Comanche Limited
I finally got around to installing my Scarfab hitch. Thank you Brandon Scarbrough for this extremely well made hitch. It fit perfectly. But I do have a few issues that have nothing to do with the hitch.
First off, my truck was originally rear bumper delete. And evidently this means that they don't tap the holes for the bumper with threads. I started trying to tap the first hole, and was having issues keeping it straight doing it in the tight confines under the bed. Long story short, I broke the tap off in the hole. That stopped my work on it Saturday after work. So off to Lowe's to buy a new tap... I got two just in case.
So today after work I started again. The new tap has a larger square drive on its end that ended up fitting perfectly into a 9mm socket, that I then put on an air wratchet. The remaining holes were done in 2-3 minutes with that setup. And the hitch installed no problem. I'll have to deal with the broken tap later though.
My next issue has to do with the XJ Cherokee rear bumper I installed years ago. I have interference issues with the hitch and the bottom of the bumper. It looks like I should be able to just cut a couple notches in the bumper and be good, maybe add some spacers to the bumper mount. I'll figure it out, but it's just taking a little longer than I thought. Again at no fault of the hitch.
Here are some pictures. The first one is hard to see, but it shows the smooth bore untapped holes.
  • Replies 93
  • 3 weeks later...
I have the front bumper off now to install a front hitch I got for Xmas 2 years ago. And this last Xmas I got a Smittybuilt front bumper light bar..... Made for a Smittybuilt bumper. While the stock bumper is off I'm going to modify and install the light bar before putting it all back together. I'll have pics next week. Then when it's all together I can install the Hella lights I got 3 years ago!
  • 3 weeks later...
On 1/24/2020 at 9:21 PM, dasbulliwagen said:
I got the bar welded up, and then sprayed it with bedliner so that the texture finish on the Smittybuilt bar and the bars I added would all match and be even. I did a test piece with red paint over the bedliner and the paint didn't seem like it wanted to fully cure, so it was scratched. Anyways here's the finished product. Next step is lights!IMG_20200226_171527790.jpg.41519b923f23e816418d5456fdc5ff5b.jpgIMG_20200226_164645681_HDR.jpg.ab7f28c3eedbb2e75cf1241fb2e075aa.jpgIMG_20200226_164628861_HDR.jpg.3cac0801dc32d8d57f07dd4c7c918938.jpgIMG_20200226_164757855_HDR.jpg.8905a10c81f48072c2da00b6957210cc.jpg
  • 3 weeks later...
  • 1 year later...
  • 3 weeks later...
  • 4 months later...
Time for an update. I pulled the bench seat out of it to send it to get recovered. My friends dad is now working with an upholstery guy, so I'm going to get him to recover it. Ill be going with new black vinyl, with red stitching and maybe a diamond pattern stitched inset. While the carpet is out, Ill be laying down some generic dynomat, New carpeting to replace the torn up rubber floor, and installing the cable front axle disconnect. Ill load pics of the seat out later for some before pics, and more pics once I dig farther into it.
  • 1 month later...
The bench has been sent out to get done, and the old rubber floor has been pulled out. You guys are right about these rusting from the inside out. The only rust on the whole truck is on the interior floors! I bought stuff to get them cleaned up and coated, and then ready to lay down some sound deadening material. I'll have more pics as progress happens.
  • 1 month later...
