. i just too that opportunity to wire a HD relay setup. if you do have the factory harness, and its intact with the plug for the drivers side harness. it should be 100% plug and play Thanks, good to know Link to comment Share on other sites More sharing options...
mikekaz1 Posted July 11, 2016 Author Share Posted July 11, 2016 got the back rack mounted up. rack was part number 10313 listed for a 1996-03 DODGE DAKOTA 1997-03 TOYOTA TACOMA and the mounts were 92001 tonneau adapter slightly modified to allow me to still use my tool box. overall the fit is pretty good. the top cross bar with the tonneau adapter goes perfectly around my cargo light and sits about 1/4" higher then the cab. if you don't have a cargo lamp the standard mounts will work fine. and the adapter brackets not needed. but with the cargo lamp the bar ran right across the lamp, effectively making it useless. Link to comment Share on other sites More sharing options...
mikekaz1 Posted August 4, 2016 Author Share Posted August 4, 2016 aerial shot Link to comment Share on other sites More sharing options...
mikekaz1 Posted August 4, 2016 Author Share Posted August 4, 2016 found this vintage style grille badge on ebay, Link to comment Share on other sites More sharing options...
Reddout Posted August 4, 2016 Share Posted August 4, 2016 Just keeps getting better & better. Like that aerial shot Link to comment Share on other sites More sharing options...
