Salvagedcircuit
Everything posted by Salvagedcircuit
  1. Hell yeah, lookin great! Must...find...rollbar
  2. Wooah, where did you find those flares? Are they still available as reproductions or was this a new old stock kind of find? Looks excellent. I always liked the black fender flares!
  3. 5x4.5 is certainly the correct size!
  4. I hear your frustrations. I have a rebuilt gm 4.3L vortec V6 in my astro van from jasper. Its been about 15k miles and for the past 5k miles there has been very tiny amounts of metal filings in the oil filter. Again, brand new rebuilt engine. Took the oil pan off and inspected the engine. Turns out the piston rod caps were not torqued down to GM spec. The rod bearings were removed and they had signs of uneven wear. Purchased all new mhale rod bearings, used plastigauge and my calibrated torque wrench and torqued everything up to proper gm specifications. It's crazy what some companies get away with. Please don't crush the comanche. You will get more by reselling it. There are folks who buy comanche's in any shape. You will get more from a private sale than any junkyard will offer.
  5. What worked well for me was welding in elevator head bolts for the under 1.25in hole sizes. You can get elevator bolts up to 1+9/16 head size from mcmastercarr, but I got mine from the local hardware store. Simply wire wheel around the area where there are holes, measure hole size, get an elevator bolt larger, tap it into the hole, then weld around the bolthead diameter. Its convenient since you don't have to deal with cutting small bits of metal and it's easier since the part does not move around as much if the hole is not too large.
  6. Gosh, those are some clean floorpans! Lucky lucky!
  7. I know the feeling. I purchased my longbed in april of 22 and I have driven it all of about 3 miles since. I put about 4 months straight of work into it and it's still not ready for prime time. I did: grounds 1/2 of cruiser54 tips welded in new floor new vinyl floor and liner brake booster + master upgrade new brake lines new front brake calipers and rear drum cylinders new distributor, adjusted the rotor cleaned all the plugs and checked gaps removed, cleaned and filed valve cover cleaned top of head cleaned out throttle body and sensor replaced vacuum lines replaced and siliconed firewall plugs new rims and tires flushed coolant new water pump new antenna install new coolant tank full gauge cluster mod new belt tensioner pulley horn replacement ignition coil cleaning oil change o2 sensor replacement parking brake cable replacement cylinder compression test new thermostat wilwood prop valve install cleaned up the light sockets all around swapped brake pedal and brake light harness seat bracket welding fuel filter I'm sure I missed a bunch. My comanche needs a new exhaust manifold to pass inspection and I'm really dreading that upcoming job. It's also in the 10s-20s most afternoons so I really am pushing it off until spring. Sometimes it helps to take some time and revisit the problem later. That's what I do. I search around on comancheclub for folks wiser than I, and their repair methods and techniques. My current to-to list: Exhaust manifold fix gauge cluster PRUNDL indicator entire front suspension. everything. entire rear suspension. everything. differential inspection, fluid change install rear spare tire radio + speakers new door seals. Using adhesive foam as a temp fix. complete vehicle paint. paint flaking and peeling everywhere pray to the jeep gods and try to find an affordable original LWB Rollbar
  8. That is a pretty sweet find. I'm still hoping to find my buildsheet somewhere in the comanche. Pete said sometimes it's in the door card or even underneath the air box. well the air box is coming out when I do the exhaust manifold, so we shall see how it goes. Nice.
  9. I'll take all of the above, Regis I got one of those Uvex S8510 full face shields recently, and boy does it make my eyes a lot happier when I'm up and about under the comanche. Good luck with it.
  10. Yep, I have an 88 reinx. The $100 baffle style header is unfortunately incompatible with the reinx 4.0L engine without modifications (change exhaust header pipe, fix header / intake clearance issues). I really really don't want to buy the stock reinx manifold since it seems to be the most prone to failure, but there are not too many options. Sure, the banks and pacesetter are ~$500 each, but I'd still have to do essentially the same procedure for 5x the cost :/ I get it. It's one of the reasons why I waited so long until I found a rust-free cab corner comanche on the east coast. I just don't understand why NY does not give a hoot. NY is one of the nanny states, but for some reason they do not care at all if your floor is falling out of your vehicle.
  11. Ugggh. You guys are killin me here. In some states you don't even need a title if it's more than 25years (new hampshire). That's $500 well spent. dang. Maybe I should make an excuse to go south for vacation. I've had enough days in the 20s lol
  12. I did the radio blank as a precaution. Yeah, I get it. it makes sense. It's just a pain. Believe it or not, inspections are a joke in NY but they are a bear in NH. If you have a spec of rust on your cab corners, you'll fail in NH. You can drive a clapped out mazda / nissan / chevy s10 with a wooden bed and it'll pass Here's a photo I took in lake placid, NY. It obscures his plate cause at this point its a road icon. My Comanche Failures: 1 of the 2 license plate lights were out. I didn't think it would be a big deal. Driver side blinker failed on me during inspection but worked fine before the trip. The column shift prnd321 red marker line was skipping. Again, I did not know this was a concern. Most of all, an exhaust leak. Exhaust header was unfortunately cracked. Bummer Frankly, I was waiting for the valvoline inspection guy to give me an "I'm all alone hereee"
  13. Oh man. This explains a lot. I wondered why there were randomly exposed wires in the doors. I also needed a radio blank to pass inspection. Inspection people are nosy enough. Yogurt container saved the day. Didn't pass inspection tho for other reasons
  14. Neat! Curious, where did you find the gladiator bumper? Junkyard? Ebay? Curious how well a trailer hitch would clear. Maybe I should find out Thanks!
  15. I also have one of those "unknown" lift kits on my comanche. If there is anyway you can share what measurements you found that were stock, that would be awesome. Many thanks from my wack job setup
  16. Hubba Hubba Hubba. Those are all metal right?
  17. Do what it takes to get that comanche on the road brotha My only input is folks tend to not like polyurethane bushings on a daily vehicle because extra stiffness + noise != comfort or convenience. Good luck!
  18. Well deserved! I'm usually not one for additional graphics, but I do like the way the 4x4 decals came out. Very period correct. That and the roll bar . Niceee
  19. For the love of... Someone please grab this. What a steal. Hell, I paid $210 for 5 poor condition turbine wheels and another $700 for new firestones.
  20. Huh. Pretty neat. It's more of a copper cutout than a circuitboard lol. It reminds me of the days when circuit boards were laid out with Bishop tape and light projectors. It would be neat to take a scan of the entire layout and import it into a PCB editor such as KiCAD. Then people could do interesting things like make a modern day circuit board behind the gauge cluster with SMT LEDs and various other components. Dang it Pete, stop giving me projects
  21. You really don't see many of these guys left. https://www.publicsurplus.com/sms/auction/view?auc=3212696 Came up in my bi weekly jeep searches. 186K miles, but she looks real clean. Dang, I hope someone saves this ol girl.
  22. I will say it again, you sir are the right kind of crazy! Loving the work you did on that intake. Dang my friend.
  23. Very true! However, both my 3 jaw and 4 jaw backplates on the chucks have a few thou of runout on them. This is an unfortunate consequence of inheriting a retired school lathe. I am not complaining though, it has been invaluable over the past few years. If anyone's interested, I completed my writeup on the Mamiya RB67 repair process here: https://www.salvagedcircuitry.com/mamiya-rb67-repair.html Thanks.
  24. If it's a proper rear disc conversion, the parts alone are $600-800. Definitely a project though. Dang.
