What Would You Change About Your Comanche?
Topic as it says.
What are two major things, and three minor things you would change about your Comanche?
I.E. Major: Engine, aspiration, transmission, body, etc.
I.E. Minor: Headlights, interior, exterior (paint, bumpers, etc.), wheels.
Ready and go!
Major: Don't make them anymore, Extended Cab
Minor: Black interior, hidden winch, electric lockers.
All of this should be factory.
Rob :dunno:
I think for the major part of it would be rebuilding the engine/swapping out for a later model longblock. Not that it needs it, but once it's done, it'll last another 150,000 easy...and have it's power back, if it had it at all.
Secondly, put in a 5 speed transmission instead of the 4 speed.
Minor stuff. New windshield as it's all cracked to hell, door latch for the driver's side because it doesn't close fully, and tires. That'd about do it.
Body's too far gone to worry about it anymore. :dunno:
Rust!!! Axles internals, shafts, lockers and probably 4.56s :D
Working radio, nice paint and new master cylinder and clutch pedal assembly, mine leaks and all the bushings are shot :roll:
Major:
rebuild the 4.0 so it gives me another 200,000 (odometer reads about 220,000)
fix all body work such as rust and dents and get it painted
Minor:
Clean interior, new tires, pass inspection :fs2:
Have you seen my build threads? :hmm:
I change everything!
Including owners!
Buuuuut, I am just as bad.
Rob :peek:
Major: NOT be sick for the past year or so and have mine done! Extended cab/doors with a shortbox (on the '89 longbox. Once I get the parts, I have a shop to do the bodywork/welding)
major: 6 speed with a rubicrawler, frame or extended cab
minor: bed side armor (rails), door/fender alingment, rock lights
have you checked out my rock lights? i only posted in the "what you did to your MJ this week" thread. ive got 9 leds and its plenty.
Major: Bigger axles and tubed out back to make room and attachment points for a 4 link.
Minor: Redo CB antenna mount, reinstall headliner and replace passenger side floor.
