redwolf624 Posted November 17, 2013 Author Posted November 17, 2013 It took you a long time to find the bad one you've got!!!!! that is true, but now i know what i'm lookin for, Redwolf
gogmorgo Posted November 17, 2013 Posted November 17, 2013 That's a decent amount of work pulling a tack bar out of another vehicle in questionable condition at a yard when the most expensive stock replacement off RockAuto costs $70. They've got a Moog for $42. And if you do any serious offroading, now would be a good time to upgrade to something beefier.
redwolf624 Posted November 17, 2013 Author Posted November 17, 2013 That's a decent amount of work pulling a tack bar out of another vehicle in questionable condition at a yard when the most expensive stock replacement off RockAuto costs $70. They've got a Moog for $42. And if you do any serious offroading, now would be a good time to upgrade to something beefier. good point, my local advance has one for 36 bucks but i can't remember if it's a moog or not, Redwolf
cruiser54 Posted November 17, 2013 Posted November 17, 2013 That's a decent amount of work pulling a tack bar out of another vehicle in questionable condition at a yard when the most expensive stock replacement off RockAuto costs $70. They've got a Moog for $42. And if you do any serious offroading, now would be a good time to upgrade to something beefier. good point, my local advance has one for 36 bucks but i can't remember if it's a moog or not, Redwolf Go buy it.............
carnuck Posted November 20, 2013 Posted November 20, 2013 I got an adjustable tracbar for $100 delivered 10 years ago. I think it was Superlift.
redwolf624 Posted November 21, 2013 Author Posted November 21, 2013 bought my new track bar today, it's a drive works but as long as it replaces the broken one, is there a special way to take the old track bar off, also how easy is it to replace? Redwolf
redwolf624 Posted November 22, 2013 Author Posted November 22, 2013 um, got bad news, i just replaced my track bar this mornin, greesed the new one up and everything, had no loud pop untill i left my local scrap yard, now that loud pop is back, why, how, what went wrong? what else could it be cause EVERYTHING is tight and greesed, Redwolf
carnuck Posted December 18, 2013 Posted December 18, 2013 Sounds like the lower control arm bolts (at the frame) might be slightly loose. Mine did that to me a couple times before I got the double serrated lockwashers.
cruiser54 Posted December 18, 2013 Posted December 18, 2013 um, got bad news, i just replaced my track bar this mornin, greesed the new one up and everything, had no loud pop untill i left my local scrap yard, now that loud pop is back, why, how, what went wrong? what else could it be cause EVERYTHING is tight and greesed, Redwolf Best thing to do is see if you can duplicate the symptom sitting still and see-sawing the wheel back and forth. If you can have someone do that while you have a gander underneath, that would be the best. Refresh my memory here. Did you actually put a wrench/socket on the trackbar bracket to framerail bolts?
redwolf624 Posted December 18, 2013 Author Posted December 18, 2013 Sounds like the lower control arm bolts (at the frame) might be slightly loose. Mine did that to me a couple times before I got the double serrated lockwashers. trust me it's not the controls arms, i checked em with a torque wrench :) um, got bad news, i just replaced my track bar this mornin, greesed the new one up and everything, had no loud pop untill i left my local scrap yard, now that loud pop is back, why, how, what went wrong? what else could it be cause EVERYTHING is tight and greesed, Redwolf Best thing to do is see if you can duplicate the symptom sitting still and see-sawing the wheel back and forth. If you can have someone do that while you have a gander underneath, that would be the best. Refresh my memory here. Did you actually put a wrench/socket on the trackbar bracket to framerail bolts? as far as takin a wrench to the track bar bracket, no i didn't, i did it the hard way, fought with the cotter pin and retainin nut and a pickle fork, and i can duplicate the pop, only when i turn the wheel all the way to the left at for lock, Redwolf
cruiser54 Posted December 18, 2013 Posted December 18, 2013 You need to do that. Got air tools? Those bolts were not tight enough from the factory. The popping noise started cropping up on customer's new rigs. It was so bad that we adopted a policy of tightening those fasteners during the Pre-delivery inspection. This is definitely a stone I wouldn't leave unturned.
AMCJeepMJ Posted December 18, 2013 Posted December 18, 2013 Those bolts were not tight enough from the factory. The popping noise started cropping up on customer's new rigs. It was so bad that we adopted a policy of tightening those fasteners during the Pre-delivery inspection. This is definitely a stone I wouldn't leave unturned. Out of curiosity, what should it be torqued down to?
gogmorgo Posted December 18, 2013 Posted December 18, 2013 I'm on board with this. My MJ's track bar bracket bolts are somewhat loose, as I think I mentioned somewhere above. I know they're loose because I can see evidence around the heads of the bolts that it's moving around. Unfortunately, though, when I tried tightening them, I couldn't get them to budge at all, and that was applying near 200 ft-lbs by my reckoning.
carnuck Posted December 18, 2013 Posted December 18, 2013 Make sure there aren't any rocks stuck in the bottom loop of the coil spring too.
redwolf624 Posted December 18, 2013 Author Posted December 18, 2013 You need to do that. Got air tools? Those bolts were not tight enough from the factory. The popping noise started cropping up on customer's new rigs. It was so bad that we adopted a policy of tightening those fasteners during the Pre-delivery inspection. This is definitely a stone I wouldn't leave unturned. no air tools for me, my dad's old school and what exactly should i be tightin, the trackbar retainin nut of the bracket? Those bolts were not tight enough from the factory. The popping noise started cropping up on customer's new rigs. It was so bad that we adopted a policy of tightening those fasteners during the Pre-delivery inspection. This is definitely a stone I wouldn't leave unturned. Out of curiosity, what should it be torqued down to? according to the haynes manual this is what it says for torques; "track bar ballstud nut....62ft-lbs trach bar-to-axle bracket nut.....74ft-lbs" that's just for the trackbar, i got all the torque specs for almost everything on a MJ/XJ Make sure there aren't any rocks stuck in the bottom loop of the coil spring too. trust me i checked that first cause it started both times i when off road and no rocks or anything, Redwolf
cruiser54 Posted December 18, 2013 Posted December 18, 2013 Redwolf: Just tighten the living $#!& out of the bolts that hold the trackbar bracket to the frame rail. Pull as hard as you can. Squirt some Panther Piss type stuff on the threads first. Easy.
redwolf624 Posted December 19, 2013 Author Posted December 19, 2013 Redwolf: Just tighten the living $#!& out of the bolts that hold the trackbar bracket to the frame rail. Pull as hard as you can. Squirt some Panther Piss type stuff on the threads first. Easy. ok, i'll try that today once i get home from work if the sun's still up, if not i'll try it satuday, Redwolf
cruiser54 Posted December 19, 2013 Posted December 19, 2013 Until you've done that, you're wasting time and money. Remember, don't just look at 'em. Tighten 'em.
redwolf624 Posted December 19, 2013 Author Posted December 19, 2013 Until you've done that, you're wasting time and money. Remember, don't just look at 'em. Tighten 'em. i know, i'll let yall know what happens when i get day light time to mess around with it, Redwolf
cruiser54 Posted December 19, 2013 Posted December 19, 2013 Until you've done that, you're wasting time and money. Remember, don't just look at 'em. Tighten 'em. i know, i'll let yall know what happens when i get day light time to mess around with it, Redwolf That daylight stuff happens about 12 to 15 hours each day, doesn't it?
redwolf624 Posted December 21, 2013 Author Posted December 21, 2013 Until you've done that, you're wasting time and money. Remember, don't just look at 'em. Tighten 'em. i know, i'll let yall know what happens when i get day light time to mess around with it, Redwolf That daylight stuff happens about 12 to 15 hours each day, doesn't it? sun goes down around 5, i don't get home till 6, Redwolf
cruiser54 Posted December 21, 2013 Posted December 21, 2013 Got flashlights in Virginia Beach? Extension cords? Trouble lights?
HOrnbrod Posted December 21, 2013 Posted December 21, 2013 This guy has more excuses than a dead horse has flies. Weather permitting of course. :yes:
redwolf624 Posted December 21, 2013 Author Posted December 21, 2013 yeah i got flashlights but workin underneither a vehicle is not somethin i'll do in the dark, i'll work under the hood in the dark but not underneither, but i'm bouta put the MJ in the drive way so i'll update yall when i know somethin, Redwolf
