I just got my results back from ASE, I am now officially certified in brakes and steering and suspension, passed both tests (only 2 i took) in november! jamminz.gif
which means a raise also. :cheers: :cheers:
so... if you need your death wobbles, alignment, klunking and other miscellaneous suspension, steering and brake issues worked out... ASK EAGLE :bowdown: cause IDFK. :waving:
:cheers: :cheers: woot woot
Congrats
Mean i should get my results sooon
create a myase account and you can check online nov written test grades should be out dec 4-19 iirc.
ummmm....I got a WICKED shimmy in my front end from 13-18 mph, but only when it's wet outside. I'm runnin' a LP D30 with a Rusty's trackbar, two stabilizers, slotted rotors, F150 coils with the last coil wrap cut off (did it with my sawzall and a 12-pak, Hell's yeah! jamminz.gif ), and YJ brake lines and I can't get rid of it!
What do you recommend???? I'm thinkin' of flipping the Gabriel gasmatics over and adding a couple pounds of airsoft pellets to the front tires to see if it'll help. Think it'll work?
edit: airsoft pellets are on backorder at JC Whitney (must be 'cause of Christmas or something, IDK). I can get a contractor pack of 3/8" hex nuts (should I go grade 5 or 8????) from Lowe's and try them if you think that'll work :dunno:
j/k.....congrats on your certs :cheers: You can never have enough knowledge.
Jeff
good job man, i got my ase certifications mainly for the customers to see it on the wall. i've seen some inept mechanics with master tech certification. :nuts:
Good job. :thumbsup: . Been ASE Master for 20+ years. Some guys will give ya crap about it in this business. Probably 'cause they couldn't pass them. Keep on taking them until you have them all. And the recerts are cake.
