1989 Mj
4.0 5 Speed 4x4
Rusty's spring pack 4.5"
Homemade Bumpers/ Airtank front bumper
OBA,GPS,CB
Black Rock 16x8 4.25" BS
Toyo open country A/T 265-75-16
I'm not much of a talker, and I know y'all are just her for the pics...So I'll let them speak.
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
So what do y'all think?
Thanks for all the positive feedback. I still have a metric ton of stuff to do to this rig.
The list:
Skids
Swing out tiregate
In cab guage for the OBA
Double sheer Track bar and mount( I don't trust the rusty's one ).
Alignment
Cherokee doors
Bed liner the inside cab and bed
Maybe bucket seats
winch setup
The list goes on and on...
Ps. The only thing the dog will fetch is 8 foot long tree branches. Not kidding :nuts:
I don't have any new pics of the truck. Work has been to busy, But I have some work pics ya'll can stare at. BTW thats all Stainless :D
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
I work maintencace for a company that paints military vehicle parts.
The first pics are of a washer we built.
The outhers are of a paint pump I built.
-gary
When I first got my 4.5 packs from Rusty's my rear sat REALLY high, WAY over 4.5 inches.
This is even after I took the lowest leaf out of them:
Now the leaf is back in. After two years and alot of loads of firewood I'm probably now riding at the advertised 4.5 height... Some guys on here are having problems with them breaking, so far mine have held up OK and they are nice and supple for good articulation.
Truck looks good, all the Best on the rest of the buildup.
- Brent
- Brent
Thanks for the info. Your Mj look very nice doorless. :thumbsup:
Well I recieved my full guage panel I got off e-bay. It was advertized as 88 to 91, and it is a 92 to 96. :mad:
Mine
Image Not Found
The wrong one
Image Not Found
Side by side
Image Not Found
I am so pissed right now. I already had the new sending units. :fs1:
Obviously he has no idea what he is talking about. You need an '87 to '90 cluster. A '91 cluster is not the same as the '87 to '90 clusters. :nuts:
Willy
Some pics of the OBA setup. It consist of a some twin cylinder belt driven compressor my boss gave me. It does real well, and it stays pretty cool. The check valve and relay/pressure switch are from viair. 85 PSI on 110 PSi off. Front bumper is my tank. I still want to get a air manofold to clean everything up.
Image Not Found
Image Not Found
Image Not Found
Where it enters my bumper
Image Not Found
Some more poser pics :D
Image Not Found
Image Not Found
Image Not Found
-Gary
Do you plan on adding protection for your front corners?
No not at the moment. Basically anything I encounter on a front corner will hit the tire first, or it will hit the center bumper section which is nice for my approach angle. I would like to add a center skid plate to protect my draglink and swaybar. I am more concerned with high centering it. I need to fab up some rocker armor.
-gary
Here is some more pics. I finally got my gauges. Some shots of me wheeling with my buddy in his bronco.
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Well more pictures... I took a page from CW's book. Hope ya don't mind.
Imatation is the Blah blah blah. ;)
On to the pics
Swing out tailgate.
Image Not Found
Image Not Found
Checking for fit.
Image Not Found
Image Not Found
Image Not Found
I am pretty happy with it. I need to mount it and check everything. Then I can take it back to work to have it sandblasted and painted.
And here is some tool porn. :D New tool crib at work.
Image Not Found
Image Not Found
-Gary
Ok. I started another project ( like I needed one ). It's a cargo basket that fits flush in between the bed rails. I made it so I can store all my gear and haul wood at the same time.
Kinda like a roof rack for the bed. Still need to put a floor in it and have it blasted and painted. I really wanted to get rid of that POS plastic toolbox.
so here is the pics.
55"X24". 3/8 poop pipe. 2"X1/4" Flat.
Image Not Found
Image Not Found
Image Not Found
Image Not Found
So what da ya'll think? :thumbsup: Or :no:
Sorry about the crapy pics.
-Gary
So I blasted and painted the rack thing last night.
Set it in place. I'm pretty happy with it.
Pics
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
-Gary
Finished the rack thing install. I used 3/8 eye bolts so I could use them a tie down points.
I had some help from my lovely wife :D
She even changed the oil :bowdown:
Image Not Found
Image Not Found
-Gary
  • 2 months later...
Just a update since it has been a while.
The beast is down for maintenance. The pukegoet slave finally gave up the ghost.
So I am in the process of doing a lot of work to it.
New slave cylinder
New clutch master
All new lines
Clutch plate
Pressure plate
All new u-joints in both shafts
New lower shift boot
Some exhaust work
I found a freeze plug leaking. So I am installing a block heater in its place.
Pic
Image Not Found
IRO adjustible double sheer track bar and bracket
Viair OBA guage panel
Hopfully soon I will have this thing on the road.
