Just picked this up from Vegas last week. My daughters new Comanche project 2wd converting to 4wd and swapping out the trans for a AX-15 for reliability. The rear is a D35 so that's going to be replaced by a 8.25" and a D30 for the front. Our goal is 90% used parts and to keep the total cost under $5K.
Build
4wd
8.25 rear axle
D30 Front
35's
4.5"" lift
Fiberglass Front Fenders
Pulled Rear Fenders
In Cab cage
Synergy Suspension LA Front
king 12" Reservoir Shocks
Deaver Long Travel Rear Spings
Bed Cage
Bumpers
LED Lights
Goal Under $5k
Current Cost
Truck:$600
Transport:$350
Radiator Fan shroud:$35
Shifter knob:$25
Shifter Boot:$25
Door Handle:$25
Ax-15 Trans W/Tcase $300
Front Bumper:$640
Centerforce II Clutch $385
Misc Trans parts:$100
Drive shaft Yoke $30
U joints $35
Chop and Bal rear shaft $75
External Slave Cylinder $180
Synergy front 4.5 Springs $185
Synergy Trac Bar $225
Synergy Short Lower CA $275
Air Horn $40
35" BFG Tires CL:$600
15" Method race Wheels:$480
Day Star Products Add a leafs:$75
Pulled Bed Sides:$10
C-Rok $68 Shipped
Spedo Cable $27
Steering Box $168
Total Cost:$3693.00
Sold Transmission -$100
Total Cost $3593
Removed the old transmission Sunday that was fun at 102*
Finally getting some parts Centerforce II clutch and everything we need to get this installed this weekend.
Finally making progress!
Repainting front grill etc
Installed new Orfab front bumper,trimmed front fenders and est where it will sit with lift.
Installing Synergy 4.5" Progressive front coils, On order tracbar and lower control arms
Synergy 4.5" Front Coils and painted the grill black
Synergy Suspension lower control arms. We like the oem bushing and the Johnny joint on the opposing side completely rebuildable.
Scored a set of low mileage 35" BFG's on craiglist! Probably need to lift the rear more!
Drove it to work today lots of little things to work on. We will be installing the Day Star Add a leaf to the rear in the next week should give us a 2" lift.
Wolo Air Horns
After rear Day Star Add A Leafs
Pulled rear bed sides with 35" tires no cutting
Pulled bed sides with 31" tires
  • 6 months later...
**Update
Added C-ROK Steering box plate and a new steering box
Cut and moved the front fenders up nearly 2" trimmed back about 4"
Your grille is upside down :) (surprised no one else has said anything). Truck looks good. Mine is also from Vegas.
Looking good so far! I like the LCOG builds the best. And I'm not sure what it is, but every MJ I see outside of the forum has the grille upside down, including the one I just purchased. MJ owners lol
RockMJ
RockMJ
Hey! It's very confusing! :rotf:
Looking good. How did you pull the bed sides out?
Cut the inside edge about 3" from the pinch weld and weld or bolt in tabs to keep them pushed out. I had a 1988 Ford Ranger Pre-runner years ago very common with those.
Here's a good site for the how too
Jason
Never seen this either but it came out great. Keep up the good work! :thumbsup:
Its not finished but are Jeeps ever? Its not my Jeep so who knows maybe it will never get done?  Thanks guys for the kind words, maybe we can get some trail pics after the 4wd gets finished up.
Jason
  • 1 month later...
