skerriltj Posted May 12, 2013 Share Posted May 12, 2013 Just picked up the rough country 6.5" lift kit for my 89 pioneer. I'm thinking 33X12.50R15LT Dick Cepek Crushers for tires. Anyone have any comments/suggestions?? Also, should I invest in some wheel spacers? The rims are currently stock rims. I will be upgrading to beadlockers eventually though. Thanks! Link to comment Share on other sites More sharing options...
Eagle Posted May 13, 2013 Share Posted May 13, 2013 You won't run 12-1/2" wide tires on stock rims without spacers. 31x10.50s on factory rims leave VERY little clearance between the sidewalls and the rear springs, and when the rear axle gets at all crossed up the inner sidewall at the top rubs the inner fender well. 12.50s will be an interference fit. Link to comment Share on other sites More sharing options...
87manche1 Posted May 13, 2013 Share Posted May 13, 2013 I like skinny tire sizes like 32x10.5. ran 285/75/16s mt for awhile and hated them. Liked the firestone mt good tread wear longer life and threw some mud. Ejection out of the tread is to me essential if it gets packed in What's the point Link to comment Share on other sites More sharing options...
Pete M Posted May 13, 2013 Share Posted May 13, 2013 what are you doing for gearing? Link to comment Share on other sites More sharing options...
skerriltj Posted May 13, 2013 Author Share Posted May 13, 2013 I was thinking of skinnier....10.5 but I think my heart is set on the crushers which only have 31s in 10.5. The reviews seem pretty good and i'm 90% wheeling the mj. Gearing........well not too sure yet. I'm just trying to get things in place and bought. Gearing is the next thing to figure out. Complete newbie here! Anyone have preferences for good wheel spacers? Link to comment Share on other sites More sharing options...
mnkyboy Posted May 13, 2013 Share Posted May 13, 2013 Spidertraxs spacers are good, just make sure you buy something hub centric and anodized. Don't buy cheap spacers no matter how tempting the price is. For the cost of quality spacers you could probably pick up a set of aftermarket steel wheels with a better offset. Darren here on CC had the crushers on an XJ, IIRC he liked them. Link to comment Share on other sites More sharing options...
skerriltj Posted May 13, 2013 Author Share Posted May 13, 2013 After more reading and chatting with fellow wheelers i'm thinking maybe it's just as easy to suck it up and buy beadlockers sooner than later that have backspacing. It'll save me buying the spacers. Any thoughts?? Link to comment Share on other sites More sharing options...
mvusse Posted May 13, 2013 Share Posted May 13, 2013 I have run 33x12.50R15 tires with ~6.5" lift on 15x8 wheels with 4" backspacing. That combination seems to work well. Link to comment Share on other sites More sharing options...
dave92cherokee Posted May 13, 2013 Share Posted May 13, 2013 If it's going to be a mostly offroad rig you can always get a set of LTB's. They have 34x10.50-15's that would fit without much trouble, ran them on an old xj with 4.5" lift and only rubbed the front at almost full lock. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted May 13, 2013 Share Posted May 13, 2013 eBay sells spacers for like 50-60 bucks that's where I got mine from Link to comment Share on other sites More sharing options...
TylerJY Posted May 13, 2013 Share Posted May 13, 2013 I like KM2's myself, our Suburban has the Wrangler MT/R's and my dads XJ had super swampers, i like the km2s the most and will be purchasing another set. Link to comment Share on other sites More sharing options...
skerriltj Posted May 14, 2013 Author Share Posted May 14, 2013 Thanks for everyone's input!! Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2013 Share Posted May 14, 2013 eBay sells spacers for like 50-60 bucks that's where I got mine from Are they hub centric and anodized? If not I would toss them in the trash. Cheap spacers are unsafe and the reason spacers get a bad rap. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2013 Share Posted May 14, 2013 Spidertrax hub centric spacers. Ebay garbage. You can see they are lug centric rather then hub centric which is not safe. Link to comment Share on other sites More sharing options...
gogmorgo Posted May 14, 2013 Share Posted May 14, 2013 What's so bad about lug centric spacers? It works fine for wheels. But yeah, generally cheap ebay stuff in the drivetrain or suspension is unsafe. Also, to the OP, 12.5's may be a bit wide for stock rims, which are 15x7. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2013 Share Posted May 14, 2013 http://tires.about.com/od/understanding_wheels/a/hub-centric-vs-lug-centric-wheels.htm Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2013 Share Posted May 14, 2013 eBay sells spacers for like 50-60 bucks that's where I got mine from Are they hub centric and anodized? If not I would toss them in the trash. Cheap spacers are unsafe and the reason spacers get a bad rap. I would quantify that reply with this: those spacers are definitely only trash worthy, but trash them in your aluminum trash pile along with the beer cans. Might as well get a couple of recycle bucks for them. Also, the Spidertrax spacers are both hub centric and wheel centric. :thumbsup: Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2013 Share Posted May 14, 2013 Good point, its important to recycle. Not only is it good for the planet but it gives the inferior part a second chance at being turned into something useful. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted May 14, 2013 Share Posted May 14, 2013 How are they bad? Break? Link to comment Share on other sites More sharing options...
CoryMJ89 Posted May 14, 2013 Share Posted May 14, 2013 I've put a good lickin on mine and they hold up Link to comment Share on other sites More sharing options...
mnkyboy Posted May 14, 2013 Share Posted May 14, 2013 Problem is that the lug nuts/stubs job is to hold the wheel on,not support the entire rig. Every time you hit a bump you are sending the impact into the side of the lug studs,this can cause the lug studs or the spacer itself to fail. You will also find cheap spacers are not anodized. Raw aluminum will rot over time weakening the part which can lead to failure. Link to comment Share on other sites More sharing options...
skerriltj Posted May 14, 2013 Author Share Posted May 14, 2013 Has anyone run trailready or allied beadlock wheels? Anyone else run something of good quality that are decently priced?? Need something that has at least 3.75 backspacing too. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted May 15, 2013 Share Posted May 15, 2013 Oh we'll my wheels are hub centric lol so guess I'm just risking it lol Link to comment Share on other sites More sharing options...
