Dezert Comanche
That sucks :mad: main thing is you're okay. As for the truck like you said rebuild it, door fender and axle and it's pretty much good to go :wrench:
Keep the positive attitude and anything can be done.
  • Replies 137
  Quote
  codymanche said:
codymanche
Post subject: Re: DezertComanche Reply with quote
how do u like the msd igintion systems and what all do u have one it how much
MSD Ignition - Coil, Chrysler Late Model, 90-96 8228 USD$ 49.70
USD$ 49.70
MSD Ignition - Harness, MSD to '90-'95 Dodge Ram 5.2/5.9L 8889 USD$ 17.10
USD$ 17.10
MSD Ignition - MSD 6-Off Road Ignition 6470 USD$ 269.50
USD$ 269.50
Subtotal USD$ 336.30
http://www.shopatron.com/home/index/424.0.1.1
OR
http://www.summitracing.com/search/?keyword=msd&dds=1
Keep in mind that this coil & wire harness are for a 91 & up H/O 4.0L inline6. they will not fit on a Renix 4.0
:thumbsup:
5.5 of lift! need a new adjustable track bar! so I went with the TNT customs track bar system http://www.tntcustoms.com/trackbarsystemmjxjzj.aspx
& i plan to go fast in the dezert. with that said i want parts that will last & that will not break and leave me stranded in the dezert. I drive my jeep there & back.
so i went with the JCR 1 ton steering http://www.jcroffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=1TNST&Category_Code=S6
  shelbyluvv said:
I saw the track bar in the pic but not the bracket.
:cheers:
actually the pic was taken after a friend welded my TNT T/b bracket to the frame!! :D
but ya i should have taken a pic W/brackets when the TNT setup was new. image_209027.gif
Got my rockrawler kit on the truck. After i cut off the stock lower control arm brackets & put the new Rockrawler brackets on the frame rails, i could not drill the front hole on the brackets there is a peace of metal in the frame that catches the brill bite, so i had a friend weld them to the frame rails. :D
:cheers:
  Quote
raviolli
..just out of curiosity...
with all the time and money going into a big long arm lift and everything else, why still 2wd?
  Quote
2wd front sleeved with .250 wall chromoly
No problems!
Eric Filar
FatCity Off-Road Racing
1790
Motive Gear - TEN Factory - National Drivetrain - PRP Racing Seats - Light Force
Some jeepspeeds like this one (FatCity Off-Road Racing 1790) run 2wd. when you have that much speed in the dezert you do not need to be in 4x4. they depend on the rear locker & gears.
got some pics of my rear end on the way! :popcorn:
& ya i have a lots more time, money & :wrench: to do before i can get that much air!
got my d44 in & i went with ford crown vic disk breaks, junkyard backing plates, new calipers, & cross drilled & slotted rotters.
for the diff cover i got a Riddler http://www.polyperformance.com/shop/Dana-44-Diff-Cover-p-2475.html
mj Mike
PostPosted: Sun Feb 20, 2011 7:33 am
my dana 44 internals 4;56 gear i got from http://www.nationaldrivetrain.com/
a Aussie locker http://www.aussielocker.com/
and Alloy USA rear axle shafts http://www.alloyusa.com/jeep-rear-axles.html
Back on the tires
  Comanche County said:
Nice Truck! Me likee.
  raviolli said:
all in all a great lookin truck though :popcorn:
thanks :thumbsup:
i got lot's more :wrench:on the way & to do
:popcorn:
did some trimming to the fenders & up to 33'' tires.
here is some pics of the new ride height & locked burnouts. :popcorn:
my red 90 Cherokee W/ 3.5 lift & 31'' my Comanche's old lift.
testing the alternator up top. not a drop no it! :thumbsup:
  codymanche said:
are your rear fenders pulled out or did u buy bedside fiberglass fender? also have u been pulled over here in cali for your tires or fenders being cut and sticking out
they are the stock bedsides W/ the wheel wells cut out then i pulled them out & made some simple tie in to the frame & extended the fuel fill tube. W/33'' 12.50s & 5.5'' of lift I have not got pulled over yet!. Butt two of my friends W/ Cherokees have. they say it is cowman to get fix it tickets from CHP for mud flaps.
A friends fix he used 1 screw! :wrench: just had it on his jeep long enough to get his fix it ticket sighed off.
:cheers:
I needed to run a good front sway bar set up w/ my deaver coils so i went w/ Currie Antirock
http://www.polyperformance.com/shop/XJ-MJ-Antirock-Front-Sway-Bar-Kit-p-21289.html
then i wanted rebuild-able lower control arm joint to up grade the ones that come w/ rockwlers kit.
new ones from Ballistic Fabrication, Forged Chromoly joints 2.63''
http://www.ballisticfabrication.com/Forged-Chromoly-263-Ballistic-Joint_p_1636.html
Nice build. I'm headed in the same direction, not nearly as much progress though, but many of the same ideas. My MJ was also my first Jeep and my DD. Being a 2wd as well, I had planned to convert to 4wd, then along came desert racing and prerunner's and I knew what I must do :D .
  codymanche said:
how did u separate the fender i was thinking about pulling mine out but not till i get glass in the front
i made two cuts, w/ 4 1/2 angel grinder, one on the in side of the fender well as far in as i could with out cutting in to the in side metal. the other cut was on the out side of the bed side. i traced the top line of the stock fender flair. you can see from my pics.
  dakineJ said:
dakineJ
Nice build.
Thanks! :thumbsup: Keep posted i have a lot more to on the way . :popcorn: & i am glad to see you have interest in off road racing! My goal is a race legal Comanche. for racing S.C.O.R.E Class 7s or jeepspeed 3700
  mj Mike said:
Thanks! :thumbsup: Keep posted i have a lot more to on the way . :popcorn: & i am glad to see you have interest in off road racing! My goal is a race leagull Comanche. for racing S.C.O.R.E Class 7s or jeepspeed 3700
Absalutely. I would love to do the same. Mabye I could crew for you, 8) . There's a 3700 MJ for sale now complete w/trailing arms, coilover's, etc. Well, looking forward to seeing more progress. :cheers:
i am changing out the JKS bar pin eliminators & went with T&J upper bypass shock mounts & i will figure out the bottom axle side mount on my own. butt i want to get these new bypass shocks mounted.
Fox 2.5 bypass 10''stroke
also doing fox hydraulic bump stops W/ the T&J bump stops mounts. a friend from NAXJA got me some front frame stiffeners, smiler to the ones TMR makes.http://www.temper-mentalracing.com/TMR/Parts_and_Services.html
