neverstuck Posted November 5, 2010 Posted November 5, 2010 Anyone had experience with changing out the fuel pumps; never done one on my comanche. any different from cherokee? Any advice, things to look for or to watch out for, helpful suggestions or hints?
Geonovast Posted November 5, 2010 Posted November 5, 2010 It can be done with the tank in the truck, but I highly recommend dropping the tank, and setting it on the tailgate to do this. It ensures you get it to seal properly during re-install, and should be harder to destroy the lock ring when you're able to, you know, see what you're doing. Also gives you a chance to check for sediment in the tank, change the 22 year old hose clamps on the fill neck, and inspect the vapor roll over valves. Popping one of those will also help you line up the return line rubber stopper when you're re-installing the sender.
thedave360 Posted November 5, 2010 Posted November 5, 2010 It can be done with the tank in the truck, but I highly recommend dropping the tank, and setting it on the tailgate to do this. It ensures you get it to seal properly during re-install, and should be harder to destroy the lock ring when you're able to, you know, see what you're doing. Also gives you a chance to check for sediment in the tank, change the 22 year old hose clamps on the fill neck, and inspect the vapor roll over valves. Popping one of those will also help you line up the return line rubber stopper when you're re-installing the sender. I WISH I would have done this when I changed my fuel pump. I changed it without dropping the tank and it SUCKED. I would definately recommend removing the tank. Next time my fuel pump goes out I'm going to convert to an external fuel pump. Thats something you might want to look into. But get a real external fuel pump, don't just rig up an internal fuel pump outside the tank.
Geonovast Posted November 5, 2010 Posted November 5, 2010 I WISH I would have done this when I changed my fuel pump. I changed it without dropping the tank and it SUCKED. Exactly why I recommend it. First time I did it, I also did not drop the tank. Spent probably 3 hours trying to get it to seat right, just to have to go an entire winter without being able to fill up past 3/4. Next spring I dropped the tank, reset the sender, and hand the tank in, in less than half the time it took me the first time.
tallon2064 Posted November 5, 2010 Posted November 5, 2010 Not really on topic here, but what external fuel pump are you going to use, I have thought of the same thing if mine goes out again. As for leaving the tank in or removing it and replacing the fuel pump I have done it both ways and removing it is by far a better choice. It is easier to work on and while out you can check for other issues, the first time I pulled mine I found a hole where the P.O. had screwed a box to the floor of the bed and through the top of the tank. :doh:
cluricaunne Posted November 6, 2010 Posted November 6, 2010 I've done mine 4 times now, in the truck, I can change one out in about 20 minutes. My exhaust system has been butchered, I am 5'9" and weigh in about 145. I can sit up between the exhaust pipe and the tank, and look right at the pump, makes life really easy.
neverstuck Posted November 6, 2010 Author Posted November 6, 2010 Thanks for the advice guys. Id like to look into an external pump as well. Rite now tho i finally had someone turn the ignition on while i was under the truck. I have no power to the wiring harness, so i need to get power back there first :dunno: crap
neverstuck Posted November 6, 2010 Author Posted November 6, 2010 How much fuel does a comanche fuel pump pump?(spec wise) lol Why can't we just get a fuel pump with a switch to turn on when its go time? thats what i want....
neverstuck Posted November 7, 2010 Author Posted November 7, 2010 I took the tank out today; it doesnt look like the lock ring is gonna loosen up very easy or at all. Hoping
neverstuck Posted November 7, 2010 Author Posted November 7, 2010 I took the tank out today; it doesnt look like the lock ring is gonna loosen up very easy or at all. Hoping And i have power to the pump again :banana:
johnnyc Posted November 7, 2010 Posted November 7, 2010 Not really on topic here, but what external fuel pump are you going to use, I have thought of the same thing if mine goes out again. A buddy of mine has a sweet setup in his Cherokee. He mounted an external Bosch fuel pump under his rear seat. Now he can change the pump in 5 minutes. I will ask him for the part number. He said he could do the same on my MJ, but we'd have to find a good location for it. Last year, I changed the fuel pump with out dropping the tank. Yeah, it was a PITA. And I didn't get the lockring back on right, so I leaked a lot of gas when I went to fill up. Had to drop the tank to do it right.
89flat Posted November 7, 2010 Posted November 7, 2010 dropping the tank is a waste of time, i have done three of them with it in the truck, it takes me about 45 mins with no damage, mind you i am 6' 2" and am about 250 so
neverstuck Posted February 26, 2011 Author Posted February 26, 2011 Not really on topic here, but what external fuel pump are you going to use, I have thought of the same thing if mine goes out again. A buddy of mine has a sweet setup in his Cherokee. He mounted an external Bosch fuel pump under his rear seat. Now he can change the pump in 5 minutes. I will ask him for the part number. He said he could do the same on my MJ, but we'd have to find a good location for it. Last year, I changed the fuel pump with out dropping the tank. Yeah, it was a PITA. And I didn't get the lockring back on right, so I leaked a lot of gas when I went to fill up. Had to drop the tank to do it right. Ya ever get that part number ? it be a handy piece of info and a handy setup....
jeep10 Posted February 27, 2011 Posted February 27, 2011 Not really on topic here, but what external fuel pump are you going to use, I have thought of the same thing if mine goes out again. A buddy of mine has a sweet setup in his Cherokee. He mounted an external Bosch fuel pump under his rear seat. Now he can change the pump in 5 minutes. I will ask him for the part number. He said he could do the same on my MJ, but we'd have to find a good location for it. Last year, I changed the fuel pump with out dropping the tank. Yeah, it was a PITA. And I didn't get the lockring back on right, so I leaked a lot of gas when I went to fill up. Had to drop the tank to do it right. Ya ever get that part number ? it be a handy piece of info and a handy setup.... yeah and did he use oem fuel pressure regulator or aftermarket ?
cody4359 Posted February 27, 2011 Posted February 27, 2011 i was comparing 4.0 mj/xj pumps not to long ago. lost my notes. got to autozone's website and pull up either pump and look at the specs, worked for me
cz777 Posted March 1, 2011 Posted March 1, 2011 external fuel pump ??,this is not a good idea ! volvo use this one ,a primer pump in the tank and main one outside !! oh yes what kind of fuel hoses you used for the MJ ? i hope 180 psi rated muti-fuel hoses ,yes, you will need 18'' of both 3/8 - 5/16 and 3.5 '' of this 5/16 180 psi for transfer hose -pump to out pipe .....the muti fuel 180 psi hose runs about 9.75 a foot ,don't use anything else or fuel leaks and fires !!!
