Mystery Clip. Anyone know their electrical connectors? (Pic)
Say, does anyone know where this clip goes? It's right by the master cylinder. It's not very long at all. It has a yellow/black wire and a violet/white wire. It seems to be all apart of the harness going into the cab. Where it goes from there is beyond me but before I go crawling under there, perhaps someone here could shine some light onto this for me.
See pics here:
It is indeed for the low washer sensor however, it wasn't solely related to the sentry system. Different trim packages had it and the low fluid indicator is located right beside the check engine light on the warning light cluster. The XJ donor I used had it so I'll be able to hook up the sensor from my 97+ washer tank. It's power source comes from, of all places, the radio fuse.
:cheers:
Yep. When I installed the 97+ XJ washer bottle mod, I extended the connector and plugged it into the new XJ tank inside the fender well; works great. Really a "must have" indicator since you can't see the washer tank anymore. :eek:
Nice Avatar Don...The Surgeon General recommends that Dog's don't smoke too!!! :cheers:
Yeah, I know Wade. That's my dog Gus the Cocker, and he's really gone over the edge since I had him neutered. He's not only attacking coyotes three times his size, swimming out in the lake and bagging the Canadian geese from underwater, now he's sneaking smokes. I caught him at it in the backyard, snapped a pic, and since he constantly stares at my monitor while I'm on CC (he's an MJ lover too), I figured if he sees his disgusting image as my avatar, he might change his ways. It's not working so far..........he's still smoking. I think he's getting his cigarettes from my neighbor. :chillin:
Don, That's just too funny... :rotfl2:
These connectors get really corroded, so clean the two contacts up real good with contact cleaner. The tank low level float is a NO switch, so short the two connector pins together and it should illuminate your cluster indicator bulb w. the IGN ON. If I remember correctly I had to install a new bulb in the cluster indicator panel; there wasn't a bulb there.
