mike
    west central indiana
mike's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. hey luke87, i use to have one, it was a 86, 2.5l 2wd and it had an auto tranny. if yours is an auto then the ratio is 3.55, and yes it is a dana 35 non c-clip. you should see a flange on the outside by the wheels with 4 bolts, that is what holds the axle halves in place, unbolt the flange and the axles will slide out. hope this helps.
  2. i had the same problem, it was the booster, the diaphram inside it had split causing an air leak when i steped on the brake pedel, replaced the booster and it was fixed. you might also want to replace the vacum hose also, if it is like mine and has weather cracks it needs replced, hose is cheap compared to not having brakes and rearending someone because the hose gave out.
  3. yea i have a spare one, it has a few minor surface rust spots but they can be hit with a wire brush and paint on a rust preventer and it'll be good as new. how does $50 sound, you can have the sending unit also but you'll need a 4.0 pump as this one has a 2.5 pump and i think it's not powerful enough to make the pressure the 4.0 needs. i'll be around the rest of the week during the afternoons and evenings, across from the turkey run golf course. mike.
  4. i measured the tank i have and it's 35" long, 15" wide, 13" tall. i'm sure this is a factory one and hasn't been replaced with an aftermarket one. the 87 i have has the same size tank on it also.
  5. egg, i measured the one i have and from the outside lip down & around the small bend and to the other lip where the small fuel line connects measures around 8", so this one is probably too short also. it came out of a large tank 20 something gallon, i don't know for sure the size, but i'm sure it's the larger one that jeep made for em. maybe the tank you have is some special order one that is deeper then a stock one????
  6. egghead, i have one from an 86 it had a 2.5l so i think the pump won't make enough pressure for a 4.0l to run but the rest is probably the same. if you can take some measurements to see how long the pipe needs to be i'll check the one i have and see if it's the same. if it is make me an offer. Image Not Found i'll be around most of the next week so if it's what your needing stop on by. mike.
  7. thanks guys, this is the first paint job i've ever done myself.
  8. new paint job, all i need to do is get some orange pin striping along the sides where the black meets the silver and it'll be finished. don't be too picky on the small dents still there as this is my old beater just with a new paint job :D Image Not Found Image Not Found Image Not Found here's what it looked like before, this is the only pic i have before the new paint. Image Not Found
  9. i had an 80 cj5 almost like in mj20's pic. i replace the white soft top with a black fast back style and some bigger tires. ran the crap out of her until all the body mounts rusted through and the body shifted a little going around a corner one day :eek: ended up selling it and bought a garage package and built myself a garage to store my other toys :D
  10. i say if you like and want it then buy it, and who cares what everyone else thinks. thats what i do, of course sometimes it bites me in the a** when i get a piece of junk thinking i can fix it easy and it turns out to be a lot more work. lets see some pics if you do get it :D
  11. mike
    aquariums?
    we used to have a 75 gallon freshwater tank, but we make a big mistake when we had a noobie at the pet store tell us they had a snakehead that was on sale, well we didn't know anything about those so we bought it cause it looked cool and was cheap. well we brought it home put it in the tank after acclamting it to the water, and the dam thing took off after every other fish we had in there and ate every dam one :eek: , so we started getting feeder fish for it and it grew to around 2 feet or so and we decided that was enough, and traded it for a big orange & black oscar which was a little more calmer :D
  12. i started out in a chevy luv 2wd, can't remeber the year. dad pulled it around back in the yard and told me what to do and i took off without no problems, he couldn't believe it. we drove around for a while after that and he said i won't have any problems and went inside and left me to play with it the rest of the day. :D . however a few years later we almost learned the hard way to not forget to put the e-brake on when sitting on a boat ramp to launch a boat. :eek:
  13. if your getting one from a junkyard before you beat it out you need to put on a nut to help keep the threads from getting damaged, otherwise you'll be in the same place with that one. :headpop:
  14. well make that 4 of us that have the black interior, i even have the black & white bench seat just like in these pics.
  15. hey are those tweeters mounted in the little square area just in front of the door handles? it's kinda hard to tell cause the pic is a little fuzzy. that gives me an idea on where to put some whenever i get some extra $.
