jeepaholic Posted August 21, 2006 Share Posted August 21, 2006 I was originally gonna go w/ 35's but i can get 36's cheaper..I don't want to cut my fenders so how much lift am i gonna need..I am at or around 8" as of now. :cheers: Link to comment Share on other sites More sharing options...
87manche Posted August 21, 2006 Share Posted August 21, 2006 they should fit, depends on what whees you have and the backspace. 8" is way high. Link to comment Share on other sites More sharing options...
JOMJ87 Posted August 21, 2006 Share Posted August 21, 2006 I would mount them up and flex the jeep to see if you have any clearance issues and if you do raise it an inch or so to clear. But they should fit good with 8" Link to comment Share on other sites More sharing options...
jeepaholic Posted August 21, 2006 Author Share Posted August 21, 2006 I was going w a 36x12.50x15 mounted on 10" wheel w/ say a 3 1/2" backspacing. Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 21, 2006 Share Posted August 21, 2006 You'll hit fender, unless you bumpstop the hell out of it. Those tires are too wide to fit inside the fenders... Afraid of a little trimming? Link to comment Share on other sites More sharing options...
jeepaholic Posted August 21, 2006 Author Share Posted August 21, 2006 Not afraid of trimming just would rather go with the jacked up stock look on this one..Shouldnt a 3.5 BS help eliminate the rubbing..Not during flex but during turning.. Link to comment Share on other sites More sharing options...
M357.5 Posted August 21, 2006 Share Posted August 21, 2006 I am running 36x13.50 Swamper IROK's on 15x10 AR's with 4" BS.....and my rig has about 8" lift in it. My tires still rub , and my fenders are cutout right upto the body line......I should be useing a longer bumpstop than the Rubicon Kit came with. I just let it flex until the tire pushes the body out of the way LOL.........You might be OK if your rig's axels are stock width , my rig is 83" wide from outsie of tires with the full width F150 axels. :D Link to comment Share on other sites More sharing options...
jeepaholic Posted August 21, 2006 Author Share Posted August 21, 2006 I am currently runnin d30 front and a 8.25 rear...prolly gonna go to the 8.8explorer in the rear to have disc brakes....I know i am fixing to hear 36's won't work w/ these axles...pffffft...I have been running 33 hawgs on my stock cj axles for over almost 30yrs..Yes it still has the amc 20...Everyone says it won't work..I say it works till it breaks. Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 21, 2006 Share Posted August 21, 2006 D30's love 35s. Image Not Found Link to comment Share on other sites More sharing options...
jeepaholic Posted August 21, 2006 Author Share Posted August 21, 2006 parts is parts :eek: worked till it broke though didnt it.. :D Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 21, 2006 Share Posted August 21, 2006 All two weeks. Link to comment Share on other sites More sharing options...
BRC 88MJ Posted August 21, 2006 Share Posted August 21, 2006 parts is parts :eek: worked till it broke though didnt it.. :D A true statement if you're really good at changing gears and LOVE to do it all of the time..... Link to comment Share on other sites More sharing options...
JOMJ87 Posted August 21, 2006 Share Posted August 21, 2006 I have stockers and 35s. I ran all over tellico until my tire ruptured 7 hours into the trip and i didnt have a 35 spare so it ended my day Limping out on the stock spare :oops: :eek: And yes everyone laughed. never broke anything else then and its 2 years later and nothing still hasnt come apart and i even have lockers now. Cole Link to comment Share on other sites More sharing options...
Pete M Posted August 21, 2006 Share Posted August 21, 2006 I'm on the other end of the spectrum. I killed a Dana 35 on 30" tires and street driving. :D Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 21, 2006 Share Posted August 21, 2006 my brothers got 33s on his 35 with a loc-rite and we were wheelin the livin #%# out of it yesterday.. 4lo at about 3k rpm tryin to make up a wet rock/mud hillclimb :dunno: Link to comment Share on other sites More sharing options...
pingpong Posted August 21, 2006 Share Posted August 21, 2006 If yo9u build it right it can survive that size tire, as long as you don't hit the skinny pedal often. I broke a yukon alloy on 35's though :driving: Superior just came out with a super 38 kit, that eliminates the c-clips and gives you alloy shafts. Its suppose to be good for up to 38's Link to comment Share on other sites More sharing options...
M357.5 Posted August 21, 2006 Share Posted August 21, 2006 Wasnt a question about breaking runnin 36's on stock 30/35.......you asked if they would rub without cutting fenders. I was just letting you know that my rig has full width axels and therefore rubs with 36's even with the majority of the fenders cut off.......you may have less rubbing with the stock width axels than my rig does. My 35's only rubbed a little with the stock width axels and minor fender trimming.....with aprox 8" lift :D won't know till you try , I say go for the 36's Stock Jeep parts that couldnt handle the punishment of my right foot include 1) D30 axel shafts 2) D35 axel shafts 3) D35 ring and pinion 4) NP231 5) 3 peugeot BA10's 6) Rear drive shaft.....pretzled 7) TOO many D30 unit bearing hubs to count......they don't seem to like 35" tires on 10" wide rims. Broke lots of other stuff too , but these are the main driveline problems. Link to comment Share on other sites More sharing options...
jeepaholic Posted August 22, 2006 Author Share Posted August 22, 2006 I'm going 36's..they are cheaper than 35's...If i have to i will just lift it more..I need some 15x10 wheels w/ 3.5 or 3.75 backspace if anybody knows of some lemme know. :popcorn: Link to comment Share on other sites More sharing options...
pingpong Posted August 22, 2006 Share Posted August 22, 2006 Q-tec or $wd hardware always has them. I think a set of 15x8 cragar soft 8's were less then 120 to more door about a yr ago Link to comment Share on other sites More sharing options...
jeepaholic Posted August 22, 2006 Author Share Posted August 22, 2006 don't you think i ought to go w/ 15x10 rather than 15x8?? Link to comment Share on other sites More sharing options...
Pete M Posted August 22, 2006 Share Posted August 22, 2006 Used tires/wheels are best. :D Link to comment Share on other sites More sharing options...
sinnaevd Posted August 22, 2006 Share Posted August 22, 2006 not eveyrone find the deals you do pete, maybe you could chare the wealth lol! i tried grabbing a used set of 31's from the scrappe and they wanted 350 for the set!!! i think he's sniffing crazy glue... Link to comment Share on other sites More sharing options...
Pete M Posted August 22, 2006 Share Posted August 22, 2006 It just takes some patience and a bit of footwork. Well, ok, there's probably a bit of luck involved, but then you'd have to consider me "lucky" because I'm unemployed and have all the time in the world to drive hours away from me to buy/sell stuff. :driving: Link to comment Share on other sites More sharing options...
jeepaholic Posted August 22, 2006 Author Share Posted August 22, 2006 195$ a pc for 36 tsl's doesnt sound too bad..i paid that for my 33 ground hawgs on my cj 8 years ago...all the used tires i find have so much rock rash on em they look like an abortion lug pattern. Link to comment Share on other sites More sharing options...
feerocknok Posted August 23, 2006 Share Posted August 23, 2006 don't you think i ought to go w/ 15x10 rather than 15x8?? A 12.50'd be fine on an 8" rim, and, "from what I understand", will be able to hold a bead at lower pressure than the 10" rim will. I wish I had the money to go out and test random shtuff. Link to comment Share on other sites More sharing options...
