Opinions Wanted.
A friend of mine who is an absolute jeep nut is eyeing an 86 thats for sale in my home town. We are going to take a look see tomorrow, but before he goes off the deep with Comancheitis i wanted to see what you guys thought of it.
The Good:
Single owner
LWB, W/ factory bed bars and fog lights (not factory)
4X4
Auto, On the Column!
red interior
Bench seat
The Bad:
2.8 V6
Currently, Unknown mileage. We will know when we go to look at it.
Dented to hell
Front clip is messed up
passenger side window no worky
Paint is faded pretty bad
I am pretty sure my friend is going to buy it regardless, but i just wanted to know what you guys think would be a fair price so i have something to shot for when haggling.
He is currently asking $1400, i was thinking somewhere along the lines of $1000. Depending on the miles.
Is this the one with all of the stickers on the back? Keep in mind that a 86 auto will be a TorqueFlite and not an AW4 and that with a 2.hate in front of it it will be almost painfully slow. Other than that, sounds like a good beater or restoration project depending on your friend's goals.
Pictures aren't showing up. Sounds like a fun project, though. Is that what he wants it for?
Posted pictures via photobucket. . . still not there?
Don't know about the first part, the truck is for sale in my town, Woodbury, Middle TN. Thanks for that little bit of info on the tranny. I had no idea the comanche came with any other auto other than the AW4. Just how bad is the torqueflight?  Can it be swapped for an AW4? I am pretty sure that would be a no, but just in case. I already know that 4.0 is b*@$£ to swap into an 86 so that is another mark against it, but if thngs go south at least we the option of swapping in the 2.5
Oh, okay, it isn't the one I'm talking about. It's a 904 three speed, old style hydraulic so none of the AW4 wiring will be there. If I were your friend I would wait to get one the way I wanted it. The one rely posted will be almost the exact same, except it has the TBI 2.5. The body looks pretty good though.
Why are there always so many 86s for sale in TN? :hmm:
can't see the pics, but if the body's rough 1000 is overpriced (here in MO anyway). Bed damage or any cab damage thats not fixed by replacing with xj body panels is a huge strike against price. but as far as engines go, just get a 3.4 out of a firebird or camaro and swap it in with an ax5 or ax4.
If swapping in a 2.5 is an option to replace the 2.8, then swapping in a 4.0 is not that much more work.  I did it in roughly 4 months by myself, working on it a few hours a night here and there. It can be done and it's not has hard as one would think. Running all the wire harnesses is the same amount of work on 2.5 or 4.0. If I had to do another one, I would do it. But that's just my 2¢...
Use the link on photobucket next to the IMG text box.
As for the topic, I'd pass. An '86 just isn't worth that kind of money with those specs and a beat up body. I'm only asking $1200 for the '86 in my sig but it has a manual and 99% straight body.
My friend is kinda bonkers about getting a jeep, particularly an MJ. He has had several ill advised automotive deals in the past and i am desperately trying to get him to reconsider. To give you an idea of the kind of guy he is, if he hadnt told me about this potential purchase he probably would have met the guy and handed over the entire $1400 without giving it a second thought. He is a good guy, its just he doesnt know what the hell he's doing.
How bout now, can you see the pics?
The body looks a lot better than I thought it was going to. I'd still stay away though because of what it'll take to remedy the 2.8 problem and the fact a 4.0 rig could be had for the same amount. Only reason I ignored the 2.8 issue of the '86 I bought earlier this year is because of the holley stuff which does bring some life to that crappy engine since I've seen the conversion on an S10. Figured I'd engine swap down the road.
But unless you go 3.4 as a swap pretty much everything will need to go and you'd basically just need a donor rig. That's why I decided to call it quits on my '86 and just buy a 4.0 rig with a lot already done to it for 1000, the extra cost and work didn't make sense to me at that point.
Well guys, he bought it . . . .  :rant: aaaaand he paided the full $1400 :rant: aaaaand he didnt even bother to negotiate :rant: . Come to find out his dad had cut him a cashier's check for $1400, no questions asked. Before driving it i figured 750-800 would have been a fair price, but once i actually saw the truck and drove it, if you can even call it driving, i wouldn't have given a nickle more than $500.
After a very thorough going over this is what i could find.
Body dented to hell
Motor ran like sh*t, stalled out three times while driving.
Biiig oil leak (owner denied)
Transmission was utterly utterly shot, (owner said it was rebuilt professionally 6 months ago)
Even the Mutherflunkin 4wd didnt hardly work. Takes 2 hands to get it into 4hi and when you try to shift into 4lo it just grinds and/or immediately pops out and grinds, severely.
Driver's side window doesn't roll up, at all. Passenger side would, but handle is broken.
Arm rests are broken/falling off
Seat belt latches are broken, literally, the latch case is broken in half.
The ENTIRE front clip will need to be replaced, all the signal lights are broken/busted.
Brakes go completely to the floor, yes they stop the truck, but if you need to stop with any sort urgency you can forget it.
Headliner is missing
Back bumper is trashed
Idiot gauge cluster, none of it works
Before i get to carried away there were a few "good" things about it. . . .
Tail lights fully intact, amazingly
Tail gate in decent condition
Horn works
Low and High beams work
Blinkers work, for the most part
Emergency brake works fantastic
Factory lwb bed bars
ZERO rust   EDIT: Couldnt check the floorboards.
Straight frame
No tears in bench seat
Bed liner
Factory radio works very good
"door open" buzzer works
Oh and the one thing that i forgot to mention to my friend is that Murfreesboro has emissions and there is no way in hell that truck is going to pass.
P.S. My friend is probably going to be joining the club in a few days, now that he owns a comanche. I know hes an idiot, but please try to be gentle.  Believe me i want to do this  :thwak:  to him as much as everybody else on here.
