Gojira94
Everything posted by Gojira94
  1. Tall boy shifter stick from a TJ. I kinda like it. In first it sits at 3:00 from the wheel about 4" away. The tall AX15 shift tower IS from a TJ so it's a shorter throw already. XJ/ MJ shifter on the TJ shift tower:
  2. Pics on the 89 auto XJ don't show anything. I was focused on cruise parts and connections. What I can say for sure is that C111 (manual only) pin A for a 4L goes straight to pin H on C115. C111 pin B is power and passes through C100 C5 to the hot side of the trans fuse. What apparently is C115 (engine control harness side) on mine I'd ignored, thinking it was the emissions maintenance timer connector until I looked closer at the 87 and 88 electrical manuals and noticed 87 didn't have one. And the color of that BLK/YEL wire taunting me lol. Polarity of the reverse switch on the trans itself makes no difference, obviously. This is from the 87 manual, 88 is identical. Though 87 shows diesel-optioned connections.
  3. Well, one side in my pic above (larger connector with 3 wires) is attached to the instrument panel harness and shares a wire with the cruise power-cancel/ TCC unlock connector (also visible in pic above). The other side (small connector, upper right, one wire) is attached to the engine control harness. So I don't think so. I suspect I might have mismatched, by year and harness types, connectors for the 2 sides of C115. I took some pics under the dash of an 89 auto XJ when I was pulling my column and cruise parts from it. I'll have a look at those and see if I'm lucky enough to have captured anything relevant to this question.
  4. Let me preface this with an apology for being long-winded... My 1987 rig started out as a base 2WD, AX4, 2.5l. POs were in the beginning stages of 'making one good out of two' MJs. The engine harness MAY be original. The engine control harness is definitely from 89 or 90, no C101. The 1990 FSM shows C115 being the only thing on the tree besides the ECU connectors on the inside portion of the engine control harness. I strongly believe my instrument panel harness is original, 1987. Emissions maintenance timer wasn't in the electrical manuals until 1988, and mine has no provision for it. Now... C115. I have a theory, maybe some of you can confirm or correct- the type/ shape of connector C115 may have changed in 1989 or 1990. On top of that, if the engine control harness was for a manual, along with not having C113, two of the pins present in C115 for an automatic might be absent in a harness for a manual. Leaving just one wire- pin H, BLK/YEL. I'd have to see an unmolested auto MJ or XJ to confirm. So... I had no reverse lights. They're dependent on switched 12V in run/ start. Confirmed 12V power at the TRANS fuse socket, brown wire coming in through C100 pin C5 by touching a ground point with the negative lead of my meter. What I believed to be C115 on the IP harness side has continuity from the other side of the TRANS fuse socket on the BLK/YEL wire on pin H. That side of the fuse has another BLK/YEL wire going to "transmission controls." Pin K on C115, BLU W/TR goes to pin A on C260, cruise/ trans switch. Anyway, I tested continuity from C111, pin A, BLK/YEL to the lone pin populated in the engine control harness side of C115. There we go, confirmed. Next I took a leap and jumpered the BLK/YEL wire on these 2 very different looking connectors and tested. Et voila, reverse lights now work. Is there something I've missed here? I mean I can live with this, make it solid and neat and tucked out of sight forever, but surely... I must be missing something a little more obvious?
  5. Off work from job 2 at 10PM, back on C100 TLC. LF turn signal now working. Conditioned all the female pins. A1 was slightly boogered. Took a little time with all pins on both sides, hoping my other issues can only benefit from the effort.
  6. Yeah, I was surprised when I read that in the electrical manual. Most cars from that era the horn wasn't 12V switched. Go figure.
  7. Battling electrical gremlins right now. So far: 1) Blower doesn't work. Back burner... 2) No power to turn signal flasher. Fixed. Involved pulling C100 apart and extra cleaning of contacts on the fuse box side. 3) LF turn signal gray w/tr wire is only seeing constant .3V w/ LF blinker on. 4) Reverse lights not working. Reverse lights switch definitely bad, found one locally. Back burner... What it took to get reverse lights... 5) Horns not working, no click from relay. Back burner... Hazards/ parking lights work on all 4 corners, rear turn signals work, brake lights work. #3: confirmed continuity from C100 pin A1 to C102 pin 3. All other Front Lighting harness pins have good voltage/ ground. RF turn signal works after replacing socket with broken ground pin. Pulled C100 (engine compartment side) again, in the process of cleaning & tweaking contacts on both sides. Next check is continuity from C156 pin H to C100 pin A1 (instrument panel side). Lunch break over, back to day job...
  8. I roughed in the uppers with about 1 1/4-1 1/2" thread showing for the approximate pinion angle. Also need to get the SOA and shackles done for the rear pinion angle setting. Then make final adjustments and nut and bolt the whole suspension. Working my way to the rear bumper, still in the cab lol. Lowers I set to make the wheelbase at first as close to 113" as possible. I came in right at 113.5" which should be fine, and help with that caster angle a few tenths of a degree positive. I left about .125" of thread showing on the lowers, and dead center in the drop brackets' adjustment range F-R.
  9. Those drop brackets are nice, I really like mine. Be prepared to do a fair amount of very small grinding in the frame's LCA pockets to get the fitment just so. The bracket kit was welded together with a MUCH higher degree of precision than your MJ was Also, you'll find when setting the wheelbase with the Core 4x4 arms and the RRO brackets it'll want a very close to stock LCA length, with the arms adjusted just about to their shortest length, with the brackets set to dead center adjustment. That's what I found to be the case on mine, with about 6.75" lift up front on OME 2934 coils and ACOS.
  10. Group 34 battery does fit after all. Today she got cab harness, a battery, new hood release cable, door checks, stereo and speakers installed, wiring for the cargo light repaired. Last interior electric item is to finish up the feeds for the Euramtec lights. Then carpet, panels, and a seat!! w00t! Also... this afternoon at lunch break I got 5 gallons of 89 and fed it in. I've confirmed tonight there are no fuel leaks. Fuel pressure at KOEO/ prime is 38psi according to the mechanical gauge on the regulator. It spun strong and even... and barked off almost immediately. Before I remembered I'd pulled the IAC off and hadn't yet swapped in the Renix TPS. So I shut it down promptly lol. Tomorrow, hopefully a video of it running while I top off/ burp the cooling system.
  11. Dash and everything in it/ behind it is situated and secured. All the cruise components are fitted. Headlight sentinel and intermittent wiper module are installed. Also added footwell lamps. Next, I'm working my way back from C118 and C157 at the instrument panel harness, door speaker, dome lamps and cargo light. My truck has zero power options so no crossbody or actual door harnesses to deal with.
  12. I guess I never knew better lol. First one I ever pulled in the boneyard was for my 92 Chevy C1500. That's how I did it, just dropped the column. It's easier in an XJ that has the parking brake assembly in the console/ tunnel. MJs with the pedal parking brake are trickier, with limited space at that brace bolt next to the chime module. I suppose the next time I'd try unbolting the steering box. Thanks for cashing my reality check...
  13. Now it's on... like a pot o' neck bones!
  14. Fade to black... I took apart the column for one more good go-through and painted the bowl assembly plastics black. No more gray. Except that wheel... I really thought I'd take the wheel to a local interiors and tops shop in Raleigh to have it wrapped. Meantime, I wondered how hard it would be to do with a DIY leatherette kit from Autozone. Video on YouTube of a guy doing a YJ wheel identical to this one convinced me to give it a try for $15 on Amazon. I was surprised that it's actually real leather. Anyone wants to try it, the kit size for the 3-spoke wheels is M2. Fully dressed column glamour shots lol:
  15. Dash is really roached. I glued up a number of semi-structural cracks. I'll be looking for a replacement as time goes on, pulling one of these is cake compared to most other cars I've done. Meanwhile, the deep and I mean deep cracks in the pad I just flattened, filled with cotton and taped over with HVAC foil tape. Then glued a piece of marine vinyl over it for now. Meh. Bothers me that it's a detail I can't get like I want it right now, but I'm starting to get in a hurry to just get on with it and drive it by Memorial Day.
  16. Loosen the steering shaft to column shaft coupling on the engine side of the firewall first. Then tackle the stuff inside. Last, uncouple the steering shaft from the steering gearbox. Inside, the column flange to firewall bolts are 14mm 13mm if I recall correctly. The prevailing torque nuts for the upper column support are 15mm. The brace bolts are also 15mm. Just loosen them enough to drop them out of the way. Rest the column/ steering wheel on the seat while you disconnect the old/ connect the new shaft at the steering gearbox end. It helps to have an extra pair of hands getting the column and steering shaft together next, but can be done by yourself if necessary.
  17. I harvested a few of those at the boneyard. I fiddled with it for a while and couldn't quite get it situated. I'll try again to see if I can make that work temporarily. The pic helps. I think the changes in the holes in that panel over the years is why it's not quite intuitive how to use the later clip, staring at an 87 panel.
  18. This gives me an idea for a little L bracket, drill a hole, and pop in a replaceable plastic clip. Thanks!
  19. Would love to see that, much appreciated!
  20. Only one I see out there is in Germany. About $30 with international shipping. Anywhere else I MIGHT be able to find one?
  21. Front bumper is on, fender flares have new backing brackets. Part Time light wires tucked inside the engine control harness. Ground side I just added to the ECH ground pack at the passenger side of the engine. Power side is from the original C300. I'm using a later 2-pin switch from a spare 98 t-case. Headlight harness update installed. Next order of business, the dash and interior wiring so carpet and interior can go back in...
  22. Transfer case yoke swapped, front shaft is in. Part Time light switch wires routed along the driver's side and then crosses over top of the trans and joins the wire pack for the reverse light switch, up to the main body of the engine control harness. Novak cable shifter is in, works great. I did have to re-shape 2 of the ears on the tunnel side bracket to fit flush: Speedo cable housing and new gear for the 33s in place:
  23. Transfer case is in and Part-Time light is wired. However... I've remembered that the 93 YJ it came from had CAD. Turns out ALL YJs had CAD. And the 231 yoke on the YJs used straps instead of bolts. I do have a 231 from a 98 XJ that's for parts (locked up solid, haven't taken it apart yet). I can swap the yoke but man, that would have been easier to do on the garage floor. Last gift of the YJ case is this little factoid I remember from early project research. No big deal, just something to keep in mind for now. The early NP231 transfer case used in conjuction with vacuum controlled front axle hub disconnect on early XJ & YJ Jeeps did not have a true neutral disconnect between front and rear axles when the 231 is shifted into neutral, as controlled by crown in the sector plate on the left. The later 231's did have true front / rear disconnect, as controlled by the valley in the sector plate, right.
