11
J10 Dana 44 front
DirtyComanche replied to Omarmartinez33's topic in MJ Tech: Modification and Repairs
J-trucks are wide track, about 66" wide. It's actually an advantage compared with the narrow track Grand Wagoneer axles. But yeah, you'll need a suitable matching rearend, look in the same truck for that, or get a C&C GM 14 Bolt as it will be close. Also certain mid-70s F-truck axles were about the same width. I believe they are driver's drop post 78? Mine are all passenger drop, and I'd gladly trade one for a driver's drop... All that said, it's a low pinion D44, I wouldn't do it, it's not worth it. -
97+ swap and LS questions
DirtyComanche replied to Kwebb9's topic in MJ Tech: Modification and Repairs
Just buy it. The harness, sensors and ECM is worth it alone. -
My consumption is staggeringly low. It actually has a very tight engine in it. It was a GM crate engine somebody bought and wrapped the truck it was in around a pole shortly after. I really should change the oil because that's easier than changing the engine (again).
I don't know that you'll learn anything terribly useful by trying to get it to run on starting fluid. And stored code history will likely be fairly irrelevant too. I'd say just look it over and hope for the best. How cheap is it? -
Why does it have no fuel lines? -
Makes more power, burns more gas. If you wanna go fast it's a good starting point. The factory tune is also really conservative, and some power and economy can be pulled out of them with just a tune. You're going to need a tune anyways (delete VATS, and probably the rear O2s, maybe a few other things) so you might as well either find somebody that writes good tunes or just buy HPTuners and try not to blow your engine up. How many miles on it? One downside of the engines in the 2500+ trucks is often they're beat on pretty hard. -
In a 2wd I'd just get a F-body oil pan and set the engine low. If you even need the F-body pan. I know you can use a tape measure, so you can determine if you're going to have a clearance problem or not. -
1990 Comanche sport truck build
DirtyComanche replied to cbreiter's topic in Member Projects: Your Comanches
Looking better! -
Pretty much. I should order a filter for it so I don't have any excuses.
Vehicle speed sensor. Assuming you're putting it in with a manual transmission, an automatic that's not controlled by the ECM (IE a TH-400 or a 4L60), people will tell you that you don't need it. If you delete the input so it won't throw a CEL the engine will likely stall every time you come to a stop. Cheapest way to do it appears to be to buy the whole donor vehicle, pair down the harness and dump the engine/trans/tcase all in as one. If you buy Novak motor mounts you will need a LS1 or LS6 style intake to clear the hood, plus their headers, and you'll have to rearrange the accessory drive. If you set the engine low and build your own mounts you can clear the hood with the truck intake you will lose some axle to oil pan clearance and a bunch of oil pan to ground clearance; if you buy a F-body oil pan to fix that you'll have all sorts of oiling problems off camber and will need a baffle kit and an accumulator. There is some other factory oil pans which give you a compromise on clearance but with less oiling issues, plus there's a couple steel aftermarket ones that aren't bad. Most guys are cutting out the front crossmember and stuffing a larger squarish radiator in. -
I haven't changed the oil in my plow truck is 5 years. It looks like brand new, yup, it's propane. That's with tons of full throttle use and abuse and driving it on the road in the summer the first couple years. That doesn't mean it is okay. The actual contaminates most often damaging to an engine are metals in the 5-15 micron range, which unless in really high concentrations are not very visible and will most likely be silver in colour if they are. What makes oil black is soot (carbon) and often it the pieces are smaller than 5 microns, so it really doesn't filter out in a conventional oil filter. With a 10 micron absolute (which will filter 5 microns most of the time) bypass setup you will get most of it out, along with almost all of those 5-15 micron pieces of metal. Carbon itself isn't a terrible thing, it's not hard enough to cause any real wear, but it will deposit itself in places and the bigger chunks do plug the filter. Anyways, the problem with only running a conventional filter is that it becomes much less efficient in short order, as more of the media is plugged with various contaminants it makes it so the remaining unplugged areas are more likely to just have contaminants pushed through them. I don't personally see an issue with extended oil changes with synthetic oil, YMMV, but you MUST change the filter at a regular interval and top the oil up. Topping the oil up seems to reasonably effectively restore the additive package, which breaks down through heat and oxidation as the oil is used, and if you don't do this the oil will lose it's effectiveness in various ways along with typically becoming acidic in nature. Oil becoming acidic is very hard on bearing surfaces and will lead to corrosion attacking them. If you really want to not have to change your oil then adding a bypass filter is the best bet.
It's something related to how in Crapatalk you can like a post. Whoever gets the most likes in a day "wins" the day.
My only comment is don't let anyone talk you out of running the VSS. -
What is it out of?
Fuel pump ground
DirtyComanche replied to Kyleinreallife's topic in MJ Tech: Modification and Repairs
I'm not that old or crusty and I don't Tapatalk. I'd rather look at the full page on my phone than have it different and weird. Get it really cold first by putting in the deep freeze, and then predrill the hole. -
Liner isn't nice paint, it comes pre-ruined for you.
These fit the stock holes. With the flash from the camera you can see where I blacked out the wiper logo. They're complete generic, tons of them on Amazon. https://www.amazon.ca/Amarine-made-Waterproof-Marine-Rocker-Switch/dp/B0727X2CHK/ref=sr_1_4?ie=UTF8&qid=1524719936&sr=8-4&keywords=rocker+switch&dpID=41HeDfNIx8L&preST=_SY300_QL70_&dpSrc=srch Finding ones with the lettering you want can be a challenge though.
You're doing the whole truck? Please don't. But if you do the whole truck to a thickness that it's actually tough, it will be 100lbs at least. A proper spray-in box liner is easily 50lbs for a short bed truck. If you're talking about doing the box, you do want to prep and paint the rest of the truck first as it is nearly impossible to mask a line against bedliner. The only way around it is to hide the edge with bedrail guards.
How do the filter efficiencies compare between the two?
Lada front. No idea what it's called.
PCO6's Expedition Trailer Build
DirtyComanche replied to PCO6's topic in Member Projects: Other Cool Stuff
This forum doesn't use normal BB code, but if you insert normal BB code it will change it automagically to it's own flavour. However, it looks like Expedition Portal doesn't either, and whatever weird code it uses isn't recognizable by ComancheClub. -
Wow, that trailer you built sure is nice. -
Fuel pump ground
I forgot about that one. Wonder if I have a username there? -
I was at the dump unloading a bunch of trash into the bins and a guy with a newer Dodge Ram pulled up (3rd gen) and was like "Wow, cool truck, you don't see those anymore! I'll trade you for mine right now!" I said I couldn't, I had more money into this truck than he could imagine.
Fuel pump ground
This forum is way more helpful than any of the actual Cherokee forums. CherokeeTalk... Totally dead over there, only a 4 people with XJs post. JeepsUnlimited... Actually dead, as in they pulled the site. Jeepforum... Lots of people there, good luck getting an answer out of them though unless you've got questions about roof top tents. Reddit... Uh, it's Reddit, it's skinny jeans and the man buns. NAXJA... Okay, you might get an answer there, but it's more likely they'll ask why you would need to find the ground and recommend that you find the positive wire instead. Pirate... Not everyone enjoys being called names. So yup, it leaves here.
