Zenobian_84 Posted October 22, 2014 Posted October 22, 2014 So I finally decided to make the jump from having a bench seat to having bucket seats in the MJ. I wasn't sure how I'd feel about it, but man, what a difference. Those first few minutes after making the switch, pretty much felt like this video. . :MJ 1: . I don't feel like I'm slouching into the floorboards anymore, plus, I gained an inch or two; enough so I can finally see out of the rear view mirror correctly (yes, and I'm 6'1 to boot). :banana: As you can see, the bench seat is still adjusting to it's new home in the back of the bed. Not sure yet what I'm going to do with ol' blue. Now I don't know what to do with all the extra space in the cab. So many decisions to make... :hmm:
JeepcoMJ Posted October 22, 2014 Posted October 22, 2014 ...they're not even the same seats lol. Add a center console...heaven.
AeroNautical Posted October 22, 2014 Posted October 22, 2014 Do this: 97+ XJ center console, I'm so happy with it. 2 cup holders, nice 4wd shifter window, decently sized cubby and the option of putting a hand brake in it.
88whitemanche Posted October 23, 2014 Posted October 23, 2014 Do this: 97+ XJ center console, I'm so happy with it. 2 cup holders, nice 4wd shifter window, decently sized cubby and the option of putting a hand brake in it. No mods to make it fit?
Blue XJ Posted October 23, 2014 Posted October 23, 2014 Do this: 97+ XJ center console, I'm so happy with it. 2 cup holders, nice 4wd shifter window, decently sized cubby and the option of putting a hand brake in it. That's what mine looks like too, same seats, but in tan with a 97+ console. I was able to use the 97+ shift boot as well to fill that opening aroud the shifter. Had to scoot the console rearward a little though, the boot would bunch up and make it tough to get into 2nd.
AeroNautical Posted October 23, 2014 Posted October 23, 2014 It does take a little modding, I had to remove the heat box that directs heat to the foot wells, but that can be avoided with a little trimming on the console itself. I haven't yet found a 97+ shifter boot, but there isn't much in my truck for looks anyway, I'm not too worried about it, haha.
mpace6a Posted October 23, 2014 Posted October 23, 2014 It does take a little modding, I had to remove the heat box that directs heat to the foot wells, but that can be avoided with a little trimming on the console itself. I haven't yet found a 97+ shifter boot, but there isn't much in my truck for looks anyway, I'm not too worried about it, haha.Seen someone use a crown royal bag as a shift boot once....
JeepcoMJ Posted October 24, 2014 Posted October 24, 2014 Also, the heat box from an xJ solves the issue...if you use the plastic heat tube that goes with it.
Motorcharge Posted October 26, 2014 Posted October 26, 2014 The 97+ consoles should more or less bolt right in since the biggest issue on swapping them in older XJs is the fact that the parking brake is in a different spot. The little half circle area in the middle of the console is great for switches too.
jimoshel Posted October 26, 2014 Posted October 26, 2014 After reading the above posts, it became very apparent that some folks just don't know the difference between a "bucket seat" and a "hole in the ground" These, people, are bucket seats. .
jimoshel Posted October 26, 2014 Posted October 26, 2014 And once again. it seems I cannot post a pic
Pete M Posted October 26, 2014 Posted October 26, 2014 is this along the lines you were thinking jim? :D
johnj92131 Posted October 26, 2014 Posted October 26, 2014 is this along the lines you were thinking jim? :D r Pete: I really like this modification!! Works great for a road trip when the wife wants/needs to stop every 50 miles for a "potty break". Just use the bucket and keep on moving!!
Guest Posted October 27, 2014 Posted October 27, 2014 Exactly. Even looks like the same bucket. Was seriously considering running around with a few milk crates if I couldn't find some brackets. Throw some padding on 'em, and they're as good as OE. :yes: :shake:
