codymanche Posted April 11, 2011 Share Posted April 11, 2011 Hell yea lol if ur not first ur last Link to comment Share on other sites More sharing options...
mj Mike Posted April 17, 2011 Author Share Posted April 17, 2011 I picked my transfer case, its a NP-242 with SYE conversion Link to comment Share on other sites More sharing options...
mj Mike Posted April 17, 2011 Author Share Posted April 17, 2011 Also found a new/used AX-15 and re-assembled with a 242 T-C. With the flat flange on the SYE, I was forced to order a custom drive shaft from Tom woods I also failed at finding matching T-C linkage at local junk yards, so i went with Novak's Shifter Assembly for the 242. Link to comment Share on other sites More sharing options...
mj Mike Posted April 17, 2011 Author Share Posted April 17, 2011 I picked up a D30 front end for $100, and took it to get it sand blasted. Then I ordered a Ballistic Fabrication D30 truss, and did some gussets to the outer C's, and the Track Bar Mount. Also fabed new beefy lower Shock Mounts. Link to comment Share on other sites More sharing options...
SW86 Posted April 17, 2011 Share Posted April 17, 2011 mj Mike said: why did you mount your LCAs upside down? good f*ckin build tho man :popcorn: Link to comment Share on other sites More sharing options...
meljr Posted April 17, 2011 Share Posted April 17, 2011 I really have to complement you on your Comanche and fabrication skills. Not so much desert here in Western Oregon, especially with all the rain this year, but I have learned quite a bit from your build description and pictures. Thanks for sharing. -meljr Link to comment Share on other sites More sharing options...
codymanche Posted April 17, 2011 Share Posted April 17, 2011 u should make that 30 a super 30 they are just as good as a 44 from what i hear Link to comment Share on other sites More sharing options...
mj Mike Posted April 17, 2011 Author Share Posted April 17, 2011 Quote why did you mount your LCAs upside down? good f*ckin build tho man :popcorn: Not that I the like the look of LCA's upside down, but function before fashion. When we cycled the suspension to the set the location of the Fox Bump Stops, my LCA's were hitting my frame rails before the Shocks were fully compressed. Link to comment Share on other sites More sharing options...
SW86 Posted April 18, 2011 Share Posted April 18, 2011 bummer but at least your landings won't be so rough lol Link to comment Share on other sites More sharing options...
mj Mike Posted April 18, 2011 Author Share Posted April 18, 2011 Got my Upper Control Arm Joint on the Axle, and a fresh coat of paint. Put a fresh coat of paint on a drive shaft that I had laying around. Tried to re-use my 2wd calipers and they were non compatible with 4wd Knuckles. So I went with 4wd calipers and with a fresh coat of paint. I had custom extended rubber brake lines made for my old 2wd drive calipes, these were non-compatiple with my 4wd also. Went with Earl's #1 AN-3 pre made brake lines. Summit's Rotor and Brake Pad combo. Link to comment Share on other sites More sharing options...
mj Mike Posted April 22, 2011 Author Share Posted April 22, 2011 new ring & pinion gear 456 & new carrier Link to comment Share on other sites More sharing options...
codymanche Posted April 22, 2011 Share Posted April 22, 2011 looking good bro Link to comment Share on other sites More sharing options...
H3RESQ Posted April 22, 2011 Share Posted April 22, 2011 Looks good, but maybe I missed reading why you have your front lower links upside down?!? Link to comment Share on other sites More sharing options...
mj Mike Posted April 23, 2011 Author Share Posted April 23, 2011 Quote 'southernwheeler86 said: why did you mount your ''LCAs'' upside down? Quote [/quote='mj Mike'] Not that I the like the look of Lower Control Arm's upside down, but function before fashion.When we cycled the suspension to the set the location of the Fox Bump Stops, my ''LCA's'' were hitting my frame rails before the Shocks were fully compressed. Link to comment Share on other sites More sharing options...
H3RESQ Posted April 23, 2011 Share Posted April 23, 2011 mj Mike said: Quote 'southernwheeler86 said: why did you mount your ''LCAs'' upside down? Quote [/quote='mj Mike'] Not that I the like the look of Lower Control Arm's upside down, but function before fashion.When we cycled the suspension to the set the location of the Fox Bump Stops, my ''LCA's'' were hitting my frame rails before the Shocks were fully compressed. Sweet...guess I did miss that post. Rig looks great, can't wait to get my air bumps. :thumbsup: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 23, 2011 Share Posted April 23, 2011 1st Ive really looked into this thread but I'm impressed! keep it up :cheers: Link to comment Share on other sites More sharing options...
mj Mike Posted April 23, 2011 Author Share Posted April 23, 2011 Thanks!! for the complements H3RESQ said: can't wait to get my air bumps. :thumbsup: i run a 10'' stroke shock with a 4'' stroke bump stops. so @ ride height the shocks only have 1'' of compression before the start of the bumps & @ full droop the bumps hit the coils. i recommend to go with a 2'' stroke bump stops (shorty's) this will give you more affective compression & they will not hit the coils like mine in the pic's. for me , Fox makes shims to adjust the stroke! i need these to fix this problem! Link to comment Share on other sites More sharing options...
Comanche County Posted April 24, 2011 Share Posted April 24, 2011 Great Job man! Link to comment Share on other sites More sharing options...
H3RESQ Posted April 26, 2011 Share Posted April 26, 2011 mj Mike said: Thanks!! for the complements H3RESQ said: can't wait to get my air bumps. :thumbsup: i run a 10'' stroke shock with a 4'' stroke bump stops. so @ ride height the shocks only have 1'' of compression before the start of the bumps & @ full droop the bumps hit the coils. i recommend to go with a 2'' stroke bump stops (shorty's) this will give you more affective compression & they will not hit the coils like mine in the pic's. for me , Fox makes shims to adjust the stroke! i need these to fix this problem! Perfect, thanks for the info. Once I lower mine I will only have the option of the shortys. I'll probably have only a inch or 1.5 before the bumps hit pads with 2" bumps. Link to comment Share on other sites More sharing options...
mj Mike Posted April 27, 2011 Author Share Posted April 27, 2011 i got A 99+ intake manifold gummed up throttle body 91 H/O VS 99+ custom vac lines work stool LOL! Link to comment Share on other sites More sharing options...
mj Mike Posted April 29, 2011 Author Share Posted April 29, 2011 after i swapped out the 91 manifold for the 99+ i found out the power steering brackets are non compatible with the manifold my P/S pump was also starting to go out so i went with the PSC power steering pump w/ remote reservoir & A/N fittings Link to comment Share on other sites More sharing options...
H3RESQ Posted April 29, 2011 Share Posted April 29, 2011 mj Mike said: after i swapped out the 91 manifold for the 99+ i found out the power steering brackets are non compatible with the manifold my P/S pump was also starting to go out so i went with the PSC power steering pump w/ remote reservoir & A/N fittings Gosh, thats just to bad it forced you into that upgrade. :drool: :cheers: Link to comment Share on other sites More sharing options...
mj Mike Posted April 29, 2011 Author Share Posted April 29, 2011 :agree: one upgrade leads to another! the PSC bracket to mount the remote reservoir to the break master cylinder is for a ,99+, & i still run my stock 92 Master cylinder so i moved the PCM & made a bracket to mount the reservoir to the fender wall. PSC recommends running a heat sink cooler for this system. i went W/ a Derale dual pass aluminum heat sink cooler #13261 from summit racing Link to comment Share on other sites More sharing options...
swamprat Posted April 29, 2011 Share Posted April 29, 2011 sexy! :D Link to comment Share on other sites More sharing options...
mj Mike Posted May 3, 2011 Author Share Posted May 3, 2011 thanks! i installed the K&N filter i piced up for $10 from the guy hew sold me the intake manifold. and notched the splash guard i made for it Link to comment Share on other sites More sharing options...
