Kenosha Warrior
Everything posted by Kenosha Warrior
  1. Oiz.....no man who drives a Jeep, anywhere, is allowed to make a statement like that :chillin: Jeff hear hear. our junk is hit and miss, so keep quiet. we don't wanna be like those chevy boys :P
  2. less than 20mi I can tell you that. a quick run around town. never going out of 3rd gear. Ill give it a bit, its sat for over a week without power/being driven. Ill give the fuses a once over too.
  3. I just replaced my alternator and battery because I soaked my alty while driving through a lot of *deep* puddles. well. my wipers, lights and heat are all working nicely now, same with my new alt and battery. nice and powerful. My only problem now, is that my upshift light, my seatbelt light and buzzer, my brake warning light and all those lights in taht little area aren't coming on anymore. no more seatbelt buzzer. nothing. Even the Oil pressure and battery lights on the dash (idiot lights) that normally come on when you turn the key into the on position won't light up anymore. everything else is running hunky-dory.
  4. a 2.5L would have what behind it? a 231?
  5. whats the t-cases the 4.0 mj's would have? Ive got a 2.5, what one normally came behind that?
  6. The 228 or 229 was what they were using as the 'Selec-Trac" option back then, and just like the NP242 Selec-Trac on the newer XJs, I don't think the option was offered with the 5-speed. So it's most likely an AX-5 with NP207, but as noted, it could be a T-5 tranny. ot I know. but whats the difference between the Selec-Trac and the Command-Trac
  7. I stripped the fill plug on my xj one, I just welded a nut to it, and am still using it haha.
  8. Web Admin/ Site Admin, like your title. :D
  9. just to be safe, check the batt and alty. I know a few members that can vouch for this. its a real pain as it'll leave you stuck in the middle of nowhere if its not rememdied.
  10. Is it right on full, or way past? Are your wipers, heat, radio and anything else electronic working ok? Renix's don't like wonky power. if there's an issue with your alternator or battery, the fuel gauge won't read right, the heat and wipers will lag and your low beams will be extremely dim. if its right on full, well. mine doesn't work period so I just carry a 5gal jerry can in case of a run-out.
  11. hrm.. I think I may need to yank my drivers door panel off. its my TuesdayProject. :)
  12. yeah, it likes to move on its own haha. I'm doing piston rings, lower crank bearings and such in the summer so it should cure that.
  13. Please bend over while we 'service the account'
  14. he plays hockey, and its all his little 8 and 9th grader friends. I get them back pretty nicely though, I'm head of the AV dept at school, we create all the movies and stuff for the school wide assemblies. nothing like a video of the school hockey team skating a practice in speedo's with David Hasselhoff's body. thats my payback. screw the physical stuff, mental is much more fun. Ill youtube it when I get my hands on my copy of it.
  15. must be a Canuck thing, eh sinnae?
  16. ripped? I paid $50 total for the 3 of them from CarQuest.
  17. Being an '87 I don't think I can get a factory build sheet that'll have accurate codes, but I'd be willing to bet a latte that my '87 SWB is factory original with the D44. I bought it from a girl whose father was the original purchaser. There is nothing about the truck to suggest that they ever did anything other than drive it, and maybe change the oil once every five years or so. I have to replace the driver's door window mechanism when I get the truck back on the road. Maybe I'll get lucky and find the original build sheet tucked inside the trim panel. ive heard of them beneath the seats as well... ithink (comancherob?)found his there. yepyep. under the drivers bucket or centre of the bench.
  18. mine will roll in 1,2,3 or 4. Rev is the only gear that will hold it. It was rocking about 4-5" back and forth when they pushed it. thing that makes me a little scared is that I'm on a sloped driveway at almost a 30 deg. slope. it was moving 6" in reverse and then back to its original position. christ I hate my brother and his friends. no respect for anyone else's property, they've taken out my mirrors, tail lights, dented the hell out of my pass. quarter panel, I can't have anything nice on my MJ because they yank it off, dent it, ect. They even took the window outta my dad's van when he first got it.
  19. my idiot brother and his friends are playing hockey in my driveway. The MJ is not moveable at the moment as its got no serpentine, alty, battery. Its got no ebrake so Ive got it sitting in reverse (AX-4 tranny) since I can't drive it out of the d-way. they want me to push it out, when I refused, they started pushing on the front, trying to roll it down the driveway. how much damage of possible could that do to my tranny?
  20. yeah, relaly. my fan won't turn, couldn't figure out why. wait for it I zip-tied it to the shroud so it wouldn't whack me as I was removing the alty.
  21. I found one with a giant tree sitting on the cab at a pick'n'pull near here. yard wants $200 drum to drum and the spring packs too. I told them to hold it for me :D (mj's out for a couple'a days, dead alty)
  22. wrong buddy :) plasma cutter and a sawzall
  23. false alarm. helps if I route it properly around the fan. My dad noticed what I had done.
  24. this is driving me insane. Ive rebuilt my alternator, and now when I go to put the belt back on, its got about 3" of slack, and my tensioners are out as far as can go. help?
  25. Rebuild is not looking good right now. I can't get the damn pulley off. I'm going to call McKeowns Dodge/Jeep in the am, and carquest also to see if they have any in-stock or can order one on the ASAP.
