Deleted user Posted May 11, 2009 Share Posted May 11, 2009 Does anyone know where i can fing aftermarket exhaust. my exhaust is shot and rusted apart. is there something i can get after market or am i breaking ou tthe welder and sawzall? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 11, 2009 Share Posted May 11, 2009 Most of us have built our own. Using our muffler of choice and a stock tail pipe. In my case, I have no tail pipe over the axle. mine exits in front of the rear wheel, but in the wheel well. Cherry bomb glass packs are a favorite, they are not too loud when new if the stock cat is kept. They are WAY durable!! CW Link to comment Share on other sites More sharing options...
Deleted user Posted May 11, 2009 Author Share Posted May 11, 2009 any idea where i can get a stock tail pipe? Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted May 11, 2009 Share Posted May 11, 2009 You can find a stock tail pipe at NAPA or others auto'S store. :wavey: Link to comment Share on other sites More sharing options...
Pete M Posted May 11, 2009 Share Posted May 11, 2009 Keep in mind when looking for tailpipes that longbeds are different than shortbeds and both are different than Cherokees. Link to comment Share on other sites More sharing options...
Deleted user Posted May 11, 2009 Author Share Posted May 11, 2009 ok so i checked online at advanced auto parts tail pipe http://shop.advanceautoparts.com/webapp ... 5487736___ exhaust pipe http://shop.advanceautoparts.com/webapp ... 5471137___ then all i would need to do is pick out the muffler i want and this would be real close to stock? can anyone check on this for me. I need this truck to be as quiet as possible.... Link to comment Share on other sites More sharing options...
Deleted user Posted May 11, 2009 Author Share Posted May 11, 2009 oh yeah one thing i forgot to check when i was posting the websites (which i will check prior to ordering parts) was if they were for a long bed or short. i just put those up there to see if there was anything else you guys could think of that i would need to replace the whole exhaust minus the converter (no inspections in florida :D Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 12, 2009 Share Posted May 12, 2009 rdjustham said: ok so i checked online at advanced auto parts tail pipe http://shop.advanceautoparts.com/webapp ... 5487736___ exhaust pipe http://shop.advanceautoparts.com/webapp ... 5471137___ then all i would need to do is pick out the muffler i want and this would be real close to stock? can anyone check on this for me. I need this truck to be as quiet as possible.... In this case, I would just buy the best factory replacement the parts store had. Most likely a Walker system. CW Link to comment Share on other sites More sharing options...
Deleted user Posted May 12, 2009 Author Share Posted May 12, 2009 will i need both the tail pipe as well as the exhaust pipe is one different from the other? ive never done a full exhaust Link to comment Share on other sites More sharing options...
BJA814 Posted May 12, 2009 Share Posted May 12, 2009 A good local parts store should have an exhaust catalog with pictures of the exact pipes. Link to comment Share on other sites More sharing options...
Wildman Posted May 12, 2009 Share Posted May 12, 2009 Check this link, it will give you the Walker page on the MJ, with Walker part #'s http://info.rockauto.com/Walker/Detail. ... 8-2643.jpg also.......you mentioned some thing about not installing a Cat. If you don't you need to make up a "test" pipe in place of the Cat. Mine, I run the Cat w/o sniffer tests up here, plus with the 4 bolt square flange, it all bolts together easier. Link to comment Share on other sites More sharing options...
OSHAGNASTY Posted May 12, 2009 Share Posted May 12, 2009 autozone for like 30 bucks u can get cherry bomb glasspack and find some old extral exaughst tube make ur own Link to comment Share on other sites More sharing options...
Deleted user Posted May 19, 2009 Author Share Posted May 19, 2009 i could just put a cherry bomb on it but i need it to be quiet so i can hear my dogs barking aways off Link to comment Share on other sites More sharing options...
ratrapp Posted May 19, 2009 Share Posted May 19, 2009 i had a dynomax superturbo on mine for a few years.it was alittle louder than stock but not so loud it was annoying.they're not real expensive.on the same note i like loud exhaust so i went back with a flowmaster 2 1/2 and 2 1/ 2 aluminzed tailpipe and high flow catco converter. Link to comment Share on other sites More sharing options...
philbert001 Posted May 19, 2009 Share Posted May 19, 2009 ratrapp said: i had a dynomax superturbo on mine for a few years.it was alittle louder than stock but not so loud it was annoying.they're not real expensive.on the same note i like loud exhaust so i went back with a flowmaster 2 1/2 and 2 1/ 2 aluminzed tailpipe and high flow catco converter. I have seen the dynomax setups with muffler and tailpipe, 2 1/2 inch on summit racing for like $100. If you go with one, let us know how you like it. I have thought about picking one up for my ZJ, as I'm gonna steal my supertraps off of it for the small block ford MJ. Good luck! Link to comment Share on other sites More sharing options...
ratrapp Posted May 20, 2009 Share Posted May 20, 2009 i put the dynomax catback on the gf's 95 4.0 zj and it fits and sounds great.it definitly doesn't sound stock. Link to comment Share on other sites More sharing options...
Deleted user Posted May 20, 2009 Author Share Posted May 20, 2009 i definately need to go cat back but i need somthing closer to stock and as QUIET as possible....... Link to comment Share on other sites More sharing options...
