Lost all Clutch Pressure
Check for dripping. Check under the truck under the bellhousing, along the clutch line running up to the master, and then in the engine compartment below the clutch master cylinder. If you find any nasty fluid, let us know. :thumbsup:
There are three possibilities: the slave cylinder, the clutch master cylinder, and the line/hose that connects them. I've not had a master blow out on my (yet), but I have had both a slave cylinder and a hose blow out on me while driving.
i had the same problem but it was the slave every morning i would fill up to get pressure becuase there would be none in the peddle after i drive it all day and then next morning have to fill again i had a small leak in mine i had a enternal on a ax-5
hang on...
you won't need to remove the transmission if you have an external slave, which could be the case if you have a 4 cylinder 5 speed, or if you have a newer ax15 in your rig.
just think about that...cause if you don't have to drop the trans, you'll be much happier
