krustyballer16
    6
Everything posted by krustyballer16
  1. Not that it matters or that I care, but are you vaccinated? Just for scientific purposes lol Sent from my SM-G973U using Tapatalk
  2. I might be making more soon... Sent from my SM-G973U using Tapatalk
  3. I hsve one under my bed trailer in Central Indiana. Not the cleanest and I know nothing about it...lol Sent from my SM-G973U using Tapatalk
  4. So hopefully in the next few weeks I csn scrounge up enough money to get a batch of hitch plates and seat brackets made! Just in case I'm no longer working at my current job where I get this stuff made at...
  5. So hopefully in the next few weeks I csn scrounge up enough money to get a batch of hitch plates and seat brackets made! Just in case I'm no longer working at my current job where I get this stuff made at...
  6. This is what I'm needing to cover... the plug I cut a square hole in is for another hole in the firewall. Doesnt fit this hole perfect and the square hole doesn't fit the harnesses right lol. But it may work for now.
  7. I'm looking them up right now. Ya, I'd assume it'd need to be a tight fit to be completely sealed. The problem I have is I need a 2" hole for the plug to go thru but then then harness is only ½" around so I need a big outer area and small inner area but a regular grommet won't work like that. Sent from my SM-G973U using Tapatalk
  8. Had anybody used these or similar? https://www.summitracing.com/parts/sit-sgs3-5-100 Was gonna try them on my firewall and Trans tunnel foe the Holley harnesses. Pros? Cons? Sent from my SM-G973U using Tapatalk
  9. I am not. But these diagrams were different than the ones I used for my 91 wiring. The couple wires I traced down all match my 90 wiring...
  10. I need the wiring gurus! LS swapping my 90. Using the holley terminator for the engine. I stripped all the stock wiring out of the engine bay and removed all the pins out of the firewall bulkhead connector that I don't need (I think) but now I've got some questions on some stuff, 99% of it being for the jeep side of it... I used these diagrams to trace down each wire and they match all my colors so I'm guessing it's accurate. #1 -there are 3 big red wires that are called out as Battery, Battery and Acc Power... They were all eventually ran into one eyelet for the battery and had the inline, non replaceable fuses or whatever. I cut all that off and left 4" at the firewall and was going to run one 10ga wire from those 3 tied together to the battery. Is this fine? #2 -i did away with the big red and white Battery disconnect wire. No problem there right? #3 I have to run an alternator exciter wire. Do I wire it into the yellow "ignition switch" wire? #4- the green "ignition switch start" wire. Is that ran to the starter? #5 - I guess I accidentally pulled out the pin for the back up lights. I'm guessing I need to put this pin back in or can I tap into anywhere Else for power to back up lights? I think thats it for now...shoulda paid closer attention when I was pulling the 4.0 and cutting wires lol. Went from 45 wires at the connector down to 17.
  11. Looking for a renix (not sure if there's a difference, wiring maybe) steering column. Doesn't matter if it's tilt or not. Doesn't necessarily have to be grey either I guess. Just completely functional and not broken in any way and as cheap and close to 47846 indiana as possible. Lol. Sent from my SM-G973U using Tapatalk
  12. I am out of everything right now. Maybe in a few months I'll start making more Sent from my SM-G973U using Tapatalk
  13. My 3 year old got up and started singing in the hospital waiting room area. Lol There was a few people there and he's usually very shy and rarely sings around us. Goofball! He probably only did it cuz my mother in law was there next to him. received_2965731203718258.mp4
  14. I've got one left for the year. It's already built. I can ship after payment. Message me on here or Facebook messenger :Brandon Scarbrough Sent from my SM-G973U using Tapatalk
  15. I just don't think anybody likes you Nick...[emoji1745] lol Sent from my SM-G973U using Tapatalk
  16. Honestly, probably will be barely any comanche parts cut on it lol. Unless there's some very simple, flat parts that every needs. Might try to redraw the hitch plates and make my own small runs of them. Sent from my SM-G973U using Tapatalk
  17. My next "new" vehicle will probably be that generation 4runner Sent from my SM-G973U using Tapatalk
  18. Should be here in 5-8 weeks!
  19. Any updates? I'm looking into this maybe. Possibly the 4x3 table...
  20. I've got 5 sets left I think. It may be a while once theyre gone before I can get more cut. Material is scarce around here. And the price of material has gone up so the price of this next round will go up too. Sent from my SM-G973U using Tapatalk
  21. I do not. Hooligan does though Sent from my SM-G973U using Tapatalk
  22. Ok, I have enough parts to build 2 more hitches. The big issue right now with ordering more is that ¼" material is very scarce around here. I work at a pretty big fab shop and they are having an extremely hard time getting any material at all for contracted jobs. So my little job gets out on the back burner like usual. So I'm the last to get the material I need. I ordered more parts about 2 weeks ago and haven't heard anything yet so not sure how much longer it will be until more parts are cut for me. So these 2 may be it for a few weeks or months. And the price will be going up to $230 still. I'll wait a few days before I advertise these on Facebook. Thanks for the support guys. (Having the same issue for seat brackets too. I have 5 sets of them left for right now) Sent from my SM-G973U using Tapatalk
  23. UPDATE: I'm about to order more side plates and tubing. Prices have doubled since the last time I ordered any so that unfortunately means prices have to go up again. Not much though but it still sucks. Hitches will now be $230+ shipping. Up $15 from the precious price. My question now is; how many more do I order? I usually order 20 at a time so far that has lasted a few months. But I have sold enough hitches and parts for 180 comanches. How many more people need them? Now or even just a thought for in the not so distant future. I'll be posting here and Facebook to kinda get a count. If I need more than 20 then I might order more, if only 3 people acknowledge these posts then I might only order a few for now. I just don't want stock sitting around. Just post here on your thoughts and if you'd want a hitch sometime, basically "claiming" one before I decide to stop making them or the prices get too high to be worth it Thanks guys. Sent from my SM-G973U using Tapatalk
  24. Says it's most likely from MySpace breach. Holy Flashback lol. well nuts Sent from my SM-G973U using Tapatalk
  25. I read that article and emailed everything I could. Lol I've tried using the laptop and it's the same exact thing. Sent from my SM-G973U using Tapatalk
