NHMJXJ Posted September 16, 2014 Share Posted September 16, 2014 I dropped the rear driveshaft pulling into my driveway tonight. I'm not a mechanic, but I think I can handle this. I just need some guidance and a few answers. I swiped the following picture from another site, so you have a visual ... What ever covers the end of the U-joint that fits under the U shaped flat steel plate is GONE (which problably explains the nasty vibration I felt right before the drive shaft dropped). I could back out the bolts that hold that plate on by hand. I literally coasted into the end of my driveway. I limped the truck into its spot by putting it in part time 4wd, which brings me to question No.1 ... was that a mistake? Second, I foolishly separated the front of driveshaft from the ... transfer case? Yes? Whatever the doohicky is the front of the driveshaft goes in. It puked about a cup of fluid. I did this because I was trying to align the u-joint and couldn't spin the shaft. I figured if I could just bolt the thing back up, I could yard drive the truck to position it for repair. Question No. 2 ... does the front of the driveshaft just find a seat? It didn't spin when I put it back in. Question No. 3 ... I'm guessing I have to have both rear tires off the ground to line up the new u-joint with the rear end. Yes? help Link to comment Share on other sites More sharing options...
mikejenn2 Posted September 16, 2014 Share Posted September 16, 2014 first chock the tires. then put transfer case in neutral. this should make it so you can spin shaft. I am under the assumption that the u joint is still intact ? if so then yes u can bolt it back up but I would prob replace the u joints since this Is already out. to answer the question it does not hurt the truck to use the part time 4x4 I have made it out of the trail many times like this. as far as the puking of fluid I think it is dex 3 auto transmission fluid just pull the plug on the transfer case and fill it back up after the shaft is in all the way. sorry for the short response but I have to leave the house soon. if anyone wants they can correct me on any of this or give better description thanks. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 16, 2014 Share Posted September 16, 2014 mikejenn2 has you covered. I would most definitely replace the rear u-joint at this point.......if not both. Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 16, 2014 Author Share Posted September 16, 2014 Me thinks the u-joint is junk. Any special tools needed to replace the u-joints? Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 16, 2014 Share Posted September 16, 2014 Press....or....C-camp........or hammer and socket.......or........ If you have another vehicle you can take the DS and your new U-joints to any good trans shop and they could fix you up for about $30......I'm guessing. Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 16, 2014 Author Share Posted September 16, 2014 If you have another vehicle you can take the DS and your new U-joints to any good trans shop and they could fix you up for about $30......I'm guessing. That's the right tool. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 16, 2014 Share Posted September 16, 2014 What ever covers the end of the U-joint that fits under the U shaped flat steel plate is GONE (which problably explains the nasty vibration I felt right before the drive shaft dropped). I could back out the bolts that hold that plate on by hand. Are you saying that the one of the rear u-joint cups under the steel straps was gone? :hmm: If so, the tab on the pinion yoke that holds it in might be snapped off. Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 16, 2014 Author Share Posted September 16, 2014 Yes, the cup was gone. The OD of the end of the u-joint would have been swimming under that steel strap, if I'd managed to get everything back up. I'll look in daylight. I didn't see any clean, broken metal on anything, but it was dark, I was on my back under the truck with a flashlight in my teeth and my bifocals weren't helping matters. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 16, 2014 Share Posted September 16, 2014 If that tab is sheared off, you will have to replace the pinion yoke too. That happened to me on the old D35 when one of the straps loosened up. Link to comment Share on other sites More sharing options...
88whitemanche Posted September 16, 2014 Share Posted September 16, 2014 Or upgrade to u-joint straps.... Link to comment Share on other sites More sharing options...
91Pioneer Posted September 16, 2014 Share Posted September 16, 2014 If the strap bolts were loose, then the tab might not be broken off. I replaced my pinion yolk just a few days ago, so if you have any questions just ask. This is the pinion yoke I bought (it fits Dana 35), it worked great and it's cheap: http://www.amazon.com/gp/product/B000FQ7UIO/ (see my review there LOL) Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 16, 2014 Share Posted September 16, 2014 If you have a d35, or whatever you have uses the same yoke, I have one if yours is bad . Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 16, 2014 Author Share Posted September 16, 2014 Figured I'd go out and take a look ... the tabs on the yoke are intact. Phewww. Thank you all for your help! This site and its members are awesome! :clapping: There's hope for me yet. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 16, 2014 Share Posted September 16, 2014 Figured I'd go out and take a look ... the tabs on the yoke are intact. Phewww. :thumbsup: Good to hear. Link to comment Share on other sites More sharing options...
mjeff87 Posted September 16, 2014 Share Posted September 16, 2014 Use some blue loctite on those strap bolts and a good 6-point 5/16" socket (do not use a 12 pt socket or wrench, the heads round off quite readily). Jeff Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 17, 2014 Author Share Posted September 17, 2014 Thanks for the tip Jeff ... So vicegrips are definitely out then, right? (Kidding!) I called my garage today and they're going to install the U-joints. Dropping the driveshaft off tomorrow morning and will pick it up on my way home. Should be back in action tomorrow night. Link to comment Share on other sites More sharing options...
mvusse Posted September 17, 2014 Share Posted September 17, 2014 first chock the tires. then put transfer case in neutral. this should make it so you can spin shaft. I am under the assumption that the u joint is still intact ? if so then yes u can bolt it back up but I would prob replace the u joints since this Is already out. to answer the question it does not hurt the truck to use the part time 4x4 I have made it out of the trail many times like this. as far as the puking of fluid I think it is dex 3 auto transmission fluid just pull the plug on the transfer case and fill it back up after the shaft is in all the way. sorry for the short response but I have to leave the house soon. if anyone wants they can correct me on any of this or give better description thanks. This will work if the central axle disconnect on the front axle is disengaged. Since he pulled into his driveway in 4wd, then presumable shut off the engine without shifting to 2wd first, it is still engaged. So he will either have to start the engine, shift to 2wd and turn it off, or remove the front driveshaft, or lift a front tire off the driveway. Why? Because the NP231J made before 1994 does not have a true neutral. In neutral it locks the front and rear driveshafts together. Shifting the transmission into Neutral and the transfer case into 2wd will always work. Link to comment Share on other sites More sharing options...
Blue XJ Posted September 17, 2014 Share Posted September 17, 2014 first chock the tires. then put transfer case in neutral. this should make it so you can spin shaft. I am under the assumption that the u joint is still intact ? if so then yes u can bolt it back up but I would prob replace the u joints since this Is already out. to answer the question it does not hurt the truck to use the part time 4x4 I have made it out of the trail many times like this. as far as the puking of fluid I think it is dex 3 auto transmission fluid just pull the plug on the transfer case and fill it back up after the shaft is in all the way. sorry for the short response but I have to leave the house soon. if anyone wants they can correct me on any of this or give better description thanks. This will work if the central axle disconnect on the front axle is disengaged. Since he pulled into his driveway in 4wd, then presumable shut off the engine without shifting to 2wd first, it is still engaged. So he will either have to start the engine, shift to 2wd and turn it off, or remove the front driveshaft, or lift a front tire off the driveway. Why? Because the NP231J made before 1994 does not have a true neutral. In neutral it locks the front and rear driveshafts together. Shifting the transmission into Neutral and the transfer case into 2wd will always work. x2, I was going to comment the same thing, I didn't know the year they changed it, but I know my tcase locks the front and rear outputs together in neutral. Link to comment Share on other sites More sharing options...
NHMJXJ Posted September 18, 2014 Author Share Posted September 18, 2014 There's proof. This place is full of subject matter experts. I did put the Tcase in neutral and the shaft wouldn't spin. Only had a little daylight left, so I got both rear wheels off the ground. With the wheels able to spin freely, I could hand turn the yoke on the rear end to mate with the new u-joint. I slid the driveshaft in, lined up the u-joint and in it went. This must have been a progressive event because my truck never felt smooth, but it rides absolutely vibration free now. Link to comment Share on other sites More sharing options...
