thejim42 Posted July 24, 2013 Posted July 24, 2013 Did the automatic mjs and 5 speed mjs with the 4.0 have the same speedometer gear? I went to hook everything on the trans of my 87 my 5 speed 2wd w/ 4.0 and the gear was missing
Geonovast Posted July 24, 2013 Posted July 24, 2013 They're swappable, but not the same, as the auto and manual used different axle gearing. If you put a gear out of an auto into a manual, both with factory axles and wheels, your speedometer(and therefore odometer) will be incorrect.
thejim42 Posted July 24, 2013 Author Posted July 24, 2013 What about the 4cylinder 4 speeds or 5 speeds?
Geonovast Posted July 24, 2013 Posted July 24, 2013 Here, this might help. Unfortunately I don't know actual tooth counts. 4.0 + 5 speed = 3.07 gears 4.0 + auto = 3.55 gears 2.5 + 5 speed = 4.10 gears 2.5 + 4 speed = 3.55 gears 2.5 + auto = 4.56 or 4.10 There were slight variations on the types of gears used, but I think you'll be fine if it's close in year.
thejim42 Posted July 24, 2013 Author Posted July 24, 2013 Any idea where I might be able to buy a new one other than a dealer?
onlyinajeep726 Posted July 24, 2013 Posted July 24, 2013 eBay... seriously. It's where I got mine. Just as an example, if you've got a 4.0 with auto, 4.10 gears swapped in running 31-32" tires, you want a 37 tooth speedo gear.
JeepcoMJ Posted July 24, 2013 Posted July 24, 2013 Someone confirm what tooth count he needs, should be 27 or 29, and I'll mail him one.
Rymanrph Posted July 24, 2013 Posted July 24, 2013 There are long and short shaft gears depending on the year (probably all the same with MJs and XJs though). If you can't find the gear with the correct length shaft, they can be swapped. This is usually an issue when you put larger tires on.
thejim42 Posted July 24, 2013 Author Posted July 24, 2013 My mistake my truck is an 88. Don't know about shaft length its a Peugeot ba10/5 trans with 235/75 r15 tires and 3.07 gears
onlyinajeep726 Posted July 25, 2013 Posted July 25, 2013 Refer to these links. Not sure if it matters with it being a manual or automatic, but I'm pretty sure you need a 29 tooth gear, long shaft. Long shaft is for cable driven speedometers, short shaft is for the electronic driven speedometers. Yours is obviously cable driven being an '88. http://jeep-xj.info/HowtoSpeedoGears.htm http://www.quadratec.com/jeep_knowledgebase/article-46.htm I would also like to mention for peace of mind that I used these exact charts to determine what speedometer gear I needed when I put my 4.10's in with 31's and it is within 1 mph of my GPS at all speeds up to 75 mph (that's the fastest I've went with a GPS in my Jeep).
HOrnbrod Posted July 25, 2013 Posted July 25, 2013 Long shaft is for cable driven speedometers, short shaft is for the electronic driven speedometers. Not true. 91-92 and some 93 models used long shaft speedo gears; all had electronic speedometers. Manual or auto transmission does not matter. The correct speedo gear tooth count is determined by tire diameter and rear differential gear ratio. Also the plastic gears themselves are the same for all. You can swap the shafts between the gears easily.
Geonovast Posted July 25, 2013 Posted July 25, 2013 Long shaft is for cable driven speedometers, short shaft is for the electronic driven speedometers. Not true. 91-92 and some 93 models used long shaft speedo gears; all had electronic speedometers. Also the gears themselves are the same on all. You can swap the shafts between the gears easily. This is because the early electric speedos were just an electronic adapter that attached to the sender the exact same way the cable did. The later ones were integrated, which I believe is when they switched to the short shaft.
onlyinajeep726 Posted July 25, 2013 Posted July 25, 2013 Long shaft is for cable driven speedometers, short shaft is for the electronic driven speedometers. Not true. 91-92 and some 93 models used long shaft speedo gears; all had electronic speedometers. Manual or auto transmission does not matter. The correct speedo gear tooth count is determined by tire diameter and rear differential gear ratio. Also the plastic gears themselves are the same for all. You can swap the shafts between the gears easily. Long shaft is for cable driven speedometers, short shaft is for the electronic driven speedometers. Not true. 91-92 and some 93 models used long shaft speedo gears; all had electronic speedometers. Also the gears themselves are the same on all. You can swap the shafts between the gears easily. This is because the early electric speedos were just an electronic adapter that attached to the sender the exact same way the cable did. The later ones were integrated, which I believe is when they switched to the short shaft. Well, I just learned something new then lol. I was (mis)informed last year on another forum about the speedometer gears apparently. I guess it pays to do a little more reading. It even has a breakdown for the different years in the first link I posted... :doh: But thank you for the clarification.
onlyinajeep726 Posted July 25, 2013 Posted July 25, 2013 Yes. http://www.ebay.com/itm/XJ-ZJ-CJ-MJ-JEEP-Wrangler-29-Tooth-LONG-Shaft-Speedometer-Gear-Cherokee-Mopar-/251286397611?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a81d622ab&vxp=mtr
JeepcoMJ Posted July 25, 2013 Posted July 25, 2013 pm me your address and I will send one out to you in the morning.
Gubachoo Posted November 12, 2020 Posted November 12, 2020 Does anyone here have a big ole stash of these guys laying around? Just swapped my gear ratio and need a 32 long. Trying to avoid buying a new one if possible. Can mail the old one back to add to the stash. If someone hasn't become this person yet, someone should (I don't have a garage or would be happy to)
Pete M Posted November 12, 2020 Posted November 12, 2020 1 hour ago, Gubachoo said: Does anyone here have a big ole stash of these guys laying around? Just swapped my gear ratio and need a 32 long. Trying to avoid buying a new one if possible. Can mail the old one back to add to the stash. If someone hasn't become this person yet, someone should (I don't have a garage or would be happy to) you should probably post up in the classifieds
Gubachoo Posted November 12, 2020 Posted November 12, 2020 40 minutes ago, Pete M said: you should probably post up in the classifieds W3 Will do, thanks Pete
Gubachoo Posted November 12, 2020 Posted November 12, 2020 31 minutes ago, fiatslug87 said: What color is a 32 tooth gear? I think it's a black one? not sure though
fiatslug87 Posted November 12, 2020 Posted November 12, 2020 Oh, I don't remember having any black ones, green, yellow orange is what I remember.
Gubachoo Posted November 13, 2020 Posted November 13, 2020 5 hours ago, fiatslug87 said: Oh, I don't remember having any black ones, green, yellow orange is what I remember. Well thanks for looking. I appreciate that.
