fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. My marvelous wife just finished sewing a rear panel to keep out the bugs. The whole thing can be unzipped and rolled up or just the center portion leaving the screen.
  2. Added a tailgate strut to soften its opening. opening.
  3. I wanted to add a tailgate strut to the WilderNest trailer so when we are inside with the tailgate closed and need to open it, it won’t just drop. Here’s what I did: Parts: 1) Tailgate support cables for 94-01 Dodge Ram https://www.ebay.com/itm/354347359527 2) Tailgate strut kit for 07-18 Chevy Silverado/Sierra https://www.ebay.com/itm/295782351237 3) Two 10mm Ball Studs (looks cleaner than modifying the brackets which come in the strut kit) https://www.ebay.com/itm/223293493196 (these are 5/16-18 thread) 4) Washer to fit upper cable end (I used 3/8” washer with 0.81” OD) 5) Bolt and washer to attach lower cable end to tailgate (I used a 1/4-20 cap head bolt, don’t want the head to be too prominent) 6) Nutserts appropriately sized for the Ball Studs and bolt for lower cable end 7) Blue Loctite 8) Drill, angle grinder with cut-off wheel 9) Drill bits appropriately sized for nutserts used Procedure: recommend priming/painting any bare metal 1) Remove tailgate strap bumpers from the left side of bed and tailgate (could install on either or both sides.) 2) Remove upper strap support pin and braze/weld a washer to it to fit the upper cable end. If you don’t the cable end will try to kick to the center and could be hit by the tailgate bracketry. Reinsert pin. 3) Drill hole in bed 8.25” up from top of the body mounted pivot bracket in line with the taillight mounting screws. 4) Insert nutsert and fasten ball stud (could do nut/washer here.) 5) Drill hole in tailgate 0.5” from end of tailgate pivot bracket, insert nutsert and fasten ball stud. 6) Cut off left strap on tailgate at pivot point. 7) Grind the pivot point flush with bracket and knock out remaining material. 8) Drill hole for nutsert through hole in bracket AND tailgate for nutsert/bolt clearance. 9) Insert nutsert into bracket (I removed the two Torx bolts holding the bracket in place and pulled it away to insert nutsert, may not have to.) 10) Attach the upper cable end, you might have to slip the cable on the pin then attach pin depending on washer size. I ground down the top and end portions of the cable end so it would rotate without binding and I could slip it over the washer and rotate it into place. 11) Attach lower cable end using bolt/washer, not too tight, cable needs to pivot, I used blue Loctite. 12) Attach the strut, the two ends are adjustable, adjust so when the tailgate is down there is no load on the strut. 13) When closing the tailgate feed the cable to the right of the strut, it may do this automatically. Disclaimer: your measurements may vary
  4. Filling the water tank was a pain in the a$$, since it has no vent the fill tube would fill with water and air couldn’t escape. My simple fix was to place a fill hose within the outer hose allowing air to escape through the space between the two, it also allowed attaching a garden hose for filling. I also added an air filter on the small vent tube of the fuel filler neck to allow air in as the faucet is used since the cap will be in place.
  5. On eBay in Los Angeles, CA
  6. I just reread your Rigistry post, we’re still not sure if it’s an ‘88 or ‘89, I think it’s an ‘89. What does it look like above the brake master? Like the white 88 or the red 89 below?
  7. On Ebay in New Braunfels, TX asking $7k OBO
  8. Just ask the guys at Oracle to verify.
  9. That is all simple stuff you can do yourself. If you smell gas, look for leaking fuel injectors. Is it a 4.0L? You have v6 listed in your signature but ‘88 didn’t come with v6, 4.0 in-line 6 or 4 banger.
  10. Seems steep for their condition.
  11. Key parts has an eBay store, https://www.ebay.com/str/keypartsinc
  12. You have to go with Marchals when you have an ‘87 and such a nice OEM bar. They come in black and chrome. These are 850’s on the bar and 750’s on the grill guard.
  13. On eBay in Auburn, NY
  14. The export ones actually have a black border on top that shows when installed.
  15. Boooooo!
  16. Send back the alternator and get a replacement.
  17. Not too difficult. I welded a washer to the top of the upper strap support pin to keep the cable end in place and cut off the strap where it attaches to the tailgate bracket then cut that head flush, drilled it for a nutsert (through the tailgate also for clearance) to attach the lower cable end. The bumpers need to be removed so the strut will fit. I will probably replace the other strap with cable, much quieter.
  18. Installed a tailgate strut. This was a test fitting before I add one to the MJ Happy Camper. I’ll post in the DYI section when I install the one on the trailer.
  19. Is that a Comanche? never mind, Cherokee just saw the rear door.
  20. I finished the drawer a week ago but just now had time to open up the WilderNest for pictures. The carcass is approximately 81” long, 25” wide and 16” high, the drawer is 75” long, 15 1/2” wide and 13” high; I made it large enough to hold three of our camping storage boxes with space to spare. The drawer slides on 3/16” thick UHMWPE strips to maximize space. The top, left side, drawer front and rear are 1 1/8” plywood the rest is 3/4” ply assembled with pocket screws (about 200 of them!!) and glue. Everything was given three coats of exterior paint (color matched to the paint I used for the shell interior) to minimize mold/mildew, the top and left side were then covered with tan vinyl diamond plate and edged with stainless steel corner guard since it also serves as the step to the sleeping platform. It’s bolted to the bed using stainless bolts from underneath into t-nuts in the base. The space on the right with the wheel well is perfect for storing the long support poles and stabilizing legs while the space on the left still accommodates the large boxes which were initially intended for the FJ Cruiser’s roof rack, they will even stack with the Nest closed. It was a fun little project.
