Darren Posted October 11, 2008 Share Posted October 11, 2008 i was working on my idle issues when i noticed a gap in between the head and the threads. lifted right out. how should i go about fixing this? please don't tell me i need a new intake manifold. how can i get that out? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 11, 2008 Share Posted October 11, 2008 you need a new sensor for sure, and to get that out you need to use a tool that's threaded backwards and fits in the inside of the broken part in the manifold. I cannot for the life of me remember what the tool is called, but places like advanced and Menards have them (especially if you go to the plumbing section and just ask the team member what they'd suggest) Link to comment Share on other sites More sharing options...
xj_dummy Posted October 11, 2008 Share Posted October 11, 2008 WOW, it must be an omen. I to am having sensor problems. Link to comment Share on other sites More sharing options...
Darren Posted October 11, 2008 Author Share Posted October 11, 2008 thank you Link to comment Share on other sites More sharing options...
shelbyluvv Posted October 11, 2008 Share Posted October 11, 2008 E Z Out Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 11, 2008 Share Posted October 11, 2008 E Z Out yea, that. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 11, 2008 Share Posted October 11, 2008 That same thing happened to me a few years ago and I used an EZout to remove it. But since the sensor bulb where the EZout will be biting into the soft brass bulb sensor housing, it ate thru the brass and buggered up the pipe threads in the head. So I had to drill it out and re-tap it, then install a new 1/2" NPT to 3/8" NPT brass bushing. Not a big deal, but there's not much room to work in back there............... 8) Link to comment Share on other sites More sharing options...
IDXJ Posted October 11, 2008 Share Posted October 11, 2008 If you work GENTLY you can get it out with a hacksaw blade. I do this a lot with brass sprinklers in Alum. pipe. Take just the blade from a hacksaw and make a cut in one spot the length of the fitting. Cut it as far as the threads. Do the same thing about 15 degrees away same as the first cut. Then use a small chisel and hammer to knock that small section out of the threads. That will allow you to unscrew the rest of the broken fitting without messing up the threads. Good luck. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 11, 2008 Share Posted October 11, 2008 If you work GENTLY you can get it out with a hacksaw blade. I do this a lot with brass sprinklers in Alum. pipe. Take just the blade from a hacksaw and make a cut in one spot the length of the fitting. Cut it as far as the threads. Do the same thing about 15 degrees away same as the first cut. Then use a small chisel and hammer to knock that small section out of the threads. That will allow you to unscrew the rest of the broken fitting without messing up the threads. Good luck. Sounds like an excellent plan of attack. I'll file this away for future use. Thanks! :cheers: Link to comment Share on other sites More sharing options...
aemsee Posted October 11, 2008 Share Posted October 11, 2008 Well, at least you found your idle issue. Remember to make sure none of the pieces go in to the manifold. Link to comment Share on other sites More sharing options...
ejndssn Posted October 11, 2008 Share Posted October 11, 2008 Well, at least you found your idle issue. Remember to make sure none of the pieces go in to the manifold. or have a very good vaccume to get the pieces outs :brows: Link to comment Share on other sites More sharing options...
knightrider Posted October 11, 2008 Share Posted October 11, 2008 left hand drill bit. don't know if you can find one large enough. should make easy work of the brass. Link to comment Share on other sites More sharing options...
Darren Posted October 11, 2008 Author Share Posted October 11, 2008 what is that sensor called? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 11, 2008 Share Posted October 11, 2008 I believe it's yout MAT Link to comment Share on other sites More sharing options...
Darren Posted October 11, 2008 Author Share Posted October 11, 2008 MAT? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 11, 2008 Share Posted October 11, 2008 Manifold Air Temp. That is your intake manifold right? Link to comment Share on other sites More sharing options...
Darren Posted October 11, 2008 Author Share Posted October 11, 2008 yes pulled out of the back of my intake. Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 11, 2008 Share Posted October 11, 2008 Yep, that's what it is then. Link to comment Share on other sites More sharing options...
Darren Posted October 11, 2008 Author Share Posted October 11, 2008 gracias chico. Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 11, 2008 Share Posted October 11, 2008 No prob. When I changed mine out I couldn't find it anywhere around here though. I got mine from BLHTAZ. Link to comment Share on other sites More sharing options...
