Blaine Posted December 27, 2013 Posted December 27, 2013 anyone know where to find the exhaust clamp that slide into the rubber insert on the cross-member transmission mount
airspeed Posted December 27, 2013 Posted December 27, 2013 There is a support / bracket that mounts to the square exhaust flange just in front of the cat. converter. This bracket has an extension that slides into the rubber mount of the cross member. Rock auto has them but I would just check your local parts store, it is a low cost low tech part.
Blaine Posted December 27, 2013 Author Posted December 27, 2013 yea problem is they don't know what your talking about or discontinued
HOrnbrod Posted December 27, 2013 Posted December 27, 2013 You're not going to find that at RockAuto. P/N 52003040, EXHAUST DOWNPIPE SUPPORT, 1987-2001 JEEP XJ/MJ $20.00 http://www.arizonaparts.com/
Blaine Posted December 27, 2013 Author Posted December 27, 2013 got this from the internet i need part# 9 what is it called
carnuck Posted December 27, 2013 Posted December 27, 2013 I noticed that 2wd and 4wd are inverted from each other or it could be a year difference.
HOrnbrod Posted December 27, 2013 Posted December 27, 2013 Can you read? The below IS the part number for #9. 2WD and 4WD use the same part support.P/N 52003040, EXHAUST DOWNPIPE SUPPORT, 1987-2001 JEEP XJ/MJ, $20.00.You can get it here: http://www.arizonaparts.com/Call the guy and order it if you want it. I've done business with him before - good guy.
carnuck Posted December 27, 2013 Posted December 27, 2013 I can read but there is no pic for it on that site.
HOrnbrod Posted December 27, 2013 Posted December 27, 2013 I prefer part numbers over pictures. They are a bit more accurate. And what does "I noticed that 2wd and 4wd are inverted from each other or it could be a year difference" mean? :hmm:
54bobby Posted December 27, 2013 Posted December 27, 2013 not to thread jack but, is there a gasket that goes to the union of the down pipe and the exhaust pipe? if so, does anyone have a pic or a pn?
Keyav8r Posted December 28, 2013 Posted December 28, 2013 54Bobby - the gasket is #8 on the diagram above. It fits between the downpipe and the catalytic converter. Autozone, Advance Auto, NAPA, O'Reillys, etc. have them for $2 to $4. Advance Auto - Walker PN 31519, Fel-Pro PN 60292
carnuck Posted December 28, 2013 Posted December 28, 2013 The "U" of the hanger is upside down in some of these. When I switched from stick to auto I ran into it.
HOrnbrod Posted December 28, 2013 Posted December 28, 2013 Why do I bother with you. :dunno: More misinformation. First you said "I noticed that 2wd and 4wd are inverted from each other or it could be a year difference." Now it's "When I switched from stick to auto I ran into it." The rubber insulator pictured below is universal for all. The smile is UP. The universal bracket for all (P/N 52003040) fits the rubber UP smile, as shown in whatever pic you posted.
Eagle Posted December 28, 2013 Posted December 28, 2013 not to thread jack but, is there a gasket that goes to the union of the down pipe and the exhaust pipe? if so, does anyone have a pic or a pn? The down pipe goes into the catalytic converter. It uses a 4-bolt flange and it requires a gasket. The catalytic converter then connects to the muffler, using a conventional male/female slip joint and muffler clamp. The exhaust pipe fits into the muffler outlet, again using a conventional muffler clamp. See post #5.
carnuck Posted December 28, 2013 Posted December 28, 2013 Why do I bother with you. :dunno: More misinformation. First you said "I noticed that 2wd and 4wd are inverted from each other or it could be a year difference." Now it's "When I switched from stick to auto I ran into it." The rubber insulator pictured below is universal for all. The smile is UP. The universal bracket for all (P/N 52003040) fits the rubber UP smile, as shown in whatever pic you posted. Like I said, I'm not sure what the difference was, but I pulled the 2wd BA 10/5 out and put the 4wd AW4 in and that piece was already on the trans but the U shaped piece on the pipe was upside down and wouldn't fit any other way. I ended up sticking it in the same direction as the smile and flipping it over before attaching it to the pipe flange.
fiatslug87 Posted December 28, 2013 Posted December 28, 2013 Here' the diagram with part numbers from the '90 parts manual for anyone that searches for exhaust.
54bobby Posted December 28, 2013 Posted December 28, 2013 guys, I recently put an entire exhaust on my 87 2.5. I bought a gasket from rock auto listed in the exhaust gaskets/seals drop down and it is listed as packing. it is felpro #60836. can anyone tell me where this goes?
Eagle Posted December 29, 2013 Posted December 29, 2013 guys, I recently put an entire exhaust on my 87 2.5. I bought a gasket from rock auto listed in the exhaust gaskets/seals drop down and it is listed as packing. it is felpro #60836. can anyone tell me where this goes? What does it look like? For an '87 2.5L, I believe there should be only two gaskets in the exhaust system. The first is the round "donut" gasket where the down pipe meets the header/exhaust manifold outlet, and the other is a rectangular gasket with four bolt holes surrounding the center hole -- that one is for where the down pipe outlet mates to the inlet side of the catalytic converter.
carnuck Posted December 29, 2013 Posted December 29, 2013 Pic shows it to be a donut, but I thought they had the manifold with it built in by '87?
Blaine Posted December 29, 2013 Author Posted December 29, 2013 guys, I recently put an entire exhaust on my 87 2.5. I bought a gasket from rock auto listed in the exhaust gaskets/seals drop down and it is listed as packing. it is felpro #60836. can anyone tell me where this goes? Look on post #17 shows whole exhaust system
airspeed Posted December 30, 2013 Posted December 30, 2013 The 2.5 does not use a gasket between the exhaust manifold and the down pipe. The convex radius is formed into the exhaust header.
54bobby Posted January 20, 2014 Posted January 20, 2014 what does the rest of this assembly look like? how does part #52003040 connect to the down pipe?
yxmj Posted January 20, 2014 Posted January 20, 2014 what does the rest of this assembly look like? how does part #52003040 connect to the down pipe? Scroll back in this thread....in the blown up drawing it is the pieces marked 9 (bracket) and 20 & 21 are the rubber isolator and holder If you look at post #13 in the thread there is a picture of the whole assembly
54bobby Posted January 20, 2014 Posted January 20, 2014 so, if I buy the part listed from Arizona parts, will it be the whole assembly? I talked the the guy there and he don't know either. just that they have it for 20 bucks.
