ComancheKid45
    3
Everything posted by ComancheKid45
  1. Got my front lifted today :D Rustys (I know :dunce: ) 2" Coils, Rough Country Adj. LCAs and a Skyjacker track bar bracket completes the front setup Truck pretty much now sits 3" or a bit more over stock and I think I'm finally done with the suspension for awhile. Next on my list is a Locker for the D30 and revamping my hood :cheers:
  2. Id buy 4-6 cans of brake cleaner as well and spray out all you can while the cover is off the Diff. Otherwise thats about all there is 2 it, just hope with that many miles that noting big and metal falls out with the fluid
  3. ^^^^ :rotfl2: :doh: MY LCAs and springs are here :D Might work on installing those tomorrow...
  4. I have my 44 installed with about 3" of lift on the rear. the D35 Driveshaft is installed as well and has about 1/2" of clearence before bottoming out at ride height. Now the front is 2.5" lower and will be lifted accordingly withen the next week or so I figure so ill see how everything plays out then. For now I'm running my D35 shaft with my D44 and unless i load the crap outta the rear I don't forsee any bottoming issues :smart: :typing:
  5. Completed my D44 swap :D
  6. Its in an Driveable! :clapping: Front lift components should be here in a few days but for now ill run 2.5" higher in the rear, lol. The driveshaft has enough slip yoke clearence it seems with this setup but getting that trimmed down some in the future may be on my list as well. Next up after front lift install is an Aussie/Lockrite Locker in the D30 :yes:
  7. Installed my D44 and XJ AAL... :waving:
  8. 2" Springs and LCAs :thumbsup:
  9. Decided to tackle my Axle install tonight with a few friends and install my XJ 3" AALs while I was in there to see how much lift I could gain from them... Pulled out the old Turdy-five Ready to throw on the AALs D44 in its new home! :clapping: After all was done i gained right about 2" in the rear after the AAL, I'm sure itll settle some but i am pleased, I have LCAs and springs ordered for the front so ill be right over the 3" mark on lift which is where ive wanted 2 be for a long time. Need to replace 1 brake line tomorrow but otherwise Its all but done. Very productive evening :cheers:
  10. I WANT!^^^^ :drool: Awesome rigs there man, I'm jealous :thumbsup:
  11. Cover installed on the 44 :yes: Ready for install when i get a chance....can't WAIT!
  12. Decided it was time to replace this hazard before something bad happened. Ground Cable :ack: Stole 1 off the parts truck that was in much better shape...
  13. My Uncle has an 89 XJ Limited sitting @ his house with black leather seats but theyre pretty well trashed... :(
  14. Well almost every fluid in this thing was disgusting so today my mission was to change coolant, oil and tranny fluid. The 1st thing i noticed last evening when i went to change the thermostat was the coolant could have been mistaken for coffee! YUCK! I replaced the 180* themostat with an OEM 195, and flushed the whole system clean and refilled with something better than the brown crap that was in it. Oil and Tranny fluid wasnt much better and decided to throw on the tranny cooler while I was @ it. Next will be fix the door latch and get ready to patch the bad spot above the drivers rear wheel.
  15. Besides the blingy rims, i would acctually love to have an MJ like that for rippin around town. I'm not a fan of lowered trucks at all but the Street MJs were awesome :D
  16. A Nice coat of POR-15 for the D44 this evening :yes: My G2 Diff Cover hasnt arrived yet and I'm not wasting effort on painting the stocker, lol
  17. Your Defrosters and I'm sure a few other attributes will not operate without it....
  18. I have a Cover on the way for my D44 from a company called G2. Its designed similar to a Rock Crusher (whats on my current D35) but is made out of Aluminum. Rock Crushers were on 2-3 month backorder so i figured ill give this brand a try.
  19. My cousins boyfriend has an 89 XJ Limited. the trans is shot and it has many electrical issues. He plans to scrap it and gave me full roam to swipe anything I want from it...Score! :banana: Picked up some Gauges (and sensors), as well as a factory tranny cooler and also swiped the OEM clock. Might go back for another thing or 2 but not 2 much i can't already get from my parts MJ, lol 1st 1 of these ive ever seen in person. I like it :yes: Gauges all work great. next on the list is fluid changes, the coolant in this thing is disgusting!
  20. I work @ Advance, other end of town from Auto Zone, across from the Gulf Station :thumbsup:
  21. Opened up the D44 for inspection, Limited Slip equipt and all looks for inside for 197k
  22. The closed Cooling system is good as long as its working properly. a Tranny cooler is a good investment if you live in a place with Warm weather and do alot of towing/hard slow wheeling. Its an easy install as well. Also a friend and a welder will do alot better and safer work over that bolt on SOA kit. Welcome to the Madness of what is ComancheClub :cheers:
  23. Unless you convert the entire system to an open Cooling system i believe your stuck with that bottle...
  24. .01 off is fine to match up, should not have any issues. As for the Trannys. 87-90 2.5l MJs used the AX5 (AX4 4 speeds) I'm not sure if this changed for the 91-92 model years though. O Yeah, Welcome to the MJ madness which is ComancheClub :cheers:
  25. I'm not sure, I'm going to add an XJ 3" AAL to my pack during the axle swap, so that might net me 1.5" in the rear on top of my 1.5" shackle, At most Ill be 3" over stock, I was under the impression that you would need atleast 4" of lift for a D35 rear shaft to work with a D44. I have my current driveshaft and its still in good shape. I also have a D44 shaft but its from a LWB (that was the 1 i was gonna get cut). If my D35 shaft will work that would be great, but from what ive read itll need to loose an inch or so to prevent bottoming out..... :dunno:
