4
Everything posted by JMO413
Build Date 4/5/88 Body Model JM61 *X1 -H9 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC Amped QYC Amp'd RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" Aluminum Wheels
Started patching holes today. Both wheel wells have definitely seen better days. The drivers side is the worst by far. You could see daylight through it. It also sprayed the back window of it was wet out. I was really afraid it might throw a rock through it. I don't drive allot of grave but my mom lives a couple miles on gravel. It's not perfect but any means but there's no hole. I ran out of gas for the welder and time do it will do for now.
Nice work Pete! She is a beauty!! Thank you for doing this for those of use without the Facebook.
After you working on an MJ our a XJ? That kit is XJ only. What skill level you have is a definite factor in this kind of lift. If you have the time, tools, and place to do it are also large factors.
That is definitely an interesting paint combo. You should add it to the registry. Then we can get a build sheet for it along with a build date.
Local band I absolutely love.
Build Date 6/26/88 Body Model JP62 *W7 Cloth Lo-Back Bckt/Red Accent Seats -H9 3LX ADA LIGHT PACKAGE ADL PACKAGE - 4X4 PROTECTION AGL AHY APA MONOTONE PAINT PACKAGE AWE SUSPENSION GROUP AWH POWER EQUIPMENT GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&& REAR CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-4SPD AUTOMATIC DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHB HVY.DTY/AUX TRANS OIL COOLER NHM AUTO SPEED CONTROL NHQ NMB ENGINE COOLING - STANDARD DUTY PYC Amped QYC Amp'd RAF Radio - AM/FM Cassette SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJM Wheels - 15 x 7.0 Chrome XEA TOW HOOKS
What could cause my low fuel pressure? Renix
JMO413 replied to 1989 comanche mj's topic in MJ Tech: Modification and Repairs
It does if the diaphragm has a hole in it. -
Front End light vibration and travel
JMO413 replied to Myersalec's topic in MJ Tech: Modification and Repairs
I fully understand. Both of mine were death wobble as in lots of curse words and brake pedal though the floor board. And the passenger possibly needing fresh underwear. All the customer vehicles that I have had to drive were a vibration felt in the steering wheel. Trying to explain the difference to most customers is pointless though. Had a 1 ton Dodge in today that got a pretty good shimmy over 55. It's was easily manageable by a slight increase our decrease in speed. Steering stabilizer and track bar fixed it.- 18 replies
- notdeathwobble
- liftedmj
(and 3 more)
Tagged with:
Have you pulled the vacuum line of the fuel pressure regulator to see if it's leaking? -
Welcome I'm just glad I can help.
That is one nice looking truck you have there! Build Date 10/14/91 Body model JL61 *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 161 Zone 61-Atlanta 1AA U.S. Dealer Retail 25H Customer Preferred Package 25H 2TH Customer Preferred Package 2TH 3VU Customer Preferred Discount ADA Light Group ADL Skid Plate Group APA Monotone Paint ARM Radio AM/FM Cassette BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHM Speed Control PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI
I use actual PS fluid. Ford usually uses ATF.
My total of 2 real experiences with death wobble were both Cooper tires. I have drove multiple customer vehicles that they said had death wobble. None of them were that bad in my eyes. Most were a tire problem and one was a steering damper. Road force balancing a tire is the end all for showing a bad tire.- 18 replies
- notdeathwobble
- liftedmj
(and 3 more)
Tagged with:
Mine arrived today in perfect shape. Thanks Pete!
That is a beautiful truck you have there. You have an extra digit in the VIN. Should be 1J7FJ36L4LL167018. Build Date 10/30/89 Body model JL61 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 4EA Sold Vehicle APA Monotone Paint ARL 300 Premium Group BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRC Entire Fleet Key Alike (FREQ 7) GUB Power Mirrors-Base HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3A STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PA2 STERLING SILVER MET CC PRI PNT - HA2 QA2 STERLING SILVER MET CC SEC PNT - HA2 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE 3 spoke Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV
Just beautiful work!
Routine maintenance on what started as a project and is still a project is awesome. Changed my oil today and reached I enjoyed doing it instead of dreading it. Yeahy to a lifted truck no jack required. I only say this beacuse I dread changing the oil in my WK. I love that Wix filters are white no need for an oil change reminder. Hooked up the scanner to just double check everything was working correctly.
HO exhaust manifold on a Renix
JMO413 replied to JMO413's topic in MJ Tech: Modification and Repairs
I could tell no difference when I did mine. -
Mine works great on the HO position and the factory wiring reaches no problem. -
Connector for an AC switch. Radiator temp sensor. Yours looks like there's a plug in it. The black plug with the Allen head in this picture of yours.
Good looking truck. Welcome to the club and the addiction.
