Pete M Posted November 14, 2018 Share Posted November 14, 2018 I see all of the images on the first page. Link to comment Share on other sites More sharing options...
vw jeep guy Posted April 16, 2019 Share Posted April 16, 2019 does anyone have info/ pics of doing the rear under spring mod...........I see Rusty's has a suspension lift kit to do that Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2019 Share Posted April 16, 2019 26 minutes ago, vw jeep guy said: does anyone have info/ pics of doing the rear under spring mod...........I see Rusty's has a suspension lift kit to do that a "spring over" or SOA conversion needs perches welded to the top of the axle in the appropriate location. then shock mounts will need to be welded on too. I would also replace the old ubolts too. oh, and a longer flexible brake line. Link to comment Share on other sites More sharing options...
vw jeep guy Posted April 18, 2019 Share Posted April 18, 2019 Thx Pete M for your response I should of mention, I’m using a 8.25, therefore I have all the brackets/ plates to bolt up. I’m curious about switching the leaf bolt around. I'm going with the disc brake mod with plates from a Grand Cherokee, so I’ll need to change the lines anyways. Link to comment Share on other sites More sharing options...
vw jeep guy Posted April 18, 2019 Share Posted April 18, 2019 now that I know I am looking for "SOA", a bunch of posts came up in my search. Huge amount of information...........again thx Pete M Link to comment Share on other sites More sharing options...
Oldman Posted January 7, 2020 Share Posted January 7, 2020 Very informative article. I do however have a question. It’s about all those firewall modifications. Wouldn’t it be simpler to just cut out part of the firewall form the donor Xj And mj and weld it in? Link to comment Share on other sites More sharing options...
Dzimm Posted January 7, 2020 Share Posted January 7, 2020 49 minutes ago, Oldman said: Very informative article. I do however have a question. It’s about all those firewall modifications. Wouldn’t it be simpler to just cut out part of the firewall form the donor Xj And mj and weld it in? There are a lot of different ways you can go about it, quite a few people have cut that portion of firewall from the XJ and welded it in like you describe and it could be considered the "factory" way of doing it. For mine I just cut the new holes where they needed to be and patched over the old ones. Link to comment Share on other sites More sharing options...
Oldman Posted January 7, 2020 Share Posted January 7, 2020 Thanks for the reply. I just got my Comanche so I haven’t started the conversion yet , just doing so research..I do know that the vin is stamped behind the booster and I don’t want to cut that out.hopefully it not in the way. Link to comment Share on other sites More sharing options...
JeepMitch Posted February 16, 2020 Share Posted February 16, 2020 Do you have a link of parts number to the non slosh pan tank? Link to comment Share on other sites More sharing options...
Pete M Posted February 16, 2020 Share Posted February 16, 2020 12 hours ago, JeepMitch said: Do you have a link of parts number to the non slosh pan tank? you should probably post that up as its own thread in Tech so more eyes will see it. Link to comment Share on other sites More sharing options...
Caleb S Posted February 19, 2022 Share Posted February 19, 2022 I know this thread is older but I have a question on the cab wiring. Did you keep the extra plugs on the xj harness for the back two doors? I want to get rid of them and was wondering how. I hacked mine off and haven’t finished but I realized I messed up the fuel pump wiring by doing so. Link to comment Share on other sites More sharing options...
Pete M Posted February 19, 2022 Share Posted February 19, 2022 @Backdraft Caleb, if he doesn't reply you might want to start a new thread in Tech where more eyes will see it. Link to comment Share on other sites More sharing options...
JonnyB Posted September 30, 2022 Share Posted September 30, 2022 Just to add since I am currently in the process of a 97+ swap, and a 5.3 swap. I wanted to keep a 5 speed transmission in my MJ, there is a difference in the firewall for the 5 speed and automatic. It is just a couple of holes to drill out but it is not something that I thought about before. You would need to find a 5 speed clutch and brake assembly to make this work which is getting rare. The aluminum bracket is the same however so that is good. You can see in the picture where the dimples are for the bolt holes, and also the punch out for the clutch engagement. Link to comment Share on other sites More sharing options...
JeepO Posted June 9, 2024 Share Posted June 9, 2024 Question for you, where did you place the charcoal canister? thank you! Link to comment Share on other sites More sharing options...
jeff351 Posted June 10, 2024 Share Posted June 10, 2024 On 6/8/2024 at 10:35 PM, JeepO said: Question for you, where did you place the charcoal canister? thank you! Are you referring to vapor canister from the 97+ donor? I put mine under the bed where the gas tank used to be, which physically matches the location where it was on the XJ. Lines hooked right up after that. Link to comment Share on other sites More sharing options...
