sinkrun Posted March 3, 2014 Share Posted March 3, 2014 Mine are rusted away my question is do I need to put them back on?? I am worried about weather it will affect the unit bearing spacing. Link to comment Share on other sites More sharing options...
jimoshel Posted March 3, 2014 Share Posted March 3, 2014 They have no effect on bearing spacing. They are necessary to keep crud out of the brake system. Calipers, pads don't work so well if they are jammed up with crud. Link to comment Share on other sites More sharing options...
sinkrun Posted March 3, 2014 Author Share Posted March 3, 2014 Jim, do you happen to have a rust free set that you could get mailed quickly? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted March 3, 2014 Share Posted March 3, 2014 What year ? 4 or 2wd ? I'm thinking they might be the same between 2 and 4wd if so I might have a set I have to check Link to comment Share on other sites More sharing options...
Dillithium Posted March 3, 2014 Share Posted March 3, 2014 If you're comfortable with tin snips they're quite easy to make yourself. You just have to drill the holes for the wheelbearing hub and cut a circle. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 3, 2014 Share Posted March 3, 2014 2WD / 4WD Samo-samo http://www.jeep4x4center.com/splash-shield-passenger-side-52005476.html http://www.jeep4x4center.com/splash-shield-driver-side-52005477.html Link to comment Share on other sites More sharing options...
earl*t Posted March 3, 2014 Share Posted March 3, 2014 IIRC, it cost less to ship them individually instead of buying both. :dunno: What's up with that? Link to comment Share on other sites More sharing options...
ride172 Posted March 3, 2014 Share Posted March 3, 2014 I got rid of mine after a rock found its way in between rotor and shield. Thought I was doing myself a favor ... oh well, won't be the last time I do something dumb .. Link to comment Share on other sites More sharing options...
sinkrun Posted March 3, 2014 Author Share Posted March 3, 2014 Thanks for the link Hornbrod that`s not to often something from mopar is that cheap. I have been on Cherokee forum looks like allot on there do not use them? Link to comment Share on other sites More sharing options...
jimoshel Posted March 4, 2014 Share Posted March 4, 2014 Jim, do you happen to have a rust free set that you could get mailed quickly? I've got some. Would be Wed tho before I could get them in the mail. Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted March 4, 2014 Share Posted March 4, 2014 They are also essential for brake cooling. May sound odd, but they direct air onto the vents helping cool the brake rotors down. Link to comment Share on other sites More sharing options...
sinkrun Posted March 4, 2014 Author Share Posted March 4, 2014 Jim, do you happen to have a rust free set that you could get mailed quickly? I've got some. Would be Wed tho before I could get them in the mail. What would you take for them priority mail shipping to 16680. Link to comment Share on other sites More sharing options...
jimoshel Posted March 4, 2014 Share Posted March 4, 2014 If you were close enough to come get them, I'd give them to ya. Since I gotta pull them, $5 for the pair. Don't know what shipping would be. Link to comment Share on other sites More sharing options...
sinkrun Posted March 4, 2014 Author Share Posted March 4, 2014 Jim, I checked from your zip code to mine 1 pound priority mail (non flat rate) was $6.20 for a 12x12x4" package. How about I paypal $15.00 if its more I will be sure to pay you this way you don't have to make two trips to the post office. And many thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 4, 2014 Share Posted March 4, 2014 Jim, I checked from your zip code to mine 1 pound priority mail (non flat rate) was $6.20 for a 12x12x4" package. How about I paypal $15.00 if its more I will be sure to pay you this way you don't have to make two trips to the post office. And many thanks! I think he means a Regional Rate A2 box. Link to comment Share on other sites More sharing options...
sinkrun Posted March 4, 2014 Author Share Posted March 4, 2014 No just regular priority mail in any box you can find or just wrap cardborad around them and make a box and tape it up good. I bet regional would be very pricey as far as it has to go. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2014 Share Posted March 4, 2014 Necessary for a mainly road driven vehicle. I remove them on every single offroad rig, there is nothing worse than the noise rocks make when they're stuck between a dust shield and rotor. Link to comment Share on other sites More sharing options...
benjy_26 Posted March 4, 2014 Share Posted March 4, 2014 Ditto. I take em off. I run slotted rotors with aggressive pads anyway. I NEED my brakes to get a bit hotter for them to work their best. Link to comment Share on other sites More sharing options...
Dando Posted March 4, 2014 Share Posted March 4, 2014 Right or wrong I have removed them on my XJ and ran without them for at least 6yrs now. I haven't had an issue. Link to comment Share on other sites More sharing options...
gogmorgo Posted March 5, 2014 Share Posted March 5, 2014 Due to road salt, mine are slowly removing themselves... they aren't tin. Hasn't been an issue yet. Ditto. I take em off. I run slotted rotors with aggressive pads anyway. I NEED my brakes to get a bit hotter for them to work their best. Wouldn't leaving the shield on lead to better heat retention? What with less air flow and all? Link to comment Share on other sites More sharing options...
benjy_26 Posted March 5, 2014 Share Posted March 5, 2014 Due to road salt, mine are slowly removing themselves... they aren't tin. Hasn't been an issue yet. Ditto. I take em off. I run slotted rotors with aggressive pads anyway. I NEED my brakes to get a bit hotter for them to work their best. Wouldn't leaving the shield on lead to better heat retention? What with less air flow and all?. Well.... It depends on what school of thought you follow. During high speed road racing with lots of corners and the appropriate wheels and body work, the shields help push air into the the brake assembly, across/ through the rotor (if vented), and out of am open face wheel. This is augmented many times by cooling air ducts built into the air dam of the vehicle, in effect giving.you a ram-air effect. In my case, I don't push my brakes THAT hard, even while perfoeming chase/support duties. With my vehicle having relatively small, closed face wheels on it most of the time (Canyons taken off of a TJ), and the brakes relying solely on the movement of undirected air across them for cooling, I get a decent balance of cooling and bite by running without the shields. Besides, I live and wheel in the desert, so heat retention is hardly ever an issue. :). One thing to keep in mind, though, if you operate in muddy conditions, it may be best to leave the shields on. No senae in making your pads wipe the mud off the rotors before they can brake. Link to comment Share on other sites More sharing options...
benjy_26 Posted March 5, 2014 Share Posted March 5, 2014 Oh, btw, on my MR2 ( which does have air ducts for thr brakes), I do indeed run the shields, along with dimpled and slotted rotors, braided lines, high temp fluid, and very aggressive pads (EBC USR rotors and Yellow Stuff pads). That thing has below average to average braking when cold, but it gets downright violent once the tires and brakes have gotten up to temp. Link to comment Share on other sites More sharing options...
Gnarmanche Posted March 6, 2014 Share Posted March 6, 2014 You should be alright without them... Link to comment Share on other sites More sharing options...
