kawaboy13 Posted October 15, 2010 Share Posted October 15, 2010 I've done this to 2 Rangers and I'm pretty sure you can do it to Comanches. Anyway, if you grab your pedal and pull up, there's most likely some slack because of throttle cable stretch. I looked under my dash and saw I had about an inch of stretch in my Comanche. In the other trucks, the trick was to lift the pedal and put in zip ties to fill in the slack, therefore giving you more pedal and more top speed. Nothing that we really need, but it could improve acceleration also. I'm just wondering if anybody has done this to these trucks? It's rather easy and should bring the pedal up a bit and giving you much more throttle. Link to comment Share on other sites More sharing options...
Eagle Posted October 15, 2010 Share Posted October 15, 2010 Words fail me. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 15, 2010 Share Posted October 15, 2010 Nope, because it's stupid and could cause the accelerator pedal to stick and/or bind. :eek: I'd rather just adjust the slack out at the throttle body. Link to comment Share on other sites More sharing options...
codymanche Posted October 15, 2010 Share Posted October 15, 2010 hornmrod where can i find that visor like u did Link to comment Share on other sites More sharing options...
MJCARENA Posted October 15, 2010 Share Posted October 15, 2010 Just because you have slack does not mean the throttle plate is not opening fully. To check this you need two people, one to depress the gas pedal down and the other to see if the throttle plate is open all the way. You would want to adjust the cable so the throttle plate is almost at the point of fully open. You do not want to put extra stress on the cable or the throttle plate shaft. Link to comment Share on other sites More sharing options...
Pete M Posted October 15, 2010 Share Posted October 15, 2010 I've yet to see a TB valve not fully open up. :dunno: but I guess it's possible. only one way to know for sure and that's to check. just be sure that any adjustment you make won't contribute to a problem down the road, like stretching the cable even more, breaking some linkage on the TB, etc. I gotta imagine my lead foot is a lot stronger than the parts between it and the TB. :yes: Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 15, 2010 Share Posted October 15, 2010 :redX: the bottom 1/2" of the pedal is compression in the cable built in because the truck is already floored... if you pulled the cable even tighter you'd most likely junk the cable out in short order. Link to comment Share on other sites More sharing options...
glundblad Posted October 15, 2010 Share Posted October 15, 2010 I have used a wood block, C clamp and a 80# tractor weight on the pedal. It works great as a cruise control. Link to comment Share on other sites More sharing options...
WahooSteeler Posted October 16, 2010 Share Posted October 16, 2010 Words fail me. :rotfl2: Well said Eagle. That one just made top 10, scratch that, Top 5 All Time ________ (fill in the blank)! Link to comment Share on other sites More sharing options...
Craft86MJ Posted October 16, 2010 Share Posted October 16, 2010 If you do that remember to take the jeep insignia off and replace it with a Toyota insignia. Link to comment Share on other sites More sharing options...
Geonovast Posted October 16, 2010 Share Posted October 16, 2010 How could it possibly stretch past being floored? Even if flooring it stretched the cable, it would only stretch to the point of still being WOT. You would have to push the pedal through the floor, stretch the cable out, then fix the hole in the floor. Link to comment Share on other sites More sharing options...
carnuck Posted October 20, 2010 Share Posted October 20, 2010 hornmrod where can i find that visor like u did I have one but it's in with the stuff for my '87 MJ shortbox I'm selling for $2500 (for $500 more you can have an AMC 360/T18A/NP208 combo to go with it!) Link to comment Share on other sites More sharing options...
