What's up guys
So this morning I was at the bank and noticed there was a nice ledge to take a picture while flexing...I don't flex often but I just wanted to give it a try...the ledge wasn't steep maybe about 10" high and I don't have a locker(open diffs)
When I started to go up the ledge I would give it a good amount of gas and it'll bog then shut off...
Turn the truck on again tried 3 more times and it happened again...
Is there something I'm missing? Fuel issue? Or something?
Any insight is great thanks....
How much gas did you have?
After the first time stalling...the second time I stepped on it to the floor and I guess being too much of a stress it shut off....idk it was weird...I know how to ease off the clutch to add a bit more torque but it just cut off....
he means how much gas did you have in the tank, since the mj tank isnt baffled iirc the pump might have not been pulling gas.
1/4 tank...
I know my mj will light the empty gas light at 1/4 and below when going around corners so that could be the issue but idk. Is the 88 Carbed or efi?
1/4 tank...
Tbi- throttle body injection....
That's probably why you stalled.  1/4 isn't much when tilted/flexed.  Fill her up full and try again.  You should have different results. :thumbsup:
Will try that later on today after work...
I can put a tire around 4' in the air with my fuel light on, I doubt thats his problem.
I would say the main issue is probably lack of power/gearing,a front locker would help too.
If its TBI its a 2.5l.
I've pulled my manche on car ambulances with short ramps with my little TBI, and it has severely worn piston rings. I doubt it's a power issue.
If he can't climb up it, either the tires have to break lose or the engine has to stall.
I believe he is also running 32s with stock gearing.
4 hi isn't a climbing gear. I also say you didn't have the correct gears to pull you up. Just straight lack of power so it stalls. i can ride trails for hours on a quarter tank. I never stall and when flexing around it goes below E.
I assume you drove the front wheels right up into contact with this ledge, then tried to crawl up it from a dead stop?
With 32" tires and a 2.5L engine running stock gearing, that's an excellent way to burn out your clutch, or break something. Stalling the engine probably saved you a big repair bill. The factory put a low range in the transfer case for a reason -- try using it.
agreed. I've tried climbing little things with my rubi lj and bogged the motor down badly. grab 4lo and boom I'm up on top with minimal throttle input.
I bogged the hell out of the mj trying to play on a snow bank. backed off grabbed 4lo and up she went.
