xjrev10 Posted August 11, 2014 Author Share Posted August 11, 2014 Empty Post Link to comment Share on other sites More sharing options...
8valvehero Posted August 11, 2014 Share Posted August 11, 2014 Wow I can't recall the last time I saw a can of Mich Golden Light. Cheers and good work! Link to comment Share on other sites More sharing options...
xjrev10 Posted August 12, 2014 Author Share Posted August 12, 2014 Wow I can't recall the last time I saw a can of Mich Golden Light. Cheers and good work!Midwest/Great Lakes beer only. I have only seen it in MN, WI, ND, and UP. It does the job. I got the ARB fixed in the rear axle today, and the gears set up again by a more experienced Jeeper. That was the big hold up in the project. Now to find time to work on the thing! Have a wheeling event this weekend. Hopefully next week I can get a day to work! Link to comment Share on other sites More sharing options...
RochesterMJ Posted August 12, 2014 Share Posted August 12, 2014 Those JK Rubicons look good Link to comment Share on other sites More sharing options...
xjrev10 Posted August 12, 2014 Author Share Posted August 12, 2014 Those JK Rubicons look good And they are a dime a dozen. Usually cheaper then TJ Moab wheels.... Link to comment Share on other sites More sharing options...
neohic Posted August 13, 2014 Share Posted August 13, 2014 Looking good, man! Link to comment Share on other sites More sharing options...
xjrev10 Posted December 24, 2014 Author Share Posted December 24, 2014 Empty Post Link to comment Share on other sites More sharing options...
xjrev10 Posted December 24, 2014 Author Share Posted December 24, 2014 These next photos where taken just after my big transmission debacle. When I swapped in the AX15, I bought all clutch parts for a 97 XJ. Flywheel too. Well wouldn't you know... The truck wouldn't start.. Dummy. In the meantime I discover nasty white oil and a ball bearing ball stuck to the drain plug in the ax15. Not a happy time... So I went on a hunt for a different trans and ordered a correct Renix flywheel. I lucked out and found a nv3550 out of a 00 TJ to use. So now that's installed. Also had a custom rear shaft built by Driveline Specialties in Duluth, MN. Rustys Offroad HD x member and a Daystar 1.5" drop trans mount Driveshaft and IRO HNT SYE installed. Curious why they didn't use a CV end at the driveshaft shop.... They knew the application, intended use.. Hopefully I don't have any issues. Trimmed the fenders the standard way. Cut and fold in the rear and just cutting in the front removing the factory inner fenders. I tried to figure out a way to reuse the stock inner fenders but to no avail. So I went shopping for some swim noodles at the end of November in MN. As luck would have it, I found some. Painted and glued in with construction adhesive. I also used the same adhesive on the rear fenders where I folded the material over. Keeps the tabs where they are supposed to be and also keeping the dirt out from behind them promoting rust. Rear Working on wrapping up some of the last things to get the truck on the road. I've had rear lighting issues since I've owned this truck.. Found this mess in the fuse box. Link to comment Share on other sites More sharing options...
neohic Posted December 24, 2014 Share Posted December 24, 2014 Damn good looking MJ. :thumbsup: Still my favorite rear bumper. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 24, 2014 Author Share Posted December 24, 2014 Damn good looking MJ. :thumbsup: Still my favorite rear bumper. It's not coming off till it gives me a reason to take it off I think.... Link to comment Share on other sites More sharing options...
88whitemanche Posted December 29, 2014 Share Posted December 29, 2014 Great build man! I wanted to ask if you have any pics to the clearance of the trans tunnel? Or did you have to do any modding? Also, did you keep the wrangler clocking with the transfer case or did you reclock? Link to comment Share on other sites More sharing options...
Dillithium Posted December 30, 2014 Share Posted December 30, 2014 That's still a great looking front bumper, the rear too! Link to comment Share on other sites More sharing options...
xjrev10 Posted December 30, 2014 Author Share Posted December 30, 2014 Great build man! I wanted to ask if you have any pics to the clearance of the trans tunnel? Or did you have to do any modding? Also, did you keep the wrangler clocking with the transfer case or did you reclock? Yes. Being the clocking is different on the wrangler transmission, the tunnel took a little modification. With a hammer. Not a big deal at all. No picture taking needed. Just beat the metal till it's clearanced. No rocket science! The seat was a b*@$£ it get back in after but I made do. The t case clocked up is better then down! Link to comment Share on other sites More sharing options...
xjrev10 Posted December 30, 2014 Author Share Posted December 30, 2014 After re reading some things I wrote, don't mind the little errors in the text. Typing on a iPad is different then a computer. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 31, 2014 Share Posted December 31, 2014 Great build man! I wanted to ask if you have any pics to the clearance of the trans tunnel? Or did you have to do any modding? Also, did you keep the wrangler clocking with the transfer case or did you reclock? Yes. Being the clocking is different on the wrangler transmission, the tunnel took a little modification. With a hammer. Not a big deal at all. No picture taking needed. Just beat the metal till it's clearanced. No rocket science! The seat was a b*@$£ it get back in after but I made do. The t case clocked up is better then down!Your right about that! But how are we talking for the hammering? A lot? Sorry...I just don't want to do a lot of something that idk what I'm doing....you know... Link to comment Share on other sites More sharing options...
xjrev10 Posted January 1, 2015 Author Share Posted January 1, 2015 Ok. Here's how I'll tell you. I let a friend of mine use the hammer on MY jeep. That's how simple it is. Link to comment Share on other sites More sharing options...
88whitemanche Posted January 1, 2015 Share Posted January 1, 2015 Ouch! Sorry I barely trust my friends with MY jeep.... Lol Link to comment Share on other sites More sharing options...
xjrev10 Posted January 1, 2015 Author Share Posted January 1, 2015 I feel the same way. Now you get my point! Link to comment Share on other sites More sharing options...
xjrev10 Posted January 18, 2015 Author Share Posted January 18, 2015 Finish interior Fix tailight wiring Rock rails ............................3 items left of the 'done' list Link to comment Share on other sites More sharing options...
earl*t Posted January 18, 2015 Share Posted January 18, 2015 Not build related, but I have to ask. Are those your donuts in the parking lot? Link to comment Share on other sites More sharing options...
xjrev10 Posted January 20, 2015 Author Share Posted January 20, 2015 Of course. Haha! Link to comment Share on other sites More sharing options...
USAFAGumby Posted February 6, 2015 Share Posted February 6, 2015 Just read through the whole thing, love the project! I keep seeing parts and swaps I really want to do. I'm looking at the CrownHD steering right now. Congrats on MJ of the month too! Link to comment Share on other sites More sharing options...
xjrev10 Posted February 9, 2015 Author Share Posted February 9, 2015 Just read through the whole thing, love the project! I keep seeing parts and swaps I really want to do. I'm looking at the CrownHD steering right now. Congrats on MJ of the month too! Ha! I posted in your build about the Crown steering. Best price I found was 4wheelparts of all places. (When I bought mine) Lots has happened but I'm waiting for more to happen then I'll update. Gonna be a big week hopefully! Link to comment Share on other sites More sharing options...
