comancheman Posted January 3, 2007 Share Posted January 3, 2007 i always thought that if u counted how many times the driveshaft spins to spin the hub once was your gear ratio but when i tried this i spun the dshaft 1.5 times and the hub spun once. I'm pretty sure that 1.5 gears werent an option. any help? Link to comment Share on other sites More sharing options...
feerocknok Posted January 3, 2007 Share Posted January 3, 2007 spin the tire 20 times and count the driveshaft rotations, then divide the driveshaft rotations you got by 10. Link to comment Share on other sites More sharing options...
comancheman Posted January 3, 2007 Author Share Posted January 3, 2007 so i went and counted again i only spun the wheel once and got 1.75 rotations on the dshaft then multiplied 1.75 by 20 and divided by 10 i ended up with 3.5 i know this wasnt an available ratio. maybe sum1 knows what the ratio would be. its a 1990 4.0 auto short bed 4x4 d35 rear maybe a 3.07? Link to comment Share on other sites More sharing options...
JOMJ87 Posted January 3, 2007 Share Posted January 3, 2007 Could be 3.55 if you came up with 3.5???? Cole Link to comment Share on other sites More sharing options...
comancheman Posted January 3, 2007 Author Share Posted January 3, 2007 but i didnt think that was an available ratio. i think my math is off because i only spun it once and it doesnt compensate for all the partial turns Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 3, 2007 Share Posted January 3, 2007 3.55 was an avaliable ratio. 98% of time it's what you have if you have a 4.0/AW4. Link to comment Share on other sites More sharing options...
ejndssn Posted January 3, 2007 Share Posted January 3, 2007 get a laser level and try the calculations again this may satisfy your curiosity. Would agree with the rest of the most likely a 3.55 based on the initial findings. :brows: Link to comment Share on other sites More sharing options...
Eagle Posted January 3, 2007 Share Posted January 3, 2007 so i went and counted again i only spun the wheel once and got 1.75 rotations on the dshaft then multiplied 1.75 by 20 and divided by 10 i ended up with 3.5 i know this wasnt an available ratio. maybe sum1 knows what the ratio would be. its a 1990 4.0 auto short bed 4x4 d35 rearmaybe a 3.07? 3.55 was an available ratio, and in fact was the ONLY ratio offered with the 4.0L and automatic. Link to comment Share on other sites More sharing options...
mike Posted January 3, 2007 Share Posted January 3, 2007 you want to know for sure, take the cover off and look on the ring gear, it'll have the ratio stamped on it. :D Link to comment Share on other sites More sharing options...
comancheman Posted January 9, 2007 Author Share Posted January 9, 2007 so i pulled the cover and the number stamped on the ring gear was 335. did they mean 355? Link to comment Share on other sites More sharing options...
newbs Posted January 9, 2007 Share Posted January 9, 2007 I think 98% of the time would understatement, that was pretty much the exclusive for the auto on the manche and cheroke except for the few that got 3.73 and I am looking for a frontend with that ratio Link to comment Share on other sites More sharing options...
87manche Posted January 9, 2007 Share Posted January 9, 2007 What drivetrain is in your comanche? the basic rules are this: 2.5L 5 spd-4.10 4.0 5 spd-3.07 4.0-auto-3.55 There are some exceptions, I have a pair of 3.73 geared axles under my junk, and the 2.5L with a 4 spd got 3.55. Most likely if you've got a 4.0 and an auto it's 3.55 if you want to know for sure, take the cover back off, find all the numbers on the ring gear and then post them. Link to comment Share on other sites More sharing options...
Oizarod115 Posted January 9, 2007 Share Posted January 9, 2007 I think 98% of the time would understatement, that was pretty much the exclusive for the auto on the manche and cheroke except for the few that got 3.73 and I am looking for a frontend with that ratio looking for 3.73s, look for tow-package XJs, that was the towpackage ratio Link to comment Share on other sites More sharing options...
JOMJ87 Posted January 10, 2007 Share Posted January 10, 2007 I have a set of 3.73 I will sell. :brows: Cole Link to comment Share on other sites More sharing options...
Pete M Posted January 10, 2007 Share Posted January 10, 2007 3.73 were pretty common in Grand Cherokees. Just make sure to get one that is high pinion and running U-joints. Link to comment Share on other sites More sharing options...
