Spare tires
i keep a full size spare 265/75/16 in the bed of my chevy and it doesn't move around all that much unless its been raining, even when I'm out in the woods... i guess theft could be an issue, but my spare rim is so rusty it will make you need a tetanus shot if you get within 2 feet of it :rotf: ... 300k miles worth of riding under the truck will do that though... i would have left it there but with the dual pipes it doesn't fit anymore.... i guess the next best thing would be to get one of those baja truck tire mounts that bolts to the bed..
yeah. If you have a roll bar, ive seen some mounts where you bolt the spare onto that. or you could do something like CW and mount it to a custom tailgate.
something like this:
thats what i would do, in that order. rollbar, or tailgate.
Ya i thought about doing the tailgate but i really don't think i could do that i really would like to do it tho.
Mine is in the bed strapped down. I don't think a worn out 37 will get stolen but if I were worried I guess I could use a cable lock on it.
Why don't you leave it under the MJ until for DD duty and then strap it in the bed for offroad use.
I go wheelin all the time so i don't want to have to get out of my truck and mess with it all the time.
Best place I ever ran it.
How did it stay up there.
You know how everyone complains about re-using leaf spring U-bolts?
Well they still work pretty good to support your tire to a round tube. :smart:
That was also a great place to put the high-lift. (you can kinda see it in the pic)
I used two reinforcing plates that go on the spring plates (shaped like this"_n_" ),
I sandwiched two together, open end to open end (forming a pretty heavy duty sleeve), bolted both of them (also with U-bolts) to the roll bar, and the high lift slid right into the opening.
I could've even put a padlock on the jack if I was worried about someone grabbing it.
  • 12 years later...
After lots of planning and thinking of different ideas, I mounted a Rugged Ridge Spare Tire Carrier Mount for the YJ/TJ to the top front rail of the bed. This standoff position also lets my soft topper fold down behind the spare.
