90pioneerlove Posted February 22, 2011 Share Posted February 22, 2011 your install looks great, i picked up the lights today ill post pics when alls done. Link to comment Share on other sites More sharing options...
Automan2164 Posted February 22, 2011 Share Posted February 22, 2011 I will always recommend the euramatec lights. Rob L. Link to comment Share on other sites More sharing options...
90pioneerlove Posted February 28, 2011 Share Posted February 28, 2011 put them in last weekend look and work perfect Link to comment Share on other sites More sharing options...
SubSonic Posted February 28, 2011 Share Posted February 28, 2011 Well, here in Dallas, there is no such thing as Advance Auto Parts :eek: ... so, does anyone know what the Chrysler OEM Part# is for these assemblies is? I'm having one hell of a time even finding the OEM part listed anywhere...which is probably why everyone is replacing them with an after market assembly... Link to comment Share on other sites More sharing options...
acfortier Posted February 28, 2011 Share Posted February 28, 2011 I picked up the ones from Euramtec on eBay, and they look nice! Installed them today, finally I have light in my truck! :clapping: Link to comment Share on other sites More sharing options...
Zenobian_84 Posted June 4, 2011 Share Posted June 4, 2011 Hey all, I'm new to the site, and felt like adding my own 2 cents worth of input. I tried BLHTAZ's interior light suggestion and I have to say that it works pretty darn well! It's a lot better than trying to start the truck and having to deal with finding the key cylinder in the dark. Very nice writeup BLHTAZ. :cheers: Link to comment Share on other sites More sharing options...
shawn Posted August 10, 2011 Share Posted August 10, 2011 Just thought I'd add to this, because it is an awesome thread that a lot of us did not know about. Below is a pic of the ashtray light, i.e. w/the blue cover. In addition, while i had the dash apart, i noticed there is a light that clips on to the cig lighter. it lights up a green glow ring around the lighter on the dash and also shines down in to the lighter socket to illuminate that. i noticed its the same assembly as the ashtray light, just a different end on it. and since i had just replaced the ashtray light, luck me, they came in a 2 pack, so now i'm just about all lit up. i still need to figure out the hvac light and i will have gone from completely dark at purchase in sept. to fully lit now. Sorry for the bad res on this pic, at night w/camera phone. I detached it from the lighter socket to show a little better. by the way, the bulb part # for the ashtray is an 1891, and for the kick panel lights is a 194. I'm guessing that ashtray light must be on a different circuit in order to work as intended. that would make a huge difference for me - I'm chronic. Link to comment Share on other sites More sharing options...
relyt120 Posted August 26, 2011 Share Posted August 26, 2011 :doh: I should have read this before I tried to do mine, it was very frustrating the way I was doing it....well I got one side in the hard way time to take the easy way out for the other. :D Link to comment Share on other sites More sharing options...
Shharks Posted September 27, 2011 Share Posted September 27, 2011 I found this place on line. Looks more like the original for interior lighting http://www.euramtec.com/parts/c/c01/7180.html :wrench: Link to comment Share on other sites More sharing options...
lexluthier72 Posted September 30, 2011 Share Posted September 30, 2011 For those that have done the footwell light mod....The drivers side only comes on when you turn the headlights on, and stays on (until you turn headlights off).....Is this correct function? Is there a way to make it go on/off with the door opening without splicing in to the passenger side light? -E. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 1, 2011 Share Posted October 1, 2011 That's how they are suppossed to work; ON when you open the door. Check to see if your headlight switch is rotated all the way ccw or cw into the stops. This turns on the interior lights w. the headlamps on. Link to comment Share on other sites More sharing options...
lexluthier72 Posted October 2, 2011 Share Posted October 2, 2011 The drivers side footwell light comes on when you pull out on the headlight switch. Rotating the switch to turn on/off the interior lights does NOT turn off the drivers side footwell. It stays on as long as the headlight switch is pulled out. -E. Link to comment Share on other sites More sharing options...
hokie83 Posted November 9, 2011 Share Posted November 9, 2011 I installed the euramatec lights last nihgt, and they look great! The drivers side is working exactly as I would expect. It comes on when either door opens, or if I turn the dimmer switch to the far left, or if I "toggle" the light itself However, the passenger's side stays on all the time. The only way to turn it off is to unplug it from the harness. Help ! any ideas why this would be happening? Link to comment Share on other sites More sharing options...
hokie83 Posted November 9, 2011 Share Posted November 9, 2011 One more note (and I'll test this when I get my next opportunity). I'm thinking that the positive lead (red wire) to the interior lights must be hot all the time. It would be a combination of the other 2 black wires that would complete the circuit and turn the light on. The door switch, dash dimming switch, and "toggle" mechanism in the light must all work to complete one of the black wire circuits. I'm thinking that one of my black wires is somehow grounded out to the truck, prior to reaching the switch mechanism... causing it to be a completed circuit at all times I'll post back what I find. Link to comment Share on other sites More sharing options...
hokie83 Posted November 10, 2011 Share Posted November 10, 2011 OK - I found the issue. The DOOR JAMB SWITCH on the passengers side was mangled to the point that it was shorting out. A quick trip to Advance Auto Parts and $6.50 later... and the lights are working correctly. (that's 3.25 per new switch. I replaced the driver's side while I was at it) Here are to pics of the Euramatec lights installed: Link to comment Share on other sites More sharing options...
Automan2164 Posted November 10, 2011 Share Posted November 10, 2011 Every time I see those Euramatec lights I think to myself "That's what should have came stock." They look great. Rob :cheers: Link to comment Share on other sites More sharing options...
DubbyDoo Posted July 25, 2012 Share Posted July 25, 2012 trying to find these lights and i can't any help? Link to comment Share on other sites More sharing options...
relyt120 Posted July 25, 2012 Share Posted July 25, 2012 which ones are you looking for? here's one on ebay: http://www.ebay.com/itm/Jeep-Comanche-8 ... 86&vxp=mtr i got mine from advance but they are stationary Link to comment Share on other sites More sharing options...
DubbyDoo Posted July 25, 2012 Share Posted July 25, 2012 id like to get the aftermarket ones but i couldnt find them on the advance website Link to comment Share on other sites More sharing options...
