Pete M Posted January 15, 2013 Share Posted January 15, 2013 get your 2wd rear shaft shortened. :thumbsup: should be under 100 bucks. Link to comment Share on other sites More sharing options...
mvusse Posted January 15, 2013 Share Posted January 15, 2013 My son and I are attepting to convert 88 mj 2x4 manual to 4x4 manual. Best parts vehicle we have found so far is a 91, 4 door cherekee. The only major difference so far is the wheel base on the cherekee is approx 12" shorter than the mj. Anyone have any thoughts or ideas that could make tranision as painless as possible? That will be the best donor you can find. Use everything from the Cherokee except the rear driveshaft. Have your current 2wd rear driveshaft shortened to fit with the transfer case. Park them side by side, take something off the Cherokee, put it on the Comanche. You will have to remove the seats and carpet to get to the bolt holes holding the shifter linkage bracket to the inside driver side of the tunnel. Link to comment Share on other sites More sharing options...
chappy88 Posted January 16, 2013 Share Posted January 16, 2013 Hey guys Just starting to convert manual mj 2x4 to 4x4 . Found a 91 manual xj as donor, any thoughts on how this may all turn out? Not sure if original rear axle is compatible? I do know the rear driveshaft will have to be altered. Link to comment Share on other sites More sharing options...
chappy88 Posted January 16, 2013 Share Posted January 16, 2013 oops newbie! :doh: Scoll all the way ! thanks Mvusse, Looking forward to starting! Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted March 5, 2015 Share Posted March 5, 2015 My conversion went great, but make sure you get a decent vaccuum harness for the front disconnect axle. I snap those stupid hoses every time I mess with my transfer case, but they're easily repaired. Theres a sweet replacement cable that you pull from inside the cab made by AlloyUSA for about $160 to solve the vaccuum harness crap, if you have $160. Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted March 5, 2015 Share Posted March 5, 2015 My conversion went great, but make sure you get a decent vaccuum harness for the front disconnect axle. I snap those stupid hoses every time I mess with my transfer case, but they're easily repaired. Theres a sweet replacement cable that you pull from inside the cab made by AlloyUSA for about $160 to solve the vaccuum harness crap, if you have $160. Sorry if this has already been answered, but I'm new here. How can you lock this in place? Link to comment Share on other sites More sharing options...
87MJTIM Posted March 5, 2015 Share Posted March 5, 2015 I am guessing you mean the CAD bypass. http://comancheclub.com/topic/17377-cad-fix-1/ In the DIY section. Link to comment Share on other sites More sharing options...
Futurecomancheowner Posted March 5, 2015 Share Posted March 5, 2015 I am guessing you mean the CAD bypass.http://comancheclub.com/topic/17377-cad-fix-1/In the DIY section.yes, that's what I meant, thank you. I'm going to attempt a conversion using a 92 cherokee as a donor, will I have to worry about the CAD? Link to comment Share on other sites More sharing options...
87MJTIM Posted March 5, 2015 Share Posted March 5, 2015 Not at all. It is a 10 minute procedure. Besure to have a pan to collect the oil that WILL drip out. Get some gear oil to top off the diff. Link to comment Share on other sites More sharing options...
Incommando Posted March 5, 2015 Share Posted March 5, 2015 Well the '92 won't be CAD IIRC. No need to screw with it at all Link to comment Share on other sites More sharing options...
87MJTIM Posted March 5, 2015 Share Posted March 5, 2015 I think Jeep changed from CAD to one piece in 96. All MJs have the CAD. Link to comment Share on other sites More sharing options...
ggcnash Posted March 5, 2015 Share Posted March 5, 2015 I think Jeep changed from CAD to one piece in 96. All MJs have the CAD.Incommando is correct it was 91-92 some 91's didn't have change year Link to comment Share on other sites More sharing options...
Incommando Posted March 5, 2015 Share Posted March 5, 2015 I think Jeep changed from CAD to one piece in 96. All MJs have the CAD.Incommando is correct it was 91-92 some 91's didn't have change year The YJ changed in '95. The XJ/MJ in '91. The '91's do not have CAD although reportedly some early ones did. Most '91s and all '92's were CAD -free Link to comment Share on other sites More sharing options...
87MJTIM Posted March 5, 2015 Share Posted March 5, 2015 Learned something new today. Link to comment Share on other sites More sharing options...
gogmorgo Posted March 5, 2015 Share Posted March 5, 2015 My January 22nd build '91 had a CAD. Don't know if that's early, though, if the model year change is in the summer. Link to comment Share on other sites More sharing options...
Incommando Posted March 5, 2015 Share Posted March 5, 2015 My January 22nd build '91 had a CAD. Don't know if that's early, though, if the model year change is in the summer. For the '91 I am going on what I read here as I have not personally seen a factory '91 4wd. Mine is converted. I do know that '92 was fo' sho' CAD-free as I knew someone who bought one new and kept it until 2010. Link to comment Share on other sites More sharing options...
ggcnash Posted March 5, 2015 Share Posted March 5, 2015 Yep, they were mixed in 91 but the 91 FSM shows non cad and I have a 91 XJ donor that is non cad all original,but have seen some cases like yours have vacuum disco but they are fewer than their counterpart. Link to comment Share on other sites More sharing options...
Boilermaker Posted March 5, 2015 Share Posted March 5, 2015 My January 22nd build '91 had a CAD. Don't know if that's early, though, if the model year change is in the summer. It also could have been swapped in by a previous owner. My 92 had a CAD when i bought it. I know it was swapped in by a previous owner because my truck came off the assembly line as a 2WD according to the build sheet. Link to comment Share on other sites More sharing options...
gogmorgo Posted March 6, 2015 Share Posted March 6, 2015 Got my build sheet from Chrysler, it was 4x4 its whole life. The axle looks original and I have no reason to suspect otherwise, and the truck was and still is almost completely stock, but it did have 290,000 miles when I got it, so it's always possible. Link to comment Share on other sites More sharing options...
