fiatslug87 Posted September 21, 2012 Posted September 21, 2012 The search keeps deleting some of my terms, my apologies as I'm sure this has been asked. How much lift is required to fit 32x10 tires on a SWB 4x4 MJ? What vendors do you recommend? Thanks
Alexia Posted September 21, 2012 Posted September 21, 2012 Five to six inches of lift to be able to make them fit nicely without having to worry about cutting metal at all.
Eagle Posted September 21, 2012 Posted September 21, 2012 First, what wheels do you plan to use? Factory Jeep rims, or aftermarket? If aftermarket, how much backspacing? It makes a difference. Also, do you plan to -- or are you willing to -- remove the flares and cut the sheetmetal, or do you want to keep the body intact?
88whitemanche Posted September 21, 2012 Posted September 21, 2012 Hmmm good question eagle....i have a rough country 3inch lift without adjustable control arms and I have the 32x11.5x15 bfg all terrains with mickey thompson 15x8s and they stick out alot but just rub at tight turns on the rear end.of the front fenders bothers me a bit but plan to cut a little bit of the fender....but I put the newer front end and they look so good I'm thinking twice about cutting and just add more lift
Incommando Posted September 21, 2012 Posted September 21, 2012 4" lift with 32x11.5x15 tires on factory Gambler rims. No rubbing or trimming need and it was used fairly hard off-road.
jeepdoggydogB Posted September 21, 2012 Posted September 21, 2012 Mike, I have the 3.5 inch Rubicon Express Springs for the front and the Hellcreek MT 3 inch lift in mine. It sits pretty level and based on the measurements I have closer to 4.5 inches of lift. I currently have 31 inch tires with the rancho LCA's and I think I could fit 32's with my current setup. You can stop by and check it out if you want. Just out of curiosity what made you consider lifting your truck?
fiatslug87 Posted September 21, 2012 Author Posted September 21, 2012 Eagle: Thinking of 17" Moab wheels (5x5 bolt pattern) with adapters. Do not want to trim or remove anything, I like the stock flares. Joe: Lift is just for kicks, my brother has this extra set of wheels, need something to do, etc. I'm just in the exploratory phase, may not come to fruition but probably greater than 50% chance it will.
xjrev10 Posted September 25, 2012 Posted September 25, 2012 TJ Moabs with 32s on 3 in. Bad pic, hasn't been out of the garage yet. :(
mvusse Posted September 25, 2012 Posted September 25, 2012 My daughter's Cherokee runs 265/75R16 tires (~32x10.50) on 16" Jeep Liberty wheels with ~4" lift. works okay, but still needs new track bar installed as well as longer control arms. Passenger front tire makes contact with the rear of the wheel opening when hitting a bump on a right hand turn.
