86ComancheXNate Posted December 2, 2010 Posted December 2, 2010 I was just informed that I have an AMC 20 rear end. I was wonder what people thought of it and what I should do with it. Should I swap it or should I keep and rebuild? Oh yeah my truck is only 2wd if that means anything.
JeepcoMJ Posted December 2, 2010 Posted December 2, 2010 how do u know it's anamc20? i didnt see pics of it in your thread
jimoshel Posted December 2, 2010 Posted December 2, 2010 ???? If there's nothing wrong with it, then just keep it.
86ComancheXNate Posted December 2, 2010 Author Posted December 2, 2010 I posted a pic on jf and they told me it was an amc 20 but here's the pic I posted there.
mkbruin Posted December 2, 2010 Posted December 2, 2010 There is nothing inherrently wrong with the 20, especially the later years such as what you have in yours. I agree, if its not broke, don't fix it. When it does go, dana 35's and 44's are bolt-in (assuming you find an MJ 44), otherwise you can look at dana 44's, ford 8.8's, etc and a weld-in/custom drivehaft/brakes type of job.
Motion Offroad Posted December 2, 2010 Posted December 2, 2010 Yes you have an AMC20. The AMC20 from the MJ is a very desirable axle. You can ID your gear ratio by looking for the stamped code on the housing. D 2.73 Open DD 2.73 Trac-Lok B 3.31 Open BB 3.31 Trac-Lok A 3.54 Open AA 3.54 Trac-Lok H 3.73 Open HH 3.73 Trac-Lok C 4.10 Open CC 4.10 Trac-Lok Most likely your MJ has a "C" stamped on it (4.10 ratio); as the majority of the AMC20's found in the MJ have that ratio.
Pete M Posted December 2, 2010 Posted December 2, 2010 "should" be 4.10 since that's all that was officially offered with the 86 metric ton package.
86ComancheXNate Posted December 2, 2010 Author Posted December 2, 2010 lol Pete I see you've found my thread on here as well.
Pete M Posted December 2, 2010 Posted December 2, 2010 and as I said on jf, it's already an upgrade. on par with the 44 and 8.8s. nothing more to do but bask in the ownership of a rare MJ gem. :D
HOrnbrod Posted December 2, 2010 Posted December 2, 2010 Don't believe all the above. The AMC20 axle is junk and should be scrapped. Nothing but a boat anchor. So where do you live? I'll come get it. :yes: :cheers:
JeepcoMJ Posted December 2, 2010 Posted December 2, 2010 Don't believe all the above. The AMC20 axle is junk and should be scrapped. Nothing but a boat anchor. So where do you live? I'll come get it. :yes: :cheers: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
86ComancheXNate Posted December 2, 2010 Author Posted December 2, 2010 haha so if its junk why do you want it so bad?
HOrnbrod Posted December 2, 2010 Posted December 2, 2010 :yes: = joke. :roll: Be thankful you have the AMC20. Wish I did.........
ride172 Posted December 2, 2010 Posted December 2, 2010 I got one under my 88 that came from my 86... 4.10 open-stamped C.... If only I had one more C after that... The trac-lok would too sweet.. Keep it.... sell the 86....
jpnjim Posted December 2, 2010 Posted December 2, 2010 "should" be 4.10 since that's all that was officially offered with the 86 metric ton package. :yes: officially all MJ M20's were 4.10 geared, available with, or without trac-lock. Is it a good axle? The shafts are 29 spline, and one piece (unlike the AMC automotive & CJ axles). They are slightly bigger than the 29spline shafts in a Mopar 8.25" axle. The ring gear is just smaller than a Ford 9", and the same size as a 12 bolt Chevy (8.875"). The only bad part is they spec'd it out to use just 8 bolts to hold the ring gear to the carrier (most axles this size have either 10, or 12 bolts). The pinion gear is bigger than a D44's, and the same size as a D60's pinion. It uses a crush spacer to set the pinion bearing preload. Easier, and more cost effective when they originally made them, but the crush spacer can be replaced with shims if needed for heavy duty applications. This is the same ring & pinion set used in Military Hummers & Civi H1's. Even tho Hummers don't get our cool 'pith helmet' diff cover, it's the same center section under the cover. Typical M20 tubes are on the thin side, and the center castings are usually as well, but I've never seen an MJ M20 cut up to know if that's true for our version too. The wheel bearings are tapered, preload type, that require setting up with shims behind one wheel bearing flange, and a special crosspin to be used in the differential. AMC guys have set these up in 10 second race cars, but most people switch to something else for reliability when they start putting serious power to the ground. I think it's a good axle. :thumbsup:
86ComancheXNate Posted December 2, 2010 Author Posted December 2, 2010 so is there anything I could to to tweak it and get more power from it?
86ComancheXNate Posted December 4, 2010 Author Posted December 4, 2010 oh and I was wondering what should I look for in a front axle to make my truck 4x4
Pete M Posted December 4, 2010 Posted December 4, 2010 you might want to break these up into different threads. :thumbsup:
86ComancheXNate Posted December 5, 2010 Author Posted December 5, 2010 I think its on the front? I'm not sure. Is there anywhere that you can find parts for the mj specific amc 20?
Pete M Posted December 5, 2010 Posted December 5, 2010 what parts do you need? your local auto parts store should have most everything except axle shafts.
86ComancheXNate Posted December 5, 2010 Author Posted December 5, 2010 I'm not sure. Pete have you done anything to your AMC 20?
86ComancheXNate Posted December 10, 2010 Author Posted December 10, 2010 I'm looking to replace the diff fluid, doing an overall tune up and fluid replacement on my mj. I need some help with how to drain and fill the rear diff on the AMC 20 and what fluid I should use.
Pete M Posted December 10, 2010 Posted December 10, 2010 to drain you'll need to pop off the cover (leave one of the top bolts in kinda loose to help prevent dropping the cover and spilling oil everywhere). takes plain ol' 75-90 gear oil (if it has a posi inside, then you'll want to add in the proper additive). for the life of me I don't remember where the fill plug is. :hmm: and the truck is over at my grandma's. poke your head around and I'm sure you'll find it. :thumbsup:
