ComancheKid45
    3
Everything posted by ComancheKid45
  1. My 88. I have found 1 Driveshaft shop close by, ill be stopping by there this week likely, Seems like $60-$100 is the price I shoul be looking at for this service :dunno:
  2. D35 all set in its new home. I also added an extra leaf outta the parts truck to this 1 for alittle extra capacity. just need some spring clamps for the packs. Decided to shoot a coat of undercoating while i was under there, the brakes are bled and this truck is drivable again :D . Ive offically sucessfully completed my 1st Axle swap This will probably be it for this truck for a few days, my focus now turns to prepping the D44 for my 88 MJ :clapping:
  3. After all what do you think Synthetic "Blend" Oils are??? :chillin:
  4. That fitting is just a rear brake line. Look up 1 for a 95 Dakota if you plan on lifting or have already lifted your truck. Itll bolt right on and be a bit longer as well. Should be available through any parts chain (I know Advance has em) :thumbsup:
  5. Got the 44 out this evening, Will begine prep for installation hopefully within the next 2 weeks, Still have 2 get a Driveshaft cut down for it as well. Its moving along nicely
  6. Pulled my 44 from the truck this evening without any problems! :clapping: The cleaned up D35 sitting in place, will get it all buttoned up Saturday most likely. :banana:
  7. Finished the brake lines on my D35 donor......Possibly might start pulling the D44 from my 89 tomorrow evening :cheers:
  8. I have a LWB tank out that i can snap a pic of tomorrow, I'm sure theyre set up the same up top
  9. Year, Make, Model. 1989 Jeep Comanche Pioneer Image, if available Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0/AW4/NP231/D30/D44/LWB Build date: (its on the driverside door sticker, in the form of month and year) worn away :rant: Current Location: Region will do, state, and area of state. Shippensburg, Pennsylvania, South Central PA Status: Is it still on the road, is it in the junkyard? Project awaiting work? Project under way to give a still solid truck a new life Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. Full Factory Skids (Gas tank skid mia but mouts were still there), Loaded interior minus full gauges, Truck was orgionally black but paint is in rough shape. cloth bench seat with column shift. Basically a high end Pioneer package back from the factory Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. BJ Naugle (ComancheKid45)
  10. Alittle more Axle work this evening, New brake lines are on (minus the main rear 1) and a quick coat of paint. I pulled the cover and everything inside looked good, I'm not sure if this is the orgional Axle for this truck unless they changed them over for the 1990 year, this 1 has 9" drums like my 96 XJ. My 88 MJs D35 uses 10" Drums :hmm: Anyway I feel kinda weird putting effort into cleaning up a D35 but hey, once its in its new home Ill have a D44 to go over next :yes: Stay Tuned... :typing:
  11. no problemo. I'll send some out next chance I get. :thumbsup: 870 Remington, yes? Yes that is correct! I gave my last 1 to a windsheild of a pretty SWB today
  12. No, I removed the vent hose prior to snapping the picture, the hose that was cut was the brake line, I was just confused on how 2 replace it prior to knowing that peice was indeed removable ;)
  13. O alright Awesome......i never thought of that :fool: Thanks! :cheers:
  14. Alright so I am currently working on a D35 to swap in my 89 MJ and have come to a bit of a confusion.... The rear hard lines on the axle will need replace as the fittings were rusted tight, no biggie however when the axle was removed the brake line was just cut on the rubber line. Now that ive began looking over everything i believe that rubber line and "block" are acctually part of the axle assembly :hmm: here's a pic of what I'm talking about, basically I'm just looking for an idea about working around this or what excatly to do about it when i goto put the new brakes lines on and swap this axle in... Thanks for any help. :thumbsup: The rubber hose end that was cut is also in the pic.
  15. Began going over the Axle in preperation for the swap in.
  16. Id offer him $650...... If he'd throw a set of rims/tires on it id glady pay $800 :popcorn:
  17. Had a very MJ filled afternoon. see my "new chapter" topic :D
  18. Well didnt do any direct work this this truck today but I did enjoy an afternoon pulling its donor axle from my parts rig. The meeting of the Comanches was commensed around 11:30am est. With some (ok alot) of help from some friends we managed to strip the Rear axle, leafs, and fuel tank out of my parts rig this afternoon. A Quick powerwash and check over of the axle shows brand new rear brakes and overall in good shape, alittle rusty but ill get it all cleaned up and change the fluid and it with new U bolts itll be ready to be installed within the next week or so. Stay Tuned! :thumbsup: Next on the list, pulling the 44 :yes:
  19. 3.55s will be a great upgrade from 3.07s :thumbsup:
  20. Yeah, no one suffered any damage from them, most of them even held up great during that part of the course, I was acctually suprised 8)
  21. The whole cluster is plug and play. all you need is the correct oil pressure and water tempreture senders :thumbsup: The RPM gauge is already wired into the factory harness.
  22. Alright within the next month os so ill be completing my Axles swaps and would like to replace all the U bolts just for peice of mind. Can anyone send me a link or point me to a place that I can get 2 sets of U Bolts (8 total). I need 1 set for a Dana 35 rear and 1 set for a Dana 44 rear. Thanks! :thumbsup:
  23. I'm not sure what this 1 will become. I have my current 88 MJ i DD most the time and have my XJ which is pretty much stock and is mainly used for highway trips and towing the Quads. When I'm finished with this truck I'm sure ill drive it around for alittle while, being its a LWB it might come in handy for hauling certian things around and such (compared to my SWB with rollbar). I still kinda have plans to re sell it next Spring/summer but it all depends on what I feel like, I'm not gonna have alot of money into it (thanks 2 the parts truck) so I might end up with just another MJ. Ill decide @ a later time, lol for now ill enjoy the project :yes:
  24. ok, ill try to upload it on youtube, might be 2 long though :dunno:
  25. I managed to pick it up for $1500. 8)
