ComancheKid45
    3
Everything posted by ComancheKid45
  1. Was working on it, I'm gonna get a "real" drill bit next and see if that helps, I have a set of brand new 1s but they would go about 1/3 way through and just stop, like the metal just was too hard for em and burnt em up :wall: . We spend plenty of time with a 10 pound sledge and a punch as well.....them suckers just wouldent budge :fs2:
  2. Yes, the lower Torx bolts for the sway bar. I have already cut off both sides flush with the axle mount but we cannot seem to get the centers to come out. I had zero issues with these on my 88 MJ and these were giving us all kinds of fits on this Cherokee... Ill try and snap a pic today if I meet up with him again. thanks!
  3. Would be great, but both sides have been cut and grinded flush with the mount. Is it possible that they are tapered and can only be hammered out from the inside-out?
  4. Alright, this isnt my problem but 1 for my friends 99 XJ. Were attempting to install sway bar disconnects today and we can't seem 2 to remove the stock pins to install the new 1s. Weve tried everything from heat and Hammers to drills, and even with brand new bits we cannot even penetrate through those things. Is theyre any other options or tricks that maybe were missing? thanks for any help! :cheers:
  5. 1st Ive really looked into this thread but I'm impressed! keep it up :cheers:
  6. Got my 160amp "Powerhouse" installed this evening, as well as upgraded the wire to 4gauge. :wrench: The pic was taken just as i dropped it in, i did bolt it tight, unlike the pic shows :shake:
  7. Has turned out great! Ill keep track of this 1 :thumbsup:
  8. alright well it took alittle longer than planned but tonight I got my sliders welded on with help from a friend :cheers: Will be sure to get some daylight pics of them soon! My mayden voyage to Rausch Creek is coming on May 20th 8) Next up on the list is my 160amp Alt. and My new hood and vents. Stay Tuned :wavey:
  9. Rusty 2" Coils + 1.5" spacer front Hell Creek XJ 2" AAL + Shackle rear :wrench:
  10. Finally gave this fella some attention today, Hopefully with the cold weather gone I can now focus on giving this guy a nice coat of paint. I will be rolling/brushing on a color called Carmel, its a nice mellow Browish/tan and should go great on a primary work truck ;) I spent some time this evening removing the rest of the decals and glue left behind from the emblems. I hope to possibly have this thing painted this week sometime but we'll see.... I'm just glad for the nicer weather to acctually get to work on it. :clapping:
  11. I Still am a Fan of "BLHTAZ" truck :cheers:
  12. :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: Need I say more...
  13. Um, idk, theyre just standard shackles.... The 2" XJ shackle will net about 1.5" of lift on an MJ.....theyre nothing crazy. People run them all the time, and I netted about 1.5" of lift from them excatly when they were installed in 2008...
  14. Yep, thats about 3.5" of total lift. XJ 3" AAL (2" on MJ) + 1.5" shackle on the rear Rustys 2" Coils + 1.5" puck up front.
  15. Stock packs had 4 leafs, MT packs had 5
  16. I installed a 3" Hell creek XJ AAL and gained just about 2" of lift, combined with a 1.5" shackle and it got my truck sitting like this.
  17. Even the rears will work? :dunno:
  18. Well after another 20 mins troubleshooting @ 11pm I think i finally found the culprit. This orange wire had seperated, i quick fixed and twisted it back together and wa la the fuel pump came on and the truck ran again.....this was probably the problem all along, atleast I hope so. ill get it repaired properly this evening and go from there. sorry for the bad pic, but this was on the distribution block behind the battery.
  19. Is this something that would help out even with the Unibody bumper tie-ins?
  20. This is a very intermittent problem. Once its running it runs great but occasionally just while sitting at idle it stalls out and will not restart... I have bypassed the Ballast resistor and tested starting 6-8 times and each time the pump primes and the truck runs fine. I drove it 8 miles tonight, parked it applied the parking brake and it slowly stalled out and no longer had power to the pump to restart. Ill try to fire it up in a few hours to drive home. I'm really at a loss for this now, its very intermittent. I'm 90% sure its a fuel pump power issue but may just replace the CPS as well, it seems to be more of an issue after the truck is drivin and up to tempreture, cause itll sit there and idle all day long once up to 210+ degrees. :wall:
  21. Definently check the Crank Sensor and also the Ballast resistor. also check your TPS voltage. :wrench:
  22. And likely the same brainiacs that think this whole Ethanol blended junk is a good idea 2.... :rant: :fool:
  23. Uh Oh, lookie what Showed up Friday :yes: Yep, my Rocky Road Outfitters sliders :clapping: Should have them installed today! Stay tuned...
