Herc Posted February 27, 2011 Share Posted February 27, 2011 That sucks :mad: main thing is you're okay. As for the truck like you said rebuild it, door fender and axle and it's pretty much good to go :wrench: Keep the positive attitude and anything can be done. Link to comment Share on other sites More sharing options...
codymanche Posted February 27, 2011 Share Posted February 27, 2011 how do u like the msd igintion systems and what all do u have one it how much Link to comment Share on other sites More sharing options...
mj Mike Posted February 28, 2011 Author Share Posted February 28, 2011 codymanche Post subject: Re: DezertComanche Reply with quote how do u like the msd igintion systems and what all do u have one it how much MSD Ignition - Coil, Chrysler Late Model, 90-96 8228 USD$ 49.70 USD$ 49.70 MSD Ignition - Harness, MSD to '90-'95 Dodge Ram 5.2/5.9L 8889 USD$ 17.10 USD$ 17.10 MSD Ignition - MSD 6-Off Road Ignition 6470 USD$ 269.50 USD$ 269.50 Subtotal USD$ 336.30 http://www.shopatron.com/home/index/424.0.1.1 OR http://www.summitracing.com/search/?keyword=msd&dds=1 Keep in mind that this coil & wire harness are for a 91 & up H/O 4.0L inline6. they will not fit on a Renix 4.0 :thumbsup: Link to comment Share on other sites More sharing options...
codymanche Posted March 1, 2011 Share Posted March 1, 2011 I'm looking to get one for mine its a 1990 and has bigger pistons and camshaft just looking to squeeze some more out of it. Link to comment Share on other sites More sharing options...
mj Mike Posted March 3, 2011 Author Share Posted March 3, 2011 5.5 of lift! need a new adjustable track bar! so I went with the TNT customs track bar system http://www.tntcustoms.com/trackbarsystemmjxjzj.aspx & i plan to go fast in the dezert. with that said i want parts that will last & that will not break and leave me stranded in the dezert. I drive my jeep there & back. so i went with the JCR 1 ton steering http://www.jcroffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=1TNST&Category_Code=S6 Link to comment Share on other sites More sharing options...
shelbyluvv Posted March 3, 2011 Share Posted March 3, 2011 You are going to want a double shear TB for the go fast stuff. Link to comment Share on other sites More sharing options...
mj Mike Posted March 3, 2011 Author Share Posted March 3, 2011 :agree: i up to a Rubicon express signal shear W/3.5 kit, but now i am going big so i want it to last. check out the link :thumbsup: .I went with the TNT customs track bar system http://www.tntcustoms.com/trackbarsystemmjxjzj.aspx Link to comment Share on other sites More sharing options...
shelbyluvv Posted March 4, 2011 Share Posted March 4, 2011 I saw the track bar in the pic but not the bracket. :cheers: Looks like you got it under control. Link to comment Share on other sites More sharing options...
mj Mike Posted March 4, 2011 Author Share Posted March 4, 2011 I saw the track bar in the pic but not the bracket. :cheers: actually the pic was taken after a friend welded my TNT T/b bracket to the frame!! :D but ya i should have taken a pic W/brackets when the TNT setup was new. Link to comment Share on other sites More sharing options...
mj Mike Posted March 4, 2011 Author Share Posted March 4, 2011 Got my rockrawler kit on the truck. After i cut off the stock lower control arm brackets & put the new Rockrawler brackets on the frame rails, i could not drill the front hole on the brackets there is a peace of metal in the frame that catches the brill bite, so i had a friend weld them to the frame rails. :D :cheers: Link to comment Share on other sites More sharing options...
raviolli Posted March 4, 2011 Share Posted March 4, 2011 ..just out of curiosity... with all the time and money going into a big long arm lift and everything else, why still 2wd? all in all a great lookin truck though :popcorn: Link to comment Share on other sites More sharing options...
mj Mike Posted March 4, 2011 Author Share Posted March 4, 2011 raviolli Post subject: Re: DezertComanche Reply with quote ..just out of curiosity... with all the time and money going into a big long arm lift and everything else, why still 2wd? 2wd front sleeved with .250 wall chromoly No problems! Eric Filar FatCity Off-Road Racing 1790 Motive Gear - TEN Factory - National Drivetrain - PRP Racing Seats - Light Force Some jeepspeeds like this one (FatCity Off-Road Racing 1790) run 2wd. when you have that much speed in the dezert you do not need to be in 4x4. they depend on the rear locker & gears. got some pics of my rear end on the way! :popcorn: & ya i have a lots more time, money & :wrench: to do before i can get that much air! Link to comment Share on other sites More sharing options...
raviolli Posted March 4, 2011 Share Posted March 4, 2011 ahhh yes forgot it was a baja truck Link to comment Share on other sites More sharing options...
mj Mike Posted March 5, 2011 Author Share Posted March 5, 2011 got my d44 in & i went with ford crown vic disk breaks, junkyard backing plates, new calipers, & cross drilled & slotted rotters. for the diff cover i got a Riddler http://www.polyperformance.com/shop/Dana-44-Diff-Cover-p-2475.html mj Mike Post subject: Re: DezertComanche PostPosted: Sun Feb 20, 2011 7:33 am my dana 44 internals 4;56 gear i got from http://www.nationaldrivetrain.com/ a Aussie locker http://www.aussielocker.com/ and Alloy USA rear axle shafts http://www.alloyusa.com/jeep-rear-axles.html Back on the tires Link to comment Share on other sites More sharing options...
Comanche County Posted March 5, 2011 Share Posted March 5, 2011 Nice Truck! Me likee. Link to comment Share on other sites More sharing options...
mj Mike Posted March 6, 2011 Author Share Posted March 6, 2011 Nice Truck! Me likee. all in all a great lookin truck though :popcorn: thanks :thumbsup: i got lot's more :wrench:on the way & to do :popcorn: Link to comment Share on other sites More sharing options...
mj Mike Posted March 6, 2011 Author Share Posted March 6, 2011 did some trimming to the fenders & up to 33'' tires. here is some pics of the new ride height & locked burnouts. :popcorn: my red 90 Cherokee W/ 3.5 lift & 31'' my Comanche's old lift. testing the alternator up top. not a drop no it! :thumbsup: Link to comment Share on other sites More sharing options...
codymanche Posted March 9, 2011 Share Posted March 9, 2011 are your rear fenders pulled out or did u buy bedside fiberglass fender? also have u been pulled over here in cali for your tires or fenders being cut and sticking out Link to comment Share on other sites More sharing options...
mj Mike Posted March 9, 2011 Author Share Posted March 9, 2011 are your rear fenders pulled out or did u buy bedside fiberglass fender? also have u been pulled over here in cali for your tires or fenders being cut and sticking out they are the stock bedsides W/ the wheel wells cut out then i pulled them out & made some simple tie in to the frame & extended the fuel fill tube. W/33'' 12.50s & 5.5'' of lift I have not got pulled over yet!. Butt two of my friends W/ Cherokees have. they say it is cowman to get fix it tickets from CHP for mud flaps. A friends fix he used 1 screw! :wrench: just had it on his jeep long enough to get his fix it ticket sighed off. :cheers: Link to comment Share on other sites More sharing options...
mj Mike Posted March 11, 2011 Author Share Posted March 11, 2011 I needed to run a good front sway bar set up w/ my deaver coils so i went w/ Currie Antirock http://www.polyperformance.com/shop/XJ-MJ-Antirock-Front-Sway-Bar-Kit-p-21289.html then i wanted rebuild-able lower control arm joint to up grade the ones that come w/ rockwlers kit. new ones from Ballistic Fabrication, Forged Chromoly joints 2.63'' http://www.ballisticfabrication.com/Forged-Chromoly-263-Ballistic-Joint_p_1636.html Link to comment Share on other sites More sharing options...
codymanche Posted March 17, 2011 Share Posted March 17, 2011 how did u separate the fender i was thinking about pulling mine out but not till i get glass in the front Link to comment Share on other sites More sharing options...
dakineJ Posted March 17, 2011 Share Posted March 17, 2011 Nice build. I'm headed in the same direction, not nearly as much progress though, but many of the same ideas. My MJ was also my first Jeep and my DD. Being a 2wd as well, I had planned to convert to 4wd, then along came desert racing and prerunner's and I knew what I must do :D . Link to comment Share on other sites More sharing options...
mj Mike Posted March 18, 2011 Author Share Posted March 18, 2011 how did u separate the fender i was thinking about pulling mine out but not till i get glass in the front i made two cuts, w/ 4 1/2 angel grinder, one on the in side of the fender well as far in as i could with out cutting in to the in side metal. the other cut was on the out side of the bed side. i traced the top line of the stock fender flair. you can see from my pics. dakineJNice build. Thanks! :thumbsup: Keep posted i have a lot more to on the way . :popcorn: & i am glad to see you have interest in off road racing! My goal is a race legal Comanche. for racing S.C.O.R.E Class 7s or jeepspeed 3700 Link to comment Share on other sites More sharing options...
dakineJ Posted March 18, 2011 Share Posted March 18, 2011 Thanks! :thumbsup: Keep posted i have a lot more to on the way . :popcorn: & i am glad to see you have interest in off road racing! My goal is a race leagull Comanche. for racing S.C.O.R.E Class 7s or jeepspeed 3700 Absalutely. I would love to do the same. Mabye I could crew for you, 8) . There's a 3700 MJ for sale now complete w/trailing arms, coilover's, etc. Well, looking forward to seeing more progress. :cheers: Link to comment Share on other sites More sharing options...
mj Mike Posted March 19, 2011 Author Share Posted March 19, 2011 looking forward to seeing more progress. :cheers: i am changing out the JKS bar pin eliminators & went with T&J upper bypass shock mounts & i will figure out the bottom axle side mount on my own. butt i want to get these new bypass shocks mounted. Fox 2.5 bypass 10''stroke also doing fox hydraulic bump stops W/ the T&J bump stops mounts. a friend from NAXJA got me some front frame stiffeners, smiler to the ones TMR makes.http://www.temper-mentalracing.com/TMR/Parts_and_Services.html Link to comment Share on other sites More sharing options...
