one_bad_MJ Posted March 10, 2010 Share Posted March 10, 2010 whats a good winch to go with for a comanche? 4000lb 6000lb 8000lb I'm going to aka custom bumper here this spring fir it and i want a winch, i don't want over kill just enough to give a good tug if I'm saddle bagged. and really stuck i was thinking of going with a 6000lb winch sound good? Quote Link to comment Share on other sites More sharing options...
MjAllTheWay Posted March 10, 2010 Share Posted March 10, 2010 not an answer but i went with the smittybuilt 8k seems good for me might be over kill but price was good Quote Link to comment Share on other sites More sharing options...
jimoshel Posted March 10, 2010 Share Posted March 10, 2010 A 6K should be adequate for a MJ. My personal rule is the winch capability should be twice the wt of the load to be pulled. Don't forget a pulley block and a tree strap. Quote Link to comment Share on other sites More sharing options...
Geonovast Posted March 10, 2010 Share Posted March 10, 2010 A 6K should be adequate for a MJ. My personal rule is the winch capability should be twice the wt of the load to be pulled. Don't forget a pulley block and a tree strap. By that rule, he should go with an 8k. A mildly built 4wd 4.0 MJ with driver should easily hit the 4,000lb mark. Quote Link to comment Share on other sites More sharing options...
89eliminator Posted March 10, 2010 Share Posted March 10, 2010 i would never get one under the 8k range. my Warn M8000 sometimes has its struggles depending on the pull. Quote Link to comment Share on other sites More sharing options...
jimoshel Posted March 10, 2010 Share Posted March 10, 2010 I based my answer on the fact that he keeps his tires properly inflated, which as we all know effects rolling resistance.Exception; If your high centered on a tree stump. :typing: I retract my previous statement. Go with the 8K, Quote Link to comment Share on other sites More sharing options...
cracker Posted March 10, 2010 Share Posted March 10, 2010 8K is the safe bet. Quote Link to comment Share on other sites More sharing options...
89eliminator Posted March 10, 2010 Share Posted March 10, 2010 I based my answer on the fact that he keeps his tires properly inflated, which as we all know effects rolling resistance.Exception; If your high centered on a tree stump. :typing: usually the only time when a winch is used is when you are stuck. tire psi has nothing to do with it. Quote Link to comment Share on other sites More sharing options...
Oizarod115 Posted March 11, 2010 Share Posted March 11, 2010 8k lbs is definitely minimum for a jeep. that weight rating is only for the first wrap of cable, so when the cable is fully extended (less leverage) it's actually got significantly less than 8k lbs Quote Link to comment Share on other sites More sharing options...
nitroxsteve Posted March 11, 2010 Share Posted March 11, 2010 8k lbs is definitely minimum for a jeep. that weight rating is only for the first wrap of cable, so when the cable is fully extended (less leverage) it's actually got significantly less than 8k lbs I thought you had more leverage with the cable fully unspooled (keeping the proper amount cable on the drum of course). Thats the first wrap of cable. Quote Link to comment Share on other sites More sharing options...
asm4mcc Posted March 11, 2010 Share Posted March 11, 2010 I HAVE A 9K AND YES THE MORE CABLE UNRAPPED THE PULLIN POWER AND THE CABLE WINES UP THE LESS PULLIN POWER THATS WHY YOU USE A SNATCH BLOCK SO U CAN PULL MORE CABLE OUT ITS LEES STRAIN ON THE WINCH Quote Link to comment Share on other sites More sharing options...
Geonovast Posted March 11, 2010 Share Posted March 11, 2010 You really need to take your caps lock off there, asm4mcc. Quote Link to comment Share on other sites More sharing options...
Oizarod115 Posted March 11, 2010 Share Posted March 11, 2010 whoops, got em-backwards :oops: my bad guys! Quote Link to comment Share on other sites More sharing options...
one_bad_MJ Posted March 11, 2010 Author Share Posted March 11, 2010 so 8k is the recommended size .. well if you had a 6000lb winch and double backed with a pulley it would pull the jeep out with half the effort. and if your triple pulley it you can do it by hand i seen that done on dirty jobs on discovery channel they pulled a stuck hummer h2 out by hand by a pulley system but i think they had like 6 or 8 lines through the pulley system Quote Link to comment Share on other sites More sharing options...
wyk Posted March 11, 2010 Share Posted March 11, 2010 so 8k is the recommended size .. well if you had a 6000lb winch and double backed with a pulley it would pull the jeep out with half the effort. and if your triple pulley it you can do it by hand i seen that done on dirty jobs on discovery channel they pulled a stuck hummer h2 out by hand by a pulley system but i think they had like 6 or 8 lines through the pulley system It all depends on the angle on the winch line. Less than a certain amount and the pulling force isn't quite as multiplied(a pully is a 'simple machine' in scientific terms - one of the six simple machines we use daily to get work done). Always carry at least _2_ snatch blocks with you - you can attach a block to the casualty vehicle to even out the load and modify or steady the angle you are pulling from. Always try to keep your line from spaghetti-ing(it will last much longer and have more pulling strength). Make sure you know how many strands your winch line has, and how much load you lose per strand if it frays in use(because, sooner or later, it will). Etc etc. Get the most powerful winch you can safely fit to your vehicle. Every pound of capacity it has over the required load is your safety factor. There is no such thing as having too much winch. Here's some of my cheat sheets I have from doing recovery work in Ireland and England: I have seen people use a purple AKA violet sling to slingshot a 4X4 with(which is not a good idea in the first place since sling-shotting means you have no idea how much strain the line is under unless you do the math for the acceleration of the vehicle as this adds to the force significantly vs a static winch line). It is only rated at 1 ton. If you follow the cheat sheets and do the simple math, you can see that one can get into a lot of trouble unless it is a significantly higher rated strap(and color guidelines are not necessary hard and fast - so read the rating). And you guys thought all us recovery guys were jis meth addicted punks ;) Know your equipment, and know how to use it. BE SAFE! WYK Quote Link to comment Share on other sites More sharing options...
-600JeepMJ Posted March 11, 2010 Share Posted March 11, 2010 :typing: great info!!!! I am going to print that out and keep it in my Jeep recovery tool box Quote Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 11, 2010 Share Posted March 11, 2010 The simple answer is MINIMUM winch cap is gauged by 1.5X the MAX vehicle GVWR its to be mounted on.... 8K works well for a MJ. Personally I have a 8K on the MJ and a 9.50K on the TJ. CW Quote Link to comment Share on other sites More sharing options...
comanchedude Posted March 11, 2010 Share Posted March 11, 2010 Thats stated backwards, fully extended gives you full pull power. the less exteneded the cable the less power. 8k lbs is definitely minimum for a jeep. that weight rating is only for the first wrap of cable, so when the cable is fully extended (less leverage) it's actually got significantly less than 8k lbs Quote Link to comment Share on other sites More sharing options...
Jeepman Posted March 11, 2010 Share Posted March 11, 2010 The simple answer is MINIMUM winch cap is gauged by 1.5X the MAX vehicle GVWR its to be mounted on.... Exactly... I run a 12000lbs Winch on my MJ as I would rather have a larger winch then needed.... Quote Link to comment Share on other sites More sharing options...
wyk Posted March 11, 2010 Share Posted March 11, 2010 Thats stated backwards, fully extended gives you full pull power. the less exteneded the cable the less power. 8k lbs is definitely minimum for a jeep. that weight rating is only for the first wrap of cable, so when the cable is fully extended (less leverage) it's actually got significantly less than 8k lbs The reason for this being the same reason you need lower gears when you increase your tire size. The further away you are from the center of the spin axis(wheel, winch) the less torque multiplication you have. Also, if you have a snatch block, always use that if you can VS winching directly back to your truck - this gives you more pulling power, is easier on your winch and makes it easier to keep the winch from tangling, and decreases the chances of your damaging the truck if the line or the hook point fail. If you guys have any questions regarding the winch cheat sheets, let me know. A remark I thought might be worth making is the grass in Ireland and England is usually far thicker and provides more rolling resistance than any of ours in the states do. So keep that in mind when using the ground factor chart. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
