Rebelfish99 Posted July 6, 2013 Share Posted July 6, 2013 Finally found a camper that fits perfect in the MJ, just need to get some leveling air bags and some extended mirrors and all will be well. Link to comment Share on other sites More sharing options...
mpace6a Posted July 6, 2013 Share Posted July 6, 2013 Cool! Looks good on the jeep! Very roomy on the inside? Link to comment Share on other sites More sharing options...
Automan2164 Posted July 6, 2013 Share Posted July 6, 2013 Some inside pics would be cool, curious minds are spinning... That rear door looks like it may be a pain to get in and out of gracefully. Rob Link to comment Share on other sites More sharing options...
SW86 Posted July 6, 2013 Share Posted July 6, 2013 x2 on the inside pics. i can agree about getting in and out but if your young it shouldnt be a problem lol. maybe pop off the tailgate for like a step action with the bumper. also i like how you blanked out your plate in the first pic but forgot to in the second lol! Link to comment Share on other sites More sharing options...
rmoore1031 Posted July 7, 2013 Share Posted July 7, 2013 You can get mirrors off a F150 and screw them into your door like I did on my MJ. Link to comment Share on other sites More sharing options...
Geonovast Posted July 7, 2013 Share Posted July 7, 2013 I'm diggin' the fender blindspot mirrors. Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 7, 2013 Share Posted July 7, 2013 very nice -- we need model numbers & such Link to comment Share on other sites More sharing options...
RubberDuck Posted July 7, 2013 Share Posted July 7, 2013 also i like how you blanked out your plate in the first pic but forgot to in the second lol! he didn't blank out the first pic, its just really, really dirty. Link to comment Share on other sites More sharing options...
Jerry Posted July 7, 2013 Share Posted July 7, 2013 Nice rig! Is that an a/c unit in the back? I use airlift levellers on my rig. There ok but not perfect, fitting them was a real pia. I like the fancy new style organic flip flop camper jack you've put on the rear left top pic, looks very stable ;) Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 7, 2013 Share Posted July 7, 2013 Bah! I saw a Skamper camper this spring on the local CL... I knew I should have picked it up. Link to comment Share on other sites More sharing options...
Alexia Posted July 7, 2013 Share Posted July 7, 2013 So, how much does it actually apply that the owner's manual states that truck bed campers should never be used? I wondered the reason behind that manufacturer decision. Link to comment Share on other sites More sharing options...
Jerry Posted July 7, 2013 Share Posted July 7, 2013 So, how much does it actually apply that the owner's manual states that truck bed campers should never be used? I wondered the reason behind that manufacturer decision. Easy to tip over. Rebelfish's is fine though, it's a drop top with a low C of G. I drive mine very carefully, mostly. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 7, 2013 Share Posted July 7, 2013 Too much side-to-side rolling with the stock suspension causing rollovers. However if the rear suspension were beefed up slightly like the below, it should be fine. Link to comment Share on other sites More sharing options...
Geonovast Posted July 7, 2013 Share Posted July 7, 2013 Maybe add a rear sway bar in addition to those air bags (or MT springs :brows: ). Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 7, 2013 Share Posted July 7, 2013 Or you could always go this route: Link to comment Share on other sites More sharing options...
Jerry Posted July 7, 2013 Share Posted July 7, 2013 Maybe add a rear sway bar in addition to those air bags (or MT springs :brows: ). Been thinking of adding a sway bar. Are they available off the shelf for the Comanche? Or would l be looking at custom build? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 7, 2013 Share Posted July 7, 2013 I would think adapting a Ford Ranger 1 or something similar would be ok. I don't think ive seen an aftermarket MJ Rear swaybar available, but i could be wrong... Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 7, 2013 Share Posted July 7, 2013 http://www.swaybars.com/detail.asp?productid=5334 Short bed only - mounts to the upper shock bolts with angle brackets. Poor design IMO. A better option is a rear sway from an S10 or Blazer. The length is correct; end links and mounts to the frame will have to be fabbed. Image Not Found Link to comment Share on other sites More sharing options...
Jerry Posted July 7, 2013 Share Posted July 7, 2013 Thanks for the info guys Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 11, 2013 Share Posted July 11, 2013 I agree with the rear sway bar. Many that I've seen on the rear for these are so small that I can't see how much good they would be. I think one similar in size to the front would be best for you especially with the slide in in place. You might look at grand Cherokees or Durango's to find one to adapt. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 11, 2013 Share Posted July 11, 2013 The Addco rear sway bar is 1.125" diameter... I have one. My only thoughts on this are to not crank them down too tightly on the ends or it will act like more like a spring instead of a sway bar, and that the mounts to the axle should really have a more secure method of attachment instead of u-bolts [i have had to re-tighten them twice and had to order a replacement part when I lost one on the road]. Other than than that, the sway bar rocks. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 11, 2013 Share Posted July 11, 2013 The Addco rear sway bar is 1.125" diameter... I have one. My only thoughts on this are to not crank them down too tightly on the ends or it will act like more like a spring instead of a sway bar, and that the mounts to the axle should really have a more secure method of attachment instead of u-bolts [i have had to re-tighten them twice and had to order a replacement part when I lost one on the road]. Other than than that, the sway bar rocks. Are you referring to the MJ rear sway bar? The MJ ADDCO front bar is 1-1/8" dia.; the rear is 7/8" dia. http://www.addco.net/aftermarket/catalog/jeep/ Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 11, 2013 Share Posted July 11, 2013 The Addco rear sway bar is 1.125" diameter... I have one. My only thoughts on this are to not crank them down too tightly on the ends or it will act like more like a spring instead of a sway bar, and that the mounts to the axle should really have a more secure method of attachment instead of u-bolts [i have had to re-tighten them twice and had to order a replacement part when I lost one on the road]. Other than than that, the sway bar rocks. Are you referring to the MJ rear sway bar? The MJ ADDCO front bar is 1-1/8" dia.; the rear is 7/8" dia. http://www.addco.net/aftermarket/catalog/jeep/ You're right- had em written down side-by-side and posted the wrong dimensions. Link to comment Share on other sites More sharing options...
Rebelfish99 Posted July 21, 2013 Author Share Posted July 21, 2013 Hey, sorry on the late replies. Work has been hell this month. Here are some inside pics, its not set up right now. Link to comment Share on other sites More sharing options...
Rebelfish99 Posted July 21, 2013 Author Share Posted July 21, 2013 Cool! Looks good on the jeep! Very roomy on the inside? I'm 6'5" and I can stand up and just barely scrape my head. Link to comment Share on other sites More sharing options...
