Backdraft Posted February 2, 2013 Share Posted February 2, 2013 I'm looking for opinions on aftermarket adjustable track bars. Thinking about ditching the one I have and going with something different. So what do you guys like? What do you prefer? What have you run successfully? And why? Thanks! Link to comment Share on other sites More sharing options...
danbyrambler Posted February 2, 2013 Share Posted February 2, 2013 What lift? Link to comment Share on other sites More sharing options...
Backdraft Posted February 2, 2013 Author Share Posted February 2, 2013 6.5 inches Link to comment Share on other sites More sharing options...
Dirteatr717 Posted February 2, 2013 Share Posted February 2, 2013 Check out the rockkrawler bombproof one, my friend has it on his XJ and has no complaints. I have the rustys HD bar and bracket and it works fine for me Link to comment Share on other sites More sharing options...
SW86 Posted February 2, 2013 Share Posted February 2, 2013 x2 on the RK bomb proof. ive ran it for about two years now (6.5 lift) with zero issues. its made from solid steel unlike hollow tube ones. it comes with a new drop bracket thats beefy as hell and all the bolts of course. you have to drill out the axle side for the bigger bolt to fit but thats no biggie. just remember to lock tight those bolts! and i mean every one on there Link to comment Share on other sites More sharing options...
Alexia Posted February 2, 2013 Share Posted February 2, 2013 Iron Rock Offroad Double Shear Track Bar - Strong, comes with the drop bracket, solid steel, and the cheapest at $190. I just installed this a few nights ago and I am impressed with the quality of the product for it being the one of the cheapest track bars available. http://ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=IR-STBCK&Category_Code=PFX Link to comment Share on other sites More sharing options...
ComancheKid45 Posted February 2, 2013 Share Posted February 2, 2013 Iron Rock Offroad Double Shear Track Bar - Strong, comes with the drop bracket, solid steel, and the cheapest at $190. I just installed this a few nights ago and I am impressed with the quality of the product for it being the one of the cheapest track bars available. http://ironrockoffro...tegory_Code=PFX x2 :thumbsup: Link to comment Share on other sites More sharing options...
Comanche County Posted February 2, 2013 Share Posted February 2, 2013 Both are probably fine, but there's a couple of differences. The IRO uses rubber bushings at both ends. It would be fine but it would allow for more side to side sway than either a stock bar or the RK bar which uses a Hiem Joint at the frame end. Also the IRO mount lowers the frame end of the track bar 3/4" according to their site. RK's website doesn't say anything about lowering the frame mounting point. Anyway, since you've got everything UTK in a stock configuration, you'd need a ZJ ptiman arm if you decide to go with the IRO bar. With the RK arm, you'll be replacing the hiem every year or so. When I called them about replacing my worn out hiem, they didn't offer to warranty it as their life time "bomb proof" warranty states. I paid for another one anyway. Link to comment Share on other sites More sharing options...
mvusse Posted February 3, 2013 Share Posted February 3, 2013 Iron Rock Offroad Double Shear Track Bar - Strong, comes with the drop bracket, solid steel, and the cheapest at $190. I just installed this a few nights ago and I am impressed with the quality of the product for it being the one of the cheapest track bars available. http://ironrockoffro...tegory_Code=PFX NO! I bought one for Sparkles. IIRC the lower end uses a 7/16" bolt, which is a bit larger than the stock 10mm one. This is good. Drill out the hole to the correct size, and if it had been wallowed out that will be fixed at the same time, BUT The upper end uses a 12mm bolt, but the holes in the bracket are 13mm. This allows the upper end to move around. NOT GOOD! I drilled out the 12mm bushing to 1/2" and used a 1/2" bolt to partly fix this (can still move around some, but only about half as much as the 12mm one), and am debating on going to 9/16" or 14mm. Both of which require redrilling the bracket which requires taking it off the truck again. Not looking forward to that. Link to comment Share on other sites More sharing options...
foreman1063 Posted February 3, 2013 Share Posted February 3, 2013 Check out these as well. Link to comment Share on other sites More sharing options...
MtnClimber Posted February 3, 2013 Share Posted February 3, 2013 foreman, I couldn't get the link to work :hmm: Link to comment Share on other sites More sharing options...
Alexia Posted February 3, 2013 Share Posted February 3, 2013 NO! I bought one for Sparkles. IIRC the lower end uses a 7/16" bolt, which is a bit larger than the stock 10mm one. This is good. Drill out the hole to the correct size, and if it had been wallowed out that will be fixed at the same time, BUT The upper end uses a 12mm bolt, but the holes in the bracket are 13mm. This allows the upper end to move around. NOT GOOD! I drilled out the 12mm bushing to 1/2" and used a 1/2" bolt to partly fix this (can still move around some, but only about half as much as the 12mm one), and am debating on going to 9/16" or 14mm. Both of which require redrilling the bracket which requires taking it off the truck again. Not looking forward to that. The 7/16" bolt fits perfectly into the D30 I tossed underneath from a 1997 XJ. The 12mm bolt fit nicely into the bracket without wobbling. Link to comment Share on other sites More sharing options...
foreman1063 Posted February 3, 2013 Share Posted February 3, 2013 foreman, I couldn't get the link to work :hmm: Hmm, works for me but try this. http://www.ironman4x4fab.com/Products/TB.html Link to comment Share on other sites More sharing options...
