wannabeMJ Posted March 27, 2010 Share Posted March 27, 2010 here it is I have this trany that I took out of the comanche with the 2.8L but it looks alot like an AX-15 but It was supposed to be the BA??? anyway I'm not quite sure but if so Ill keep it instead and looks like I got the same one on the donnor (cherokee 90) Image Not Found Link to comment Share on other sites More sharing options...
Pete M Posted March 27, 2010 Share Posted March 27, 2010 If it came from a 2.8L, then it'll be an AX-5, the baby brother to the AX-15. :thumbsup: Neither the AX-15 or the BA-10 can be bolted to the 2.8L. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 27, 2010 Author Share Posted March 27, 2010 what's gonna be the differences betwen the ax-5 and the ax-15 cuz the one under the cherokee looks alot like it Link to comment Share on other sites More sharing options...
Pete M Posted March 27, 2010 Share Posted March 27, 2010 the AX-5 bolts to the 2.5/2.8/2.1L engines. The AX-15 bolts to the 4.0L. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 27, 2010 Author Share Posted March 27, 2010 so will it be an AX-15 under the cherokee? Link to comment Share on other sites More sharing options...
Eagle Posted March 27, 2010 Share Posted March 27, 2010 Under a 1990 Cherokee, it will be an AX-15 if the engine is a 4.0L and it will be an AX-5 if the engine is a 2.5L. Aside from the AX-5 being weaker than the AX-15, the input shaft is smaller in diameter (which no doubt contributes to its being weaker) and may be a different length. Link to comment Share on other sites More sharing options...
Geonovast Posted March 28, 2010 Share Posted March 28, 2010 The AX-5 is comparable to the AX-15 the same way the 2.5 is comparable to the 4.0. The 2.5 is basically the same motor as a 4.0, but with 2 cylinders hacked off. The AX-5 looks very similar to the AX-15... it's basically the same transmission, just everything in it's smaller, so it's not as strong. The AX-5 was used behind the 2.5L I4, 2.8L V6, and 2.1L Turbo Diesel I4. AX-15 was used behind the 4.0, and 258 in 89-90 YJs. The ones used behind the 2.5 and 2.8 are the same, they even use the same bellhousing. The one used behind the 2.1 is essentially the same transmission, although it used a different bellhousing, input shaft, and bearing retainer. The AX-5 used a cast iron midplate, while the AX-15 has an aluminum one. And yes, the AX-4 is literally identical to an AX-5, except it's missing the pieces for a 5th gear. Link to comment Share on other sites More sharing options...
wannabeMJ Posted March 28, 2010 Author Share Posted March 28, 2010 thanks as I looked at the pix you posted up of the ax-5 I can see where the bolt is for the stick on top it is the same as mine so perfect Link to comment Share on other sites More sharing options...
87 Comanche dude Posted February 7, 2025 Share Posted February 7, 2025 87 MJ 4.0L 5 speed manual. So I now see I have an AX-15 tranny. THANK YOU!! where are the fill and drain plugs located? thanks!! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 7, 2025 Share Posted February 7, 2025 87 MJ didn’t come with an ax15 but it may have been swapped. BA10 was the standard behind the 4.0 up to around 89 Link to comment Share on other sites More sharing options...
87MJTIM Posted February 7, 2025 Share Posted February 7, 2025 For an AX15, the fill plug is left side toward the top. Drain plug is on the right side lower. Be sure you can open the fill plug BEFORE draining the fluid. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 8, 2025 Share Posted February 8, 2025 2 hours ago, 87 Comanche dude said: 87 MJ 4.0L 5 speed manual. So I now see I have an AX-15 tranny. THANK YOU!! where are the fill and drain plugs located? thanks!! Unless your transmission has been swapped you will have a Peugeot BA10/5. Here is a thread on how to tell the difference. Link to comment Share on other sites More sharing options...
