K&N Cone filter
So the last week I was up in south carolina last week for thanksgiving with my brother and his family. While there My brother gave me his old K&N Cone air filter. All I have is the filter. I have since cleaned and re oiled with a kit I bought at auto zone. Now all I need to do is put her in. any idea's on how to do this with out buying an intake kit? Here is a pic of what the filter looks like:
any advise will help. Thank you
Brandon
edit: the filter's hole can be clamped but not by much. and the hole is large in comparison to the stock intake.
You can get an 3" intake tube with grommet holes for the emissions (to make it legal).
One hose from front of valve cover, the other to vac supply.
They come in different lengths and 20 degree angle all the way to 90 degree angle. Auto Zone, cheap. The filter will not fit 3" ABS pipe because the 3" on ABS is inside diameter.
Like said above, $30 or so.
Dose the rustys intake tube have the One hose from front of valve cover, the other to vac supply? and what did you have to do to make the ford intake fit? any real hard core mod's? and what year did you use? do you know if there is a year range? btw I have the 4.0 I6. Thanks
Brandon
that hose from front of valve cover i ran into a old plastic bottle.
that way when it blows oil out you can pour it back in.
the vacuum line i think i blocked with a screw
then just put a piece of tubing between the filter and the rubber intake hose that went to the filter box
when i got a new engine i removed the bottle and just vent the stupid thing new engine does'nt have blow by yet.
most of the parts stores have tubing you can put in there.
Brandon
it clamped into place w/o any alteration other than a small slit in the filter end so it clamped down very tight. as to year, I do not remember any difference in the various units when I went to the scrap yard to get it
I've been running this system for about 5 yrs now, I do like the idea of using the alum tube or pvc the others have suggested, as it would be more stable --
i have a rusty's air tube on mine but ditched the K&N after 3k miles after finding dirt inside the air tube behind the filter....i run a AirRaid filter now.
Idk all i have heard is good things about K&N the only thing that has kept me away from them is the price. so we will see
I use the pre-filter cover on mine as we run in the desert quite abit
What do you mean by the Pre-filter cover? I thought you just laid them in the engine compartment? thats how ive always seen them :dunno:
Brandon
won't work because the stock hose is to small to try and clamp to the air filter. must have a different filter then me :dunno:
Brandon
here's some pics of the set up
sorry attempted to insert pics -- not sure why they would not go
hmmm, this is actually very disturbing. even if I try to edit packratt's post, the photos will not show. but if I quote him in my own post (and add the img tags), the photos do show. same with quoting people. its almost as if the features are turned off for you. :hmm:
packratt, send me a PM to remind me about this and I'll look into it later today.
